Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 fills but won't spin
The cycle begins by spraying water and then the minutes just tick down as the machine keeps trying to spin. I can hear it wind up and wind down but nothing happens.
  • Lucinda38 Jul 15, 2008
    It does not make any sound, like ticking and I have to close the door just to hear the faint winding up sound. It fills with water (spray) then sits there and every 30 sec. or minute it winds up but the drum does not move.
    Guru:
  • 1,894 Answers
Do you hear any sound while stops??
like ticking sounds?
Posted on Jul 15, 2008
  • dewan nafees ahmed Jul 16, 2008
    Make sure the lid is closed. There is a switch inside that
    completes
    the connection. Your washer may not spin or agitate if this connection
    is not completed. Make sure that the speed selector switch is not
    between speeds. Verify that the washer is not in a soak cycle. You can
    also reset the water level up or down to make sure that the water level
    control switch isn't stuck. If you hear a humming sound when the washer
    is full of water, you may have something stuck in the drain pump.
    If one of these is not the problem, check the belt. The main
    drive
    motor has two distinct functions. The first function is to spin the
    basket; the second function is to reciprocate your agitator. Inside
    your washer's transmission is a crank type gear and connecting rods
    that are used to agitate the washer, with the spinning coming from the
    washer motor itself. This usually entails some sort of clutch
    mechanism. Some things to check if your washer is not agitating and/or
    spinning are:
    If you notice weak or no agitation, the splines connecting the
    agitator to the drive shaft may be stripped and need to be replaced.
    After a lot of use, belts can become worn or damaged. Replace
    any
    worn or damaged belts immediately. If you have a broken belt, replace
    it and check the pulley to make sure it's not seized.
    Sometimes the drive pulley can wear out and it won't turn the
    drive
    belt. Look for wear marks, pits, or uneven spots. It's best to just
    replace it with a new pulley.
    Many washers use a reversing motor. Sometimes it will continue
    to
    work in one direction even if it won't spin in the other direction. If
    your washer has a drive motor issue, you probably need to replace the
    motor with a new one. Call a professional appliance repair person to
    verify this first.
    The lid switch is a safety device that's there to protect you
    from
    sticking your hands into a spinning washer. If this switch goes bad,
    the washer will not work. You will have to replace it. It is inside the
    main housing for the washer, and located near the door frame.
    The coupler connects the motor to the transmission. After
    lengthy
    use, this plastic and rubber coupler can wear out. If this happens, you
    need to replace it.
    Transmission and clutch assemblies can cause agitator and
    spinning
    problems They are fairly complex, so if you suspect you have
    transmission or clutch issues it's probably in your best interest to
    call a professional appliance repair person.
    please dont forget to accept the solution if you are OK with it.
Have old kenmore elite he3 washer. Have wet laundry after spin out. Have checked ball be low drum, replaced strainer, pump motor, cleaned all hoses. Did a test run in the drain and spin cycle. For like 7...
If the washer is taking more water during spin, then most likely it is thinking the water level is low for the load. It is a smart washer and tries to adjust water according to load. This can mean the level sensor is giving wrong sensor. I would try to run the washer with a cleaning agent (not bleach) available from specialist stores or washing machine retailers.
Also observe if the drain pump is running all through the spin cycle. If not that is likely causing water to remain. But controller is thinking there is no water and not starting the pump when required.
You should be able to locate the parts in these diagrams.
KENMORE ELITE Washer Parts Model 11049962600
Sep 20, 2014 | Washing Machines
Kenmore Elite HE3 Error FH I forgot to turn the water hoses on when I started a load. The FH error sounded at 33 minutes of a 45 minute cycle. I can't reset the machine now. It is stuck. It is unplugged....
according to kenmore, you should press the "pause/cancel" button twice and it should release it.  it may also have locked up the CCU, central control module and might need to be replaced.
Aug 02, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 front loader F-11 and FDL codes
yes!! the F/11 is triggered under high voltage conditions like high speed spinning. The part is called the MCU motor control unit. if it goes into failure while using your machine and locks the door, just wait 3 minutes and the door will unlock after the MCU resets. Try using you machine with a low speed spin for awhile.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
Help! Mt Kenmore Elite Quietpak2 HE3 keeps
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Mar 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washer machine problem.
Hello noemystotler
You said,
On the last spin cycle water, never stops keeps spraying. Triede different cycles same problem I even disconnected machine in same problem.
sounds like the timer is not progressing and is defective!
Aug 03, 2008 | Kenmore Elite HE4 Electric Dryer
Shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Jul 28, 2008 | Kenmore 44072 Front Load Washer
Kenmore Elite HE3 washer keeps filling with water
The inlet valve will need to be replaced. Its a fairly simple procedure and a pretty inexpensive part.
Nov 15, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
1,191 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
