Question about Vivitar 2800 Flash
I'd like to know if I can use a Vivitar 2800 flash in a Nikon D80 safely. I've been using it, without any problem, but read that maybe this flash can be dangerous to the D80 and I want to be sure. Thanks.
    Problem Solver:
  • 14 Answers
Yeah Rolo, I read that too. I would put a slave unit on your Vivitar, and the Master would be the pop up unit on the camera. Not only will you save risking your camera with the voltage of the flash, but your pictures will be better too. I use Aperture Priority on the camera and AUTO on the Vivitar set to the same aperture
Best regards,
John
Posted on Jul 15, 2008
Can I use the Vivitar auto thyristor 2800 on my Nikon D3000?
If it's a 2800D then it's probably safe. If it does not have a D after 2800, then measure the trigger voltage on the flash contacts with a voltmeter. If it's above 8 volts it will fry the camera. It's not TTL so it doesn't communicate with the camera. You'll have to shoot Aperture priority to get proper exposures
Aug 05, 2013 | Vivitar 2800 Flash
I have vivitar 2800 flash for my pentax can i use it with Nikon D70s
If there is a D after the 2800 you're probably safe. The trigger voltage is 8 volts so to be sure, find out what the upper limit of trigger voltage the camera can safely handle. If there is no D designation in the model number it will definitely fry the Nikon
Mar 14, 2013 | Vivitar 283 Flash
Can I use a Vivitar 850AF C with Nikon D80?
Yes, but only if you isolate it using something like this. Do not use it directly on the camera's hot shoe, as you're liable to fry the camera's circuitry.
Jun 02, 2012 | Vivitar Cameras
I got a DSLR Pentax K-r digital I would like to know if I can use my old Vivitar flash 2800
No. The trigger voltage on the 2800 is much too high, and will eventually fry a digital camera. You can use it as a slave, or isolated from the camera with something like a Wein Safe-Sync.
Jun 01, 2011 | Vivitar 2800 Flash
How to use vivitar zoom thyristor 285 with nikon D80 digital camera
DO NOT ATTEMPT TO USE THIS FLASH ON THE CAMERA OR TEHTER BY WIRE. THe voltage will destroy at least the built-in flash function of your camera. either use a radio slave, an optical slave or you can use it on camera if you use a WEIN safe-synch (approx. $70 USD). If you do not have the users guide for the flash, it can be GOOGLED. Search for "VIVITAR 285 users guide"
Dec 14, 2010 | Nikon Cameras
Using a vivitar 2800 flash on a nikon d60
The old series Vivitar 2800 flashgun has a very high trigger Voltage, that can damage your D60's circuitry. Even measuring the trigger voltage with a voltmeter is not a solution since you can't rely on the voltmeter to indicate the peak voltage.
Feb 05, 2009 | Vivitar 2800 Flash
Vivitar 283 with new Nikon Digital camera
the nikon D80 has a 250 volts safe range and i have the same issue but readin on the internet i learned that yo can now the voltage of your flash with a voltage metter ond the hot soe.
Vivitar 283 has diferent ranges of voltages depending on the year of fabrication so older ones can achieve 300 volts and earlier have 230 volts so the best is to get a vivitar 285hv for about 75dollars or a safe sync for about 55dollars, you can find all on ebay or other brouser the safe sync converts up to 400 volts to a safe 6 volts that are yust the normal voltage for digital flashes.
Jan 06, 2009 | Vivitar 283 Flash
Nikon D80. Vivitar 4600 Flash unit
That particular unit is probably not a good choice for the D80 because the trigger voltage (the electricity which flows from the flash through the camera circuits to fire the flash) is 19.5 volts, according to http://www.botzilla.com/photo/strobeVolts.html - this could possibly damage your camera electronics.
You don't have to stick with Nikon brand Speedlights, but get a modern flash which says it is I-TTL compatible for Nikon.
Jan 01, 2009 | Vivitar 850AF for Nikon TTL Flash
Vivitar 2800 Flash Logo
496 people viewed this question
Top Vivitar Cameras Experts
Tony
SHARCNET-USA
SHARCNET-USA
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
