Question about Insignia Bluetooth Wireless Behind-the-Head Headphones - Black
Microphone doesn't work
The microphone won't work while the headset is on stereo mode and only if linked with a phone. how do i get the mic to work for gaming?
  • cjenkk Dec 30, 2008
    The mic doesnt work on the computer. Works on my iphone and I can hear the other person, but they can't hear me.
  • arebmann Jan 07, 2009
    i can pair my headset to phone and computer however the mic doesnt work on either.
For some reason, these types of headphones don't like to work in both A2DP Stereo headphone mode and headset profile. I know that every computer I've dealt with thus far sees both profiles as two separate devices, and since the mic is tied to the headset profile, the mono audio comes with it. Simply put, I'm not sure that there's a way to use both on a computer. I'm also pretty sure that most phones toggle between profiles when applicable. Best I can guess is that the problem is hardware related, not software.
Posted on Mar 22, 2009
Ac-648 mic not working
Either you have connected to the wrong socket on your computer, or the controls on your computer have not been set up. For example the microphone circuit is switched off or set too low for recording.
Jul 12, 2013 | Cyber Acoustics AC-648 Headset - Stereo...
Skype not working
Sir,
Click this link for more information........
http://support.skype.com/index.php?_a=knowledgebase&_j=questiondetails&_i=35
Also Check........
On a PC with external speakers and also a headset with microphone. Windows XP is configured so that standard audio are external speakers and standard microphone is the headset. Skype is configured to use the headset for audio in and out.
This way one can listen to sound from the PC and from MP3 players through external speakers and if there is a call to make or take, this is going through the headset.
But now there is the problem that the noise level for the headset is too low. Increasing volume has no effect on the headset, it only affects the external speaker's volume.
Now the solution: Going to the control panel and opening the sound setting, go to the audio tab. The external speakers are selected as default. Just temporarily select the headset and then click on volume just below. You can now set the volume for the headset, click OK and click cancel (!!!) on the sound control dialog box. This way the external speakers remain as default output.
Skype-->Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Windows:
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard(AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
thanks
good luck
Oct 29, 2008 | Altec Lansing Stereo Headset with...
I bought a samson se50 headset microphone to go with my GTD Audio wireless system. It has the correct adapter plug to plug in to the transmitter. The plug is a mini XLR plug. The microphone does not...
You need power from the transmitter to power this mic. See your mics specs to determine if it needs "Phantom Power"
Perhaps the transmitter doesn't supply power. Condenser mics may not work. Stay with the dynamic type. IMHO
Jul 29, 2010 | Nady Systems Nady ATM-75 Headset Mic w/...
Clear chat mic doent work
in skype go to tools>options>audio setting make sue the microphone is logitech and the green bars should start moving as you talk.
if no logitech appears or the mic is not producing sound. call logitech for warranty info. if the mic is producing sound below is "make a free skype test call" to see if the program is transmitting.
Jul 18, 2009 | Logitech ClearChat Stereo Headset Headset
My mic is recording sound from the headphones, NOT the mic piece, why is this?
-right click on the volume icon on the system tray and select recording devices
-there should be a selection that says stereo mix or something like it
if not.. right click on a blank space on that box and select "show hidden devices"
-you must disable this device
-make sure your microphone jack is enabled
-click apply and it should work
Apr 12, 2009 | Microsoft LifeChat Stereo Headset with...
Dont now how how to use them
my head phone is working but my microphone does not, there are two cord one is red and other black, when i plug black its fine for head phone tell about red cord
Jan 02, 2009 | Microsoft LifeChat Stereo Headset with...
Dynex Stereo Headset w/ noise canceling mic: Headset Won't Work!
More than likely it just burned out or the battery is defective.
May 19, 2017 | Dynex Stereo Headset with Noise-Canceling...
Logitech headset
it is due to mic problem
1. mic cable may breaked
sol. check cable
2. other wise ur pc mic supporting software is not properly added
sol. if u r using windows xp, double click the volume icon ( located on ur desktop startmenu bar) click options, properties,
recording, and check the microphone then click ok button
check and select the microphone button and increase the volume and check it
3. check sound functions, some times ur software used in voice cancelation mode change mode.
Dec 31, 2007 | Logitech Precision PC Gaming Open Air...
Microphone not working
maybe its a problem with your sound card. Check your microphone settings in Windows.
Dec 11, 2007 | Altec Lansing Stereo Headset with...
Microphone not working...
well, first time i installed mine i didnt plug the mic in all the way. it seems like it's in but ti's not, you have to give it an EXTRA push. try that.
Oct 07, 2007 | Kenwood KCA-BT100 Wireless Headset
Insignia Bluetooth Wireless Behind-the-Head Headphones - Black Logo
1,036 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
