My projection HDTV is showing two pictures of image red and blue
The image that I see on my magnavox HDTV wide sceen is two images with red and blue coloers.
  • jessehughley Jun 25, 2008
    Model#0003784994452_500x500x500-42.4KB MAGNAVOX 51"WIDESCREEN PROJECTION HDTV MONITOR.
  • jessehughley Jun 26, 2008
    off the back of TV:MAG1AA
    255WATTS
    60HZ
    120 V
    TX FCCID
    MODEL#51MP392H/17
    SERIAL#YAIA0438025173
  • 8,617 Answers
You need new convergence Ics . Please respond ti this post with the model number and I will post the correct ICs for your model as well as where to get thrm with free instalation instructions with pictures so you can do the repair yourself.
Posted on Jun 25, 2008
  • Sonny Berry
    Sonny Berry Jun 25, 2008
    Thats not the correct model number . It should start with 51 or 50 followed by numbers and letters it should also have a chassis number such as MAG01
  • Sonny Berry
    Sonny Berry Jun 26, 2008
    Okay you will need two Convergence ICs STK3920120 and 4 6.8 ohm 1watt resistors and your set will be fine again. You can get the replacement Convergence ICs and resistors at the following link and they provide free instalation instructions with pictures so you can do the repair yourself and save about 450.00. the parts are very inexspensive. Heres the link.
    http://servicemanuals.vstore.ca/
Image is green color............what is wrong with the tv?
It means that the blue and/or red picture tube (bulb) is not working properly. It could be the tube(s) or the circuits that drive the tube. My money is on the circuits.
Apr 22, 2010 | Philips Magnavox 51MP392H Rear Projection...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
Philips 55P8288A tv has a dull color and a red hue.
This sounds Like the the coolant for your piture tube has become cloudy and needs replacement (usually blue or green tube - thats why the image seems ovrely red).It's a big job (labour wise) since completee dissassembly is required ($200-300). It can be done youreself - check out TVrepairkits.com to get the coolant and instructions.
You can confirm that this is the problem by dissassembling the unit to the point where you can view the face of the CRT's (red green and blue) directly.
Nov 28, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Picture has red and blue shadow images
thats a fairly easy fix. You need the DPTV305-DPTV345 convergence repair kit available at the following link.
The kit contains the parts and the CD with instructions
Sep 29, 2009 | Philips Magnavox 51MP392H Rear Projection...
Only red tube shows picture, but green & blue are on, just no pic
More likely the problem is the blue and green fluid in the tubes is so cloudy that its distorting the image. Get a fluid kit from www.tvrepairkits.com
Jul 29, 2009 | Philips Magnavox 9P6034C 60" Rear...
I have a red and blue shadow in my picture
i think you need a new convergence board they rin from about 88.00 to about 140.00
Sep 08, 2008 | Akai PT5598HD 55" Rear Projection...
TP55F80/81 55 in
no mater what I say you will need a tech, is note that you dont have experiece with this tv, so let the job to a tech, is better for you...good luck
Aug 09, 2006 | Toshiba TP55F80/81 55" Rear Projection...
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Electro Med Services...
