I hane a Sanyo Model HT32744 CRT HDTV I purchased in April of 05 and for a year now it will drop out the red and green spectrum and the only color is blue and yellow. If I wack the cover it goes back to normal colors. The first time I did this it worked fine for over 3 months but now it is more frequint! I saw some websites that had comments on this problem like cracks in solder connections on the color board that plugs into the CRT and component problem on a PC board. Checked the connections on color board and they looked fine. It sounds like this a common problem with this TV. I was wondering if the PC board creating this color problem is available and where?
  • overyjb Jun 25, 2008
    Are there any more comments before I take it appart again?
    Genius:
  • 2,028 Answers
I found the part number for the board, but unfortunately I couldn't find any for sale on the web. You might try contacting Sanyo directly. Here's the part number, hope it helps.
Sanyo Model HT32744 Main Micro board P/n E22459
Posted on Jun 25, 2008
    Genius:
  • 1,665 Answers
What I do with colour cast problems :-
1) check the voltage (with no aerial signal) on the collector of all three video output transistors (on the crt base) they should be +-5v of each other if one is different, then swap over this transistor with one of the other two and if color changes, its the transistor, If not then I use a 2k-4k wirewound and touch it from each collector to chassis in turn, and watch the screen (I use a mirror) each color should be equally bright with flyback lines, if not its probably the tube (CRT) faulty.
2) If all of tests are ok, then I find the three wires coming up from the the main pcb to the crt base panel and swap over the green/red and see if the color cast changes
If yes then its the chip on the main board, If no its on the crt base board, so check values of all the resistors there.
    Brigadier General:
  • 3,614 Answers
Yes, check for any bad solder on the convergence module..
  • 1 more comment
  • micromaster
    micromaster Jun 25, 2008
    and do a test on the IC, and capacitor, resistor on that area too..
  • micromaster
    let me know..
    kindly rate my solution if this solve the problem..
  • micromaster
    if you don't have any idea or professional background servicing that kind of unit, it was not advisable for you to work on that..
Green Screen on an HDTV
I do not believe there is any easy fix to this. The problem may be either in the picture tube or the related circuitry. The worst case scenario is the tube itself is failing. However, it could be as simple as a defective connection on the pc board at the tube for example. You may want to get a technician to check it out and get an estimate before you buy a new set. Good luck
Nov 25, 2009 | Sanyo HT32744 32" TV
Bad color suddenly appeared on Maganavox 437S 52 " Flat Screen HD
it should have a year warranty get it in for warranty repair before the warranty runs out or someone tells you the wrong thing to go and the tv ends up as a big paperweight...
Dec 28, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Model #
The solder joints on the CRT board might have cracked and cause this symptom. What you are describing indicates that the red gun is intermitten, and the solder joints on the CRT socket itself (red cathode) or the red output transistor have probably cracked loose.
Aug 23, 2008 | Sanyo HT32744 32" TV
Sanyo TV - HT32744
Lower the contrast first.
If colors not in balance, reduce saturation until "normal" to your eye with whichever color (or color pair) out of balance.
Aug 19, 2008 | Sanyo HT32744 32" TV
Sanyo 32" hdtv
CRT socket is the the problem of your tv,so change the socket.it is a white plastic with a 7 or 9 pins that attach to the picture tube
Jul 12, 2008 | Sanyo HT32744 32" TV
TV problem
Sound like either the Red or Blue driver transistor on the CRT board is intermittant.
Hope that helps...
Geno
Apr 03, 2008 | Televison & Video
Sanyo ht32744 32" tv
After reviewing the info with the same tv sitting in front of me.
seems to be a connector problem in the video board that is connected to the crt. the connector between the video board and the signal board. remove this board, inspect the board and spray and clean the connectors. also try to ruffin up the contacts if possible. also resolder connectors, and check crt board for cracks. this is a known problem with these.
please report back if this helps you.
Mar 31, 2008 | Sanyo HT32744 32" TV
Black pic on tv turns green
normally this means the high voltage preamp green control transistor on the neck of the tube circuit board is loose solder connection from heat or is going bad.
Feb 17, 2008 | Sanyo HT32744 32" TV
Sony Digital TV screen colour problems
My sony projection tv seems to be out of focus on all four side.
Aug 02, 2007 | Sanyo HT32744 32" TV
Sanyo HT32744 Picture mostly green and blue
On mine I took the rear cabinet off, unseated the card mounted on the picture tube, applied a little dielectric grease on the connector on the card and reseated the card, removed, re-greased and reattached the card. I have had no problem with either my or mom's which I did the same to since! This is an easy fix that anyone can do. The hardest part is moving the TV and reassembling the rear cabinet. Do not pull the cabinet back out more than you have to, to ease the reassembly of it.
Jun 22, 2007 | Sanyo HT32744 32" TV
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
