Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Cleaning problem When i clean after is dry looks ashy, what i need to do to solve this problem
  • Euro-Pro Master
  • 43,501 Answers
This type of problem usually is not he fault of the Shark Steam Mop.
The problem is the old residue left on the floors by other cleaners.
Here is a tip that I wrote that will help you out with that problem...
Shark Steam Pocket Mop Cleaning Problemsheatman101
Posted on Nov 07, 2010
My newly laid porcelain floor tiles black matt slate effect look dirty after cleaning with water and a cloth. still looks like they have grout residue stuck to them. How can i clean them
Grout residue is removed with an acid residue remover. The installer should have done that--call him back. If epoxy grout was used (not likely) it will be a real problem to remove.
Sep 14, 2014 | Vacuums
Cleaned filters, lights still blinking
Somewhere in the compartment Where the filters go, there should be a sensor eye. Clean the eye of, and see if that doesn't solve your problem.
Dec 17, 2013 | Dyson DC28 Animal Bagless Upright Vacuum
How can Berber carpets be maintained fresh and new-like for a longer period of time?
You can clean them with household units but even professionals have trouble with berber carpet because of its tight weave and usual inlaid patterns. Dry carpet cleaning between professional cleanings will help keep carpet looking new without staining. My suggestion is to use a dry carpet cleaning machine and then have a professional come in with hot water extract as often as every year depending on traffic. I sell the SEBO DUO machine you can see by clicking the link provided.
http://vacuummedic.com/product.php?id=511
Jun 28, 2013 | Hoover SteamVac Carpet/Upholstery Deep...
How to hook up tool to clean upholstery
Keep your upholstered furniture looking fresh by vacuuming it regularly with the upholstery tool attached to your vacuum's hose. Prevent the fabric from fading (or at least delay this) by keeping your furniture out of direct sunlight -- close blinds, shades or curtains when the sun shines most directly through windows closest to the upholstery. And remove stains by blotting them with a dry cleaning solvent. Before steam cleaning your upholstered furniture, read the piece's cleaning code label to determine whether or not it is safe to do so. Then rent or buy a steam cleaner (also called an extractor) and follow the directions below.
  1. Rent a steam cleaner or purchase one; buy steam cleaner solution.
  2. Step 2 Vacuum the upholstery on the furniture you wish to steam clean; use the upholstery attachment to most effectively **** up loose debris.
  3. Step 3 Test the steam-cleaner solution on the upholstery in an inconspicuous place to ensure the color won't be steamed out or drastically altered.
  4. Step 4 Attempt to remove any stains with a stain removal or dry cleaning solution. Follow the directions that come with the product you choose for the best results, and allow the stain remover to dry before you begin steam cleaning.
  5. Step 5 Remove cushions and, if necessary, arm covers.
  6. Step 6 Gently apply the steaming water and cleaning solution in straight lines across the upholstery one section at a time.
  7. Step 7 Use the cleaning extension on the steam cleaner to **** up as much water as possible. The dirt will come out with the water.
  8. Step 8 Clean one side each cushion (then allow it to dry) before cleaning the other side. If the cushions are permanently attached to the furniture, clean them last.
  9. Step 9 Allow the furniture to dry completely before repeating the steam-cleaning process or replacing the cushions.
Jun 19, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
The carpet does not look like it is clean
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
dhgjdg
Mar 11, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
No liquid dispensed
I cleaned the water and cleaning liquid tubes and it solved the problem! Thanks.
GMC
Mar 06, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 5200 Upright wet/dry vacuum
go to Bissell.com and u can print the manual out solved. you welcome
Aug 30, 2008 | Bissell 5200 Upright Wet/Dry Vacuum
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
76 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
