Question about Canon ImageClass MF5770 Laser Copier Printer Fax Scanner Network
Canon MF5700 Series all in one printer
Alarm light goes on. Check the paper size. I did everything right and does not print
  • Anonymous Jul 21, 2008
    check paper size and jams on request to print
  • Anonymous Nov 05, 2008
    I have a message that blinks "Check paper size"
Throw it in the trash. It's a piece of shi*. I'm sick of mine.
Posted on Sep 18, 2008
The paper size in your word processor is set to legal and you have letter size in the printer. To fix this first change the paper size in your word processor program to what you are using in the printer. Then clear the print jobs in the printer the procedure is explained in the printers guide you can download the guide pdf from cannon.
Posted on Jan 23, 2009
Canon LBP 3300 printer A4 Paper is already loaded in Cassatt 1 but "Load custom paper in manual feed slot" massage shown when given print comment
these instructions r for win xp
go to printers and faxes select canon lbp3300, right click and select printing preferences set out put paper size as A4.
Apr 16, 2011 | Canon LASER SHOT LBP 3300 Printer
How to print A5 paper incannon 3300?
Go to printer and faxes, right click, printer preferances, page setup ,size , select A5 then paper source select casste 1. then click ok. Feed the paper through cassete 1. Print ready
Apr 03, 2011 | Canon LASER SHOT LBP 3300 Printer
Canon MF5700 Printer Error says "Check Paper Size" and won't printHow do I fix this?
thanks for contacting in fixya
u need to switch off ur printer and again switch on if this problem persists then let me know
regads
john symester
Nov 03, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Red alarm keep coming to my (Canon imageCLASS MF5770 Multifunction Printer) and display message: CHECK PAPER SIZE AND CHANGE PAPER SIZE CASSETTEL LTR. please guid me through steps. thanks!!
Chances are the paper size in the cassette doesn't match the paper size (or alignment) that you've tried to print. Verify the paper and alignment of the paper match what you're trying to print, and that the paper guides in the cassette are locked into position for the size and alignment you're working with.
Aug 05, 2009 | Canon imageCLASS MF5770 All-In-One Laser...
Have canon mf5700 says check paper size. Powering off doesn't help Changing trays does not help. After powering on again it prints a test page and then gives the warning again.
You need to remove paper tray, and unplug canon. Leave it this way overnight, and in the morning, reinsert the paper tray, and plug back it. This should effectively reset the machine, and clear that error. It worked for me!
Mar 06, 2009 | Canon Office Equipment & Supplies
Problem in canon
i found a solution for printing with Canon MF 3110
1- Download Driver For MF5730/5750/5770 For Vista 64-Bit
File Name : L7602ENx.exe
http://software.canon-europe.com/products/0010260.asp
Follow These Steps
1- Add Printer
2- add a local printer
3- Use an existing Port : Choose : USB ( Virtual Printer for USB )
4- Have Disk
5- Locate the File Name : MF5700AK.inf
6- Printer Name : Change From Canon MF5700 Series To Canon MF3110 Series
7- Print Test Page
it Work for me on Vista Home Premium SP1 64-Bit
P.s
still Cant Manage to use the Toolbox 4.9.1.1.mf04 for Scanning ( Any Ideas ? )
Oct 22, 2008 | Canon MF3110 All-In-One Laser Printer
Have canon mf5700 says check paper size and only prints one page of several page job
go to control panel> printers> and make sure in preferences its set to LTR (letter)
Hope this helps
Dec 21, 2007 | Office Equipment & Supplies
Alarm light is on it says( check paper size) this is a canon mf57700
I had this problem also. I was unable to clear the paper size error. Finally I loaded the papersize that the printer was wanting (A4 in my case) and let it print. Once the print job finished it was back to working normal.
Oct 22, 2007 | Canon ImageClass MF5770 Laser Copier...
If your alarm light is flashing and your printer will not print, press the "copy" button to get the device into the copy mode, once the copy button light is on, press the "Status Monitor" button. The LED panel will then show two lines of words: Line 1 "COPY STATUS" and Line 2 "SELECT JOB TO CANCEL"; then hit the Set button and the screen will show you what print job which has jammed the printer and you then press the - (Minus) button to clear the job. Open and close the front panel and the printer should reset and the warning light go off.
I had trouble locating the problem because my machine tends to stay on the Fax mode and when I pushed the Status Monitor button I would only get information about fax jobs.
Hope you have already figured out the problem. I thought I had better tell someone so I will remember the next time I try to print a job which requires a different size paper than what I have in my printer.
Blessings!
tdocdaws
Oct 16, 2007 | Canon imageCLASS MF5730 All-In-One Laser...
1,388 people viewed this question
old marine
old marine
