Question about Sony DVP-CX985V Multi-disc DVD Player
Wont feed Rotates but won't feed
I have a solution for this, remove the hulky black cover and watch how the plastic white wheel will now finally hit its full rotation point and start playing the movie. if you place the cover back on, the until will revert back to rotating left and right and not make any progress. keep the cover off the unit
and keep it away from any heavy dust, it should work properly... good luck
Posted on Feb 28, 2009
    Genius:
  • 1,142 Answers
Hard reset the unit and then see what happens
Posted on Jun 25, 2008
  • Maanita Chadha
    Maanita Chadha Jun 25, 2008
    You might need to open the unit and clean the dust on the lens using a damp cloth.
Digital timer stuck on 10 min.won't start the spin cycle
I know this isn't the solution you were hoping for but here is the manual for your machine:
http://www.samsung.com/ca/consumer/home-appliances/washers-dryers/washers/WF203ANW/XAC-supportforward
You say it rotates L & R...do you mean it agitates but the timer isn't advancing?
Dec 30, 2012 | Samsung WF203ANW Front Load Washer
Singer 507 sewing machine - material wont feed through
if the fabric won't feed thru then there is something wrong with the feed dogs
May 25, 2012 | Singer Sewing Machines
Sewing machine wont stitch in reverse, needle hitting bobbin feed.
since the needle is hitting the bobbin feed it has to be replaced, if the machine continues to hit the bobbin feed the most likely the machine is out of time & has to be retimed at a sewing machine repair shop
they would also be able to see why the machine won't stitch in reverse
Mar 31, 2012 | Brother XR-65t Mechanical Sewing Machine
My PC is not starting what is problem.
first make sure your ac cable is working well, then try to check the power supply of your computer if the fan rotates every time you hit the power button of your cpu, if not then change your power supply. if it fan rotates and stops, try to used another power supply if fan rotates and still won't display open up your cpu try to check if the fan over the processor will rotate and still don't recieve display. try to remove the video card and memory and clean it and re insert it. if still don't work. you got your motherboard defective.
Jul 10, 2011 | Intel SRMK2 Motherboard
My canon D761 copier does not feed paper. message says "paper jamed" but there isno paper jamed.How do I fix this
paper jam lit when jammed or feeding does not occurs, try cleaning the feed rollers and look if the feed rollers rotates when you copy
Mar 19, 2010 | Canon imageCLASS D761 Copier
My ML1210 has stopped feeding paper, any ideas what's wrong. The feeder rotates it just doesn't pick up the paper. Its a fairly low mileage machine albeit about 5 yrs old
the paper feed rollers inside the machine need cleaning... take the unit appart and clean them with a clean and rubbing alcohol...
Dec 21, 2009 | Samsung ML 1210 Laser Printer
Canon pc 940 no paper pick up and a signal of P in the display panel
You may have a blockage in the paper feed path, or a worn out paper feed roller, or a faulty paper feed drive clutch / drive mechanism.
Can you see if the paper feed roller rotates in contact with the paper?
Are you using plain paper?
Dec 07, 2009 | Canon Office Equipment & Supplies
I cant print,scan & copy
try reinstalling the drivers and/or replacing the cables. Also look for any debris or tiny piece of paper that may be stuck between the rollers..
May 09, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Problem with trac feeds
When you drop the feed dogs on most modern machines they do not return to the up position until the motor rotates one full turn. Your feed dog will then be up and ready to use.
Dec 28, 2007 | Sewing Machines
Sony DVP-CX985V Multi-disc DVD Player Logo
63 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
