Am having difficulty removing Black (96) print cartridge from an HP 7210 All-in-one printer/scanner to enable installation of a new (96) cartridge and need help!
HP 5780 Office Jet printer. Is there a generic or compatible cartridge for this printer? It uses HP 74 and 75.
Posted on Jan 12, 2009
    Brigadier General:
  • 3,614 Answers
On the software on your PC there was a option in the printer setting>> preferencess>> maintenance, which you can select the ink/cartridge replacement..
Posted on Jun 25, 2008
Hp 7210 rinter will not align properly
Hi Melvin,
This could be due to faulty, low ink level or Scanner glass not clean.
Remove the cartridge and Clean the electrical contacts ( tiny golden contacts ) with lint free cloth. Open the scanner glass and wipe the glass for any dust particules.
Turn off the printer ( without cartridges )and turn on. It should prompt you to install cartridges for alignment.
You can also try cleaning Cartridges from Front panel
Press Setup button ( menu button )
Scroll to Tools - Press ok
Check for Clean Cartridges/Printhead - Press OK
IT will clean the cartridge contact and print the alignment sheet which you need to place face down on the scanner glass and press OK
Regards,
Sean
Apr 21, 2013 | HP 7210 OfficeJet All-In-One Printer
I have an HP Officejet 7210 All-in-One. I would like to know if there is any way to print a document that only needs black ink, even though a message always pops out that I have to remove and check the...
Hi
Black is not True black. It is slightly brown.
Printing in black uses mainly black but may also a tiny amount of a mixture of some of the other colours.
To minimize the usage of other colours:
HP Solution Center > Settings > Print Settings > Printer Settings > Color > tick Black Print Cartridge Only > OK.
HP ink can be expensive. It is possible to economize on HP inks in some cartridge formats by using Ink refill kits.
I hope this helps.
Aug 24, 2011 | HP Officejet 7210 All-In-One InkJet...
I am printing an invitation on my HP Officejet 7210 All in One. I am gettting striping in areas which have a lot of solid black. How can I fix this?
From the HP Toolbox on your PC you can run a cleaning page. If that doesn't fix it, or if you are using refilled ink cartridges, it may be time for a new black ink cartridge.
May 02, 2011 | HP Officejet 7210 All-In-One InkJet...
Printer says to insert black print cartridge in right stall
Refer to printer manual as some of them require you to reset the software to accept new cartridge.
Manual here if you do not have one
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Dec 03, 2009 | HP Officejet 7210 All-In-One InkJet...
HP Officejet printer, says cartridges are missing or not detected
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr11
Aug 13, 2009 | HP Officejet 5610 All-In-One InkJet...
Printing blue
Printer defective.
need a new machine.
May 22, 2009 | HP Officejet 7210 All-In-One InkJet...
HP officejet 7210 hortizontal white lines
I would suggest you get a set of original HP cartridges .. I have clients trying to save $ all the time by buying refilled and/or refilling themselves to only go and get HP brand. Refills just don't cut it .. leaks, poor print quality, unrecognized cartridges .. there are so many things that I can point out .. save yourself the hassles .. get HP
Mar 30, 2009 | HP Officejet 7210 All-In-One InkJet...
Recurring "cartridge successfully installed" message
Download the Kyocera Driver Deleter tool from here:
http://drivers.softpedia.com/progDownload/Kyocera-KM-Deleter-281031-Download-18304.html
Run the tool and delete the driver for your HP. Disconnect the printer, then use Add/Remove programs to uninstall the HP software.
Reboot.
Reinstall the HP software and reconnect the printer when prompted by the software install.
After this I didn't get the message again.
Hope this helps!
Mar 18, 2009 | HP Officejet 7210 All-In-One InkJet...
Error C-0012, what do this means?
mhn arahan untuk problem yang saya alami dalam pengoperasian hp officejet 7210 all in one -
problem : kedua tinta hp black print cortridge 96 dan hp color treecolor 97 uda di masukan kedalam kotak atau wadahnya, namun, perintah yang keluar adalah : remove and check color cartridge mhn arahan tks
Feb 11, 2009 | Kyocera Mita KYOCERA/MITA - KM-C3130...
HP 7210 All in one - cannot get new black in cartridge
Check to see if the old one slides in as rough as the new one.
Apr 24, 2008 | HP Officejet 7210 All-In-One InkJet...
55 people viewed this question
k24674
