Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Follow-up... Mr. Mike, Thank you for your response... I tried defrosting the fridge, and came to the point in which i have to check the fan and it is working. I turned the fridge side switch all the way to off to see if the fan will come off but it did not turn the fan off. I am not an electrician, so is there any suggestion on what else do i have to check? I really do appreciate any info that you can give me... Again, thanks in advance... Rowel
    Genius:
  • 1,122 Answers
Set the temp.setting back to where they where,pen freezer door and find the freezer door button,push that in and see if the fan goes off,mike
Posted on Jun 28, 2008
  • MIKE major Jul 03, 2008
    no i said open freezer door and find the door button and push it in to see if the fan goes off,let me know-mike
I have a GE Profile freezer on the bottom refrigerator model #PDS18SBMARBS. A fan was runnining on the inside of the fridge seemed to be between the fridge and freezer. It was very loud and now does not...
Could be a bad fan motor. A bad defrost part or a bad control board.
Check for ice buildup on the back wall of the freezer. If so you have bad defrost parts or a bad control board.
Enter your model number at www.appliancepartspros.com to find the exploded view to dis-assemble the freezer. You can also order parts from them.
Aug 20, 2011 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Freezer works but fridge remains warm.
The same fan that circulates air in the freezer also blows air in to the fridge. If you open the freezer door and hold the door switch closed you should hear the fan running. If not you have a failed motor or motor control. Look at the back wall of the freezer section and see if there is a heavy frost build up. If so. you have a defrost system problem. Please post back with what you find and with the complete model number and I will try to walk you through the steps of checking everything.
Thanks/Mike
Oct 27, 2007 | GE GSS20IEM Side by Side Refrigerator
My bottom freezer gets cold but the top part (fridge) does not. Why? I have an older first addition style
Its defrost problem.When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
May 19, 2011 | Amana ABB1927DE Bottom Freezer...
G.E. Bottom freezer evap drain keeps freezing up and ice build up stops fan so no cooling in fridge compartment. How can this be solved?
When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Feb 22, 2011 | Refrigerators
Freezer cold, fridge part cold at first then warming
hi friend
it is fan problem check it....it may also be a thermostat not working proper,,check them both ,
thank u,,,,,,,,
May 03, 2009 | Estate TT18TKXKQ Top Freezer Refrigerator
Kenmore fridge side by side keeps freezing up
defrost problem,check,freezer fan,remoce freezer back panel,check heater,find and check defrost timer,most are in the frig.if it is manual put it in defrost then check to see if the heater ib the freezer comes on,if it does then you have a bad defrost timer,if not,the freezer heater or terminater(attached to coils)is bad,chevk with your meter,let me know-mike
Feb 03, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge freezing up on back wall of fridge not defrosting
is freezer fan working?remove freezer back wall put frig. in defrost,watch freezer to see if the heater is melting the ice,if not wait 20 minutes till freezer out out of defrost and fan comes on,if it does you have a bad heater and bimetal switch (the little silver round thing clipped on coils,let me know-mike
Sep 22, 2008 | Refrigerators
Troubleshooting defrost system failure on Amana Fridge
YES YOU GOT IT,IT'S THE BOARD BECAUSE EVERYTHING ELSE CHECKED OUT GOOD,BOTH FANS,HEATING ELEMENT,DEFROST THERMOSTAT,THE ONLY OTHER THING I WOULD DO IS TURN THE THERMOSTAT OFF IN THE FRIG.TO SEE IF THE COMPRESSOR AND FANS TURN OFF,WAIT 3 MINUTES AND TURN IT BACK ON, IF THAT CHECKS OUT THEN IT HAS TO BE THE DEFROST TIMER,LET ME KNOW-MIKE
Jul 02, 2008 | Amana Refrigerators
My side by side fridge, fridge side is feezing up...
HI,GOOD JOB CLEANING THE COILS IT HELPS ALOT,MOST TIMES IF YOUR FREEZER SIDE IS FREEZING UP THERE ARE 5 THINGS TO CHECK,WHAT MAKE,MOST GE HEARTERS GO BAD FIRST,EASTEST TO CHECK FIRST IS THE FAN,OPEN FREEZER DOOR,IS THE FAN RUNNING,SOME MODELS YOU WILL HAVE TO HOLD THE FREEZER BUTTON DOWN FIRST,MOST ON INSIDE TOP,NEXT REMOVE FREEZER BACK PANEL WALL,IF YOU SEE A SHEET OF ICE,YOUR DEFROST HEATER(ON BOTTOM OR SIDE) AND THE HEATER TERMANATOR(LITTLE ROUND CLIP ON BALL WILL HAVE TO BE CHECKED WITH A OMES METER,YOU CAN DEFROST IT WITH A HAIR DRYER,WHEN DEFROSTED YOU CAN SEE IF THE DRAIN(MIDDLE BOTTOM OF FREEZER IS CLOGGED,LAST DEFROST TIMER(TOP FRONT,BACK BOTTOM,INSIDE FRIG.TURN CLOCKWISE SLOW TILL YOU HEAR A CLICK,SEE IF FREEZER FAN WENT OFF,WAIT 25 MINUTES,SEE IF FAN COMES BACK ON IF SO IT'S NOT THE TIMER,LET ME KNOW WHAT YOU FIND AND I WILL HELP YOU FARTHER-MIKE
Jun 21, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer Working, but Fridge side is not cold.
ou most likely have a defrost problem is there a large build up of frost in the back wall; of the freezer??
Jan 26, 2008 | Frigidaire FRS26KF5C Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
47 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
