Question about Car Audio & Video
Unlock code for chevy s10 - Car Audio & Video
    Genius:
  • 1,665 Answers
Please contact to a nearby chevy dealer.
Posted on Jun 25, 2008
Had to recently replace battery. now I need the code to reset radio.
GM Delco Radio Lock Out - Forums - Car Review
forums.carreview.com/showthread.php?1839-GM-Delco-Radio-Lock...
Sep 29, 2005 - 25 posts - ‎14 authors
2000 Chevy S10 pickup, battery died, replaced, radio now locked ... Does one haveself service cheaper options to get the code and ... Note: if the display does notchange from "LOC" to "000" the unit is ... Recently I noticed that the led was flashing indicating that THEFT .... I had the same problem as you.
How can I find the unlock code to a Chevy S10 radio? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Feb 24, 2008 - The radio display changes to SEC Your radio is now "un-locked" and usable. ... Source(s): find unlock code chevy s10 radio: https://tr.im/o2Hg7 ... that youhad to disconnect the battery and you need the code for the radio. ... to have it reset, which could mean replacement of the microchip that stores the info.
Aveo factory radio unlock code- DEALERS CAN'T HELP ME! - Car ...
www.automotiveforums.com > ... > Chevrolet > Aveo
Jan 13, 2016 | 2002 Chevrolet S-10
1998 S10 Chevy stalls after it warms up while driving.Replaced ignition switch did not solve problem.Have had it to 3 techs still no solution. Any ideas need help. Thank You
Is your "Check Engine" light on, Gregory? If so, have someone get the error codes from the truck's computer with an OBDII scan tool - that should point you to the problem.
If none, then check the fuel pump pressure and flow rate at the fuel rail with the engine warmed up, immediately after a stall.
Aug 06, 2014 | Ipcw Chevrolet S10 / S-pu 1998 1999 2000...
Unlocking the theft deterrent feauther after a power loss
The code may be on a label on the rear of the radio or nearby.
Apr 03, 2014 | Thule 2001 Chevy S10 Pickup - Extended cab...
99 Chevy S10 Blazer that seems to start in second gear
run fault codes to check for servo/ solenoid problems --TCM faults
Jan 28, 2014 | Cars & Trucks
BATTERY WENT DEAD AND RADIO IS IN LOC MODE CAN YOU HELP ME CHEVY S10 PICKUP 2000
YOU SHOULD HAVE THE LOCK CODE ON A SMALL CARD THAT CAME WITH THE TRUCK POSSIBLY WITH OWNERS MANUAL OR IN YOUR GLOVEBOX. IF NOT YOU MUST REMOVE THE RADIO AND RETRIEVE THE NUMBERS ON THE BACK OF THE UNIT AND CALL A CHEVY DEALER TO GET THE CORRECT CODE TO UNLOCK THE FUNCTIONS.
Sep 05, 2009 | Car Audio & Video
How To Unlock A 200 chevy s10 Radio
I will need the calibrate numbers to decode it for you
turn on key and press the buttons 2&3 together for about 5 seconds. a 3 digit code will show write it down then within 10 sec press am/fm button and another 3 digit code will display write it down. I can use this 6 digit code to get you your 4 digit unlock code.
Aug 30, 2009 | 2000 Chevrolet S-10
Chevy s10 2002 starting problem doesn't idle very
check the idle sensr, also buy an scan tool, check the code, a sensor or too are bad
Jul 28, 2009 | 2002 Chevrolet S-10
Chevy 1996 s10 pedal position code?
Another name for it is throttle position sensor. It is usually on the side of the throttle body, usually black in color, has a 2 wire connection, attached with 2 screws. Needs replacing.
Mar 16, 2009 | 1996 Chevrolet S-10 Pickup
91 chevy s10 junk
did you try changing the fuel filter or scanning for codes? This would be a great place to start.
Mar 12, 2009 | 1991 Chevrolet S-10 Blazer
Car Audio & Video Logo
81 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
