Question about Sony DVP-CX985V Multi-disc DVD Player
Hard Reset By hard reset do you mean unplugging the unit and then powering it back up?
  • Anonymous Dec 30, 2008
    tray keeps moving , will not load disk
    Genius:
  • 1,142 Answers
Correct
Posted on Jun 26, 2008
Lg 42px-4dv/ea sustain pcb fails after 6 hrs running.
Try hard resetting;
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
Figure 1: Example of the reset button labeling on the LC2600N
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Jul 21, 2008 | Televison & Video
Tip
Garmin Nuvi 1450 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1450 Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 1450 series GPS unit.
I hope that helps.
__________________________________________
Garmin Nuvi 1450 Manual Download
Garmin Nuvi 1450 QuickStart Download
Garmin Nuvi 1450 Webupdate
Garmin Nuvi 1450 Favorites Backup
on May 27, 2010 | GPS
Need to reset to factory settings
Try this hard reset method:
  • With the unit powered on, press and hold the reset button on back of unit for 30 seconds
  • Without releasing the reset button, unplug the unit and hold reset for another 30 seconds
  • Plug the unit back in STILL holding the reset button a final 30 seconds
Aug 16, 2011 | Linksys WRT160N Wireless Router
No signal- from my wireless route can not clear arp cahe Linksys sat my wrt54g is old
Perform a 30/30/30 reset; aka Hard Reset.
Hard Reset (aka 30/30/30 reset): The following procedure will clear out the NVRAM and set dd-wrt back to default values:
Mar 06, 2011 | Linksys Wireless-G WRT54G Router
Tip
Garmin Nuvi 1370 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Does your Garmin Nuvi 1370 Freeze at Loading Maps?
You have now performed a hard reset of your Garmin Nuvi 1370 series GPS unit.
I hope that helps.
Garmin Nuvi 1370 Manual Download
Garmin Nuvi 1370 QuickStart Download
Garmin Nuvi 1370 Webupdate
Garmin Nuvi 1370 Favorites Backup
on May 15, 2010 | GPS
Tip
Hard Reset your Garmin Nuvi 205W (Mark 2b)
Hard Reset of your Garmin Nuvi 205 and 205W
Does your Garmin Nuvi 205 or 205W Freeze at Loading Maps?
A hard reset (or Clear All User Data)has been known to resolve unit quirks and strange behavior after firmware updates. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
You have now performed a hard reset of your Garmin Nuvi 205 and 205W.
I hope that helps.
on Mar 22, 2010 | Garmin nuvi 205W GPS Receiver
Tip
Perform a Hard Reset of your Garmin Nuvi 205 (Mark 2a)
Perform a Hard Reset of your Garmin Nuvi 205 and 205W
I hope that helps.
on Mar 22, 2010 | Garmin nuvi 205 GPS Receiver
Tip
How to Perform a Hard Reset of your Garmin Nuvi 205W Does your Garmin Nuvi...
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior after firmware updates. It is generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Your Favorites:
I hope that helps.
on Mar 22, 2010 | Baby Care
Tip
How to Perform a Hard Reset of your Garmin Nuvi 205 and 205W (Mark 2a
I hope that helps.
Tip
Does your Garmin Nuvi 205 or 205W Freeze at Loading Maps? Does it lock up or...
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior after firmware updates. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit. It's also one of the first things that Garmin will have you do when contact tech support regarding quirky unit behavior.
Ifpossible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
I hope that helps.
on Jan 15, 2010 | Kitchen Appliances - Others
Sony DVP-CX985V Multi-disc DVD Player Logo
255 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
