Question about HP Photosmart M425 Digital Camera
Can't reformat my memory card
I took out the memory card in my HP Photosmart M425 Digital Camera and it was working perfect, I put the chip from my phone in another memory card and put that in my camera to transfer the pictures from that chip on to my Computer and when I put the original memory card back in my camera it tells me Card HAS WRONG FORMAT , then it tells me to press ok to reformat and it says Unable to format, can you please tell me what the problem is?
    Genius:
  • 1,234 Answers
Hello
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Posted on Aug 27, 2010
    HP Photosmart M425, "Card Lock" message, camera
    Take the memory card out of your camera. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
    Nov 05, 2010 | HP Photosmart M425 Digital Camera
    Photosmart M425 Digital Camera: How do I get my memory card unlocked?...
    SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
    May 18, 2010 | HP Photosmart M425 Digital Camera
    Would not format memory csrd gigaware 4gb
    The M425 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
    May 15, 2010 | HP Photosmart M425 Digital Camera
    I want to transfer pictures from my computer onto my memory card in my PhotoSmart M425 camera to then put on my digital photo frame. How can I do this?
    Put the card into a card reader attached to your computer. The card will then appear to your computer as another hard drive. You can transfer pictures to the card the same way you normally transfer any other type of file.
    Dec 30, 2009 | HP Photosmart M425 Digital Camera
    Memory card
    You might need the SD card, not the one that has HC also.
    May 29, 2009 | HP Photosmart M425 Digital Camera
    Help with camera?
    Do you have a pc with an SD card reader on it? If you do, you can insert the card into that slot and it will act as a removeable drive. You can find it in My Computer under removeable drives.
    When you connect the camera to the pc, it will become a removeable drive. Just transfer from one drive to the other.
    Let me know if I can be of anymore help, and thanks for coming to FixYa. If you would, rate my solution a fixya.
    Rob
    Jan 27, 2009 | HP Photosmart M425 Digital Camera
    Card has wrong format
    Not a solution, but after corresponding with HP customer service, they concluded that the problem with my M527 (see above) cannot be fixed. They offered to replace it with the same two-year old model for $99.99 which is much more than that model camera would be worth. I declined their offer.
    May 18, 2008 | HP Photosmart M425 Digital Camera
    Memory card
    plug in and turn on your camera to link it. when the option to open the folder comes up, select open folder to view files. when you have that open, simply drag the photos you want to that folder and drop them. they will then be on the memory card.
    Apr 22, 2008 | HP Photosmart M425 Digital Camera
    Wrong format on HP M425
    Just fixed this problem on a M525 camera (same physical construction).
    Do a search with M525 and format.
    Feb 10, 2008 | HP Photosmart M425 Digital Camera
    HP Photosmart M425 Digital Camera Logo
    91 people viewed this question
    Top HP Cameras Experts
    Fred Sops
    teddyboy
    Lawrence Oravetz
    Are you a HP Camera Expert? Answer questions, earn points and help others
