Question about SanDisk Sansa e250 MP3 Player
My usb hook up
My computer isnt reading my usb hook up
  • 8,596 Answers
Try diff. USB port first
Go to hardware --> device manager and see if there is a yellow exclamation bu usb port - if there is, right click and update driver
otherwise:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jun 26, 2008
To put picture on computer?
If your USB isnt working, an easy way to transfer pics to your computer is to subscribe to a cloud service like dropbox (www.dropbox.com) Upload pictures from your phone and then sign in on the computer and download from there.
A usb problem can be a faulty cable or the usbdriver for the cell phone needs to be installed on the computer for the computer to read from the phone,
Jan 13, 2015 | Samsung Cell Phones
I connect the usb into the computer but the camara isnt charging
USB is to download pictures and not to charge batteries - read manual
Jul 03, 2012 | Disney Pix Micro Digital Camera
My hard drive isnt working.the lap top isnt reading it its not going on
If it still has a valid warranty, exercise the warranty to get a free replacement.
Otherwise, open the enclosure, and separate the disk-drive from the USB-to-disk-drive adapter, and connect the disk-drive as a 'slave' disk-drive in a desktop computer, to see if the adapter was the problem.
Oct 25, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
Cam isnt hooked up to monitor
You will need to install the cam software - open that and choose to film a video.
Jun 13, 2010 | Microsoft LifeCam VX-3000 Web Camera
Why isnt my computer not reading my webcam usb cord
why isnt my computer not reading my web cam ,
Oct 06, 2009 | Creative Labs WebCam Live!
Camera wont sync with any computers
YOU HAVE TO INSTALL DRIVER BEFORE YOU HOOK THE USB CABLE.
Jul 23, 2009 | Konica Minolta DiMAGE Z3 Digital Camera
PNY Optima SD HC 8GB isnt working on laptop
Youll have to get updates for your laptop card reader or get a new one which may have to be installed. Another method you may want to try would be to put the card back into the device you used it in and then hook the device up to the computer, most likely through the USB slot....good luck
Jun 05, 2009 | PNY Optima Pro 2GB Secure Digital Memory...
Psp wont charge or hold a charger
It could be a bad battery or you can check under the psp if you can turn it on and make sure that under Settings > System Settings > USB Charge is set to on. If it is and it isn't charging then it's a bad battery.
Dec 22, 2008 | Sony PlayStation Portable (PSP) Console
Mp3 insignia sport
is the battery in correctly and is the usb cable fully inserted on the computer end if your going throug a usb multi-port hub make sure its not over loaded with too many devices
if no hub try a different usb port or a different cable
Aug 10, 2008 | Insignia NS-DV2G MP3 Player
My sansa e250
that means u need a update
Jun 19, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
22 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
