Question about ValuSoft MasterCook Deluxe 9.0: Windows
MASTERCOOK OWN MASTERCOOK VERSION 6.0. IT IS BROKEN!!! SO I WENT AND BOUGHT MASTERCOOK VERSION 8.0 AT STAPLES. THEY SAID IT WAS THE LATEST VERSION! HOW DO I TRANSFER ALL MY RECIPES FROM VERSION 6 THAT I HAVE ON MY COMPUTER TO VERSION 8
  • Brad
    Brad May 11, 2010
    This solution im going to offer is a test and might not work. Try it. im sorry if it doesn't work i am just trying to help. normally i wouldn't offer my knowledge on something i dont know 100% but ima try.
    IF the recipees are the same format from v 6 to v 8 you might be able to do a drag and drop method to +add them into the new programs recipee book.
    Inorder to do this you need to understand how ROOTS work. (where a file is located on your hardrive and have to find it if you now skip this)
    EXAMPLE
    C:\Program Files\Master Cook V6\Data\Book\######### . %%%
    this Root indicates a path on your "My Computers" Menu.
    the root is C:\ (a Hard Drive) Program Files (a Folder) Master Cook V6 (a Folder) Data (a Folder) Book (a Folder) ###### (a recipee name) %%% (the extension type that we have to see is compatable)
    Your programs root path may be different than this (it will be diff after mastercook v6) may be different than shown above its just an example of how you
    might navigate to find them I dont know where they are. if you have a shortcut to the program you may be able to right click and go to properties and see the root as well there may be a button labeled Find Target.
    Your root might not even be named Master Cook v6 it might be named the parent company who produce alot of software (uggg lol)
    once you do locate the Root its easier from here. You have to meticulously check each folder inside the root to find where the recipees are :( its boring and tuff and can be daunting but take your time and like i said one by one (start with files like data or book or recipees lol). Once you find a folder that you suspect holds all your recipees test it out. go into the software if you have to create a *dummy recipe* name it something obvious (try all capitols? if you noticed the suspected recipee file was alpha numerical name it a number or two first then 3 or 4 a's ex 01aaaa this would vault it to the outside of the folder mostlikely top or bottom :) if the dummy recipee you made shows up in the folder (after closing it or backing out one folder then going back it after its been saved in MC 6) then youve succesfully found the saved data of your recipees. try and notice how many files were added when you added 1 recipee hopefully its just 1 if not this is going to get harder (you would need to identify what comprise 1 save (this might require removing and storing all your recipees out of the software for a monent (just drag it out and make a new folder with the same name in its spot) (then make a dummy recipee again and see how many files were created ** Make sure the saved dummy recipee isnt being accessed by the software when your doing this or you might drag an extra file with you (usually invisible maybe jsut translucent) now that youve identified what one file is you might as well just leave those other files out there (where ever you dragged them to *****NOT INSIDE THE SOFTWARE FOLDER MAYBE YOUR DESKTOP?******
    then using the above mention methods locate the v8 root and the saved recipees in there move them to different location than your other recipees as they may have the same name for those folders (prepare a new folder on your desktop open it and drag the v8 saved recipees into that because its now in desktop\new folder\recipees\ and the names dont conflict
    now that you have NO recipees in v8 try dragging what you determined before to be 1 full saved file (hopefully one file maybe more) (note in extreme cases you may have to extract information from mutliple folders for 1 save :(
    now load up the software v8 and see if it can open it it should show either nothing at all or the dummy recipee.
    if the dummy recipee is their then the folder you took from v6 can be assimilated into the v8 software (as long as the names of the recipees dont interfere with the names in v8 (probably not but you could add them one by one and if there is an overwrite prompt then say no and rename the file and try until sucessfull)
    if the dummy recipee is not recognized replace the v8 recipees back into thier respective places and do the same for v6
    the only thing that i know of that can be done now is go and get v9 that ive heard is out that has a utility to assimlate various versions recipees for v9 (check to see how many versions back this assimilator is good for.
    GL
    Brad
    To test to see if the "extensions" or "file types" are compatable we can do a couple things
  • 99 Answers
Removing Clutter from work que and and forumn boards
Posted on Apr 10, 2009
When I try to open a cookbook I get a dialog box saying Unable to create view: 'cbks'-'open'
I started receiving this same message today also. In addition, when I do a search by ingredient in the Search feature and try to open up the recipe I get the same message with the words 'Rcpe' - 'open' instead of the 'Cbks' - 'open'
Aug 06, 2013 | ValuSoft MasterCook 11
Hello, A while back I bought A Memorex DVD Writer. Well, I also owned a copy of Nero 6 with all the other software like wave editor, and others that came with the program. Well, when I went to install my...
You cannot install several different versions of Nero Burning Rom on one PC system. You can only install one only. This is because of software conflict on your system from different versions. Best is to install the latest or newer versions ie. if your Burner drive support the newer functions on the software or your operating system is compatilbe to which versions.
Hope it helps.
Nov 09, 2010 | Ahead Software Nero 7 Essentials Suite...
I have the cosmi 20,000 recipies perogram in my old computer and the hard drive went out. I got a new Acer with Windows 7 and cannot get the old disk to load. The former computer was running Windows XP...
i think u are probably out of luck. this software looks like it came from the late 90s and will work with anything up to xp, but vista & win7 are a whole different ballgame. best solution, buy an old laptop with win98 or 2000 or xp super cheap on ebay, or beg one from a friend, and use ur software on it there in the kitchen. that's what i do with my old laptop. works great if u have room in the kitchen lol
also transfer ur fave recipes from 20,000 recipes to a recipe organizer program like mastercook, it's much much better for searching plus u can enter 1000s of new recipes from anywhere. u can get older versions of mastercook for $5 on ebay. version 8 works just great for me with winxp. (WARNING if ur interested in mastercook on ur NEW computer, get version 11, the older ones DON'T work w/Vista or win7.)
Jan 22, 2010 | Cosmi 20,000 Recipes with Party Planner...
I cannot open mastercook 5 without getting this error when trying to open. I am using Windows 7 64 bit.
Hello and thank you for using Fixya's services.
Unfortunately, Mastercook 5 is not compatible with Windows 7. There may be a work around but the only work around I found was for Mastercook 9.
From what I understand, it has been difficult for many to install Mastercook 5 & 6 on Windows Vista.
I did, however, included a link to MasterCooks blog in hopes that it can assist you with a work around.
Maybe the work around for MC9 in W7 will work for your version?
http://mastercookinwindows7.blogspot.com/
Hope this helps and please let me know if you have any questions.
Dec 04, 2009 | Vivendi Mastercook Cooking Light 6.0 Full...
Error when installing mastercook 6 on my vista laptop
hi there.
mastercook 6 runs on older windows versions
like win95, win98 and win Millenium Edition
only, newer are not supported.sorry
MasterCook deluxe 9.0 supports win2000, XP and VISTA, but this would mean spending another 19.99 on amazon.
you could try to install the 6.0 version on an older machine that still has win98 on it or think about setting up a multi-boot system (u need some computer expertise)so you can install multiple operation systems on your laptop, but this takes a lot of effort and all the drivers for your computer for win98, so spend of whatever you have more of, time or money...
good luck!
Aug 07, 2009 | Vivendi Mastercook Deluxe 6.0 (71052) for...
Wanting to upgrade old Mastercook program to meld to new computer
ValuSoft says that MasterCook 9.0 is only supported in Windows 98-XP. Specifically not Vista compatible. What's wrong with these people? I have Vista and didn't realize until tonight that some of MasterCook doesn't work right. So, buy XP.
Jan 15, 2009 | ValuSoft MasterCook Deluxe 9.0: Windows
ValuSoft MasterCook Deluxe 9.0: Windows Logo
679 people viewed this question
Top ValuSoft Computers & Internet Experts
Mike
k24674
Edwin
Are you a ValuSoft Computer and Internet Expert? Answer questions, earn points and help others
