Question about Bosch 23 in. SHU3307UC Built-in Dishwasher
Detergent latch install for Bosch SHU3307UC dishwasher
I have a replacement latch and spring, and would like to know how to install it.  I removed the sliding detergent cover, and I'm stuck there
  • Anonymous Mar 13, 2014
    After replacing the drying agent reservoir, the detergent cover will no longer latch closed. I was not paying attention to the orientation of the timer arm and wheel in relation to the power cover arm. Manual says should auto-align but in my case this did not happen. Thoughts on how to re-align the timer arm and the detergent cover wheel?
    Bosch SHE55M16UC/64 Dishwasher replacing control panel fascia or cover. How to remove chrome handle cover from old part and reinstall it?
  • 76 Answers
You need to remove the front panel of the dishwasher. you need to open the door and remove the 6 torx screws on the inside of the door, close the door and lift up and out to remove front panel. you wiil see the detergent assembly there
Posted on Jan 01, 2009
My Bosch shu3307uc pumps out all the water at the end of the cycle, but slowly fills the bottom between cycles, even wuth little or no activity at the sink. have checked the drain hose for blockage, but...
Hello, welcome to FixYa.
Based on your post I understand you have a Bosch SHU3307UC dishwasher, correct ? Firther to this you.ve stated "slowly fills the bottom between cycles, even with little or no activity at the sink"
It sounds to me like the fill valve is at fault unfortunately. This is a very common problem for Bosch dishwashers of that era.
A faulty fill valve...sticking in the "open" position either due to the plunger in the coil getting stuck or sediment inside the valve body impeding it from closing correctly...Either way you're safer to change it with the history of these valves failing.
This is what to look for...
As long as your model is indeed a Bosch, this info below will be accurate.
Original part is # 425458. It usually retails for about $20 - $30USD at places such as "searspartsdirect.com" "repairclinic.com" to name a couple, if needed. They may be available at your local brick & mortar parts depot/vendors.
**Before attempting to repair the unit please turn off the power and the water supply to the dishwasher...safety first**
If you remove the lower kick plate/toe panel, you will see the inlet valve to your left...
i.e.
Replacing it or to check for debris in the filter/screen at the inlet is pretty straight forward. Here`s how...
1) undo the water line. ( here you can visually inspect the screen in the valve...if nothing noted, you'll likely need to replace it as follows )
2) Remove the two #20 torx screws fastening it in place.
3) the feed tube to the machine at the back of the valve and swap it with the new one.
and
Once the new one is in or it's all clear you should be good to go.
Let me know if you need any further assistance. Thanks for choosing FixYa and good luck.
Please take a moment to rate the assistance provided here and a brief testimony on your experience here at FixYa is appreciated as well and tell your friends to look for "Macmarkus" on FixYa should they need asistance as well.
Regards,
Macmarkus :)
Sep 26, 2011 | Bosch 23 in. SHU3307UC Built-in Dishwasher
We have a Bosch SHU3307UC dishwasher. Two friends swear by theirs, saying they put everything in dirty and the load always comes out clean. That does not at all work for us. My wife has to just about wash...
Put dirty stuff in will eventually keep a tech like me very busy. We love to come and charge you alot for cleaning your dishwasher. Remember the Maytag commercials where they put a cake in it? Still got the dishes clean but before long it will cost you big time. Just run everything under the tap. Pot and pans should be lightly washed also. Watch how you place the dishes. Most dishwashers spray up from the bottom. Block it, and the spray will not reach the top.
Nov 28, 2010 | Bosch 23 in. SHU3307UC Built-in Dishwasher
I need to replace the detergent dispenser latch on
To replace the parts you have to buy a whole dispenser assemble for $100 to $200. To buy some time ... Get a heavy gage sewing needle - hold it with pliers and heat it red hot. Stick the hot end into the plastic door at the area where the plastic latch is (where it will line up with the far end of the latch mechanism). when it cools cut off most of the needle leaving one eight to one sixteenth (more or less) protruding. Use a drill and small bit to remove some plastic (or drill a small hole) on the spring latch mechanism. push the remaining part of the needle in or out to engage the hole in the latch.. this will hold awhile.
Jul 19, 2010 | KitchenAid 24 in. KUDP01DLBS Free-standing...
Dishwasher soap lid is not latching. It's free of detergent.
We have the same problem, so I took the door of the dishwasher apart and cleaned it up, reassembled it, and it latched for about a week. Something is worn somewhere, and it's going to be a pain to figure out and replace, so we just bought some powdered dishwasher detergent, and fill the cup and close the door. The water spray will dissolve any that falls out when you close the door, and it does just fine, doesn't leave any residue or undissolved detergent on the dishes, at least with our dishwasher, hope you have the same luck.. If you choose to get it fixed, get an estimate first. Sometimes it's better to just replace, depending on the cost of repair. Hope this helps, good luck.
Mar 25, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Our Bosch SHY66C05 door latch is stuck in locked position
you have to pull back the spring or replace the lock. the repair is pretty easy.let me know what happen.
Nov 07, 2009 | Bosch 24 in. SHY66C05 Stainless Steel...
Detergent holder wont spring open
I suspect the spring is actually broken.
You may be able to order a spring - but unfortunately may only be available as a complete unit.
Try a replacement from Ebay if possible - otherwise order via appliance spares.
Fairly easy to replace - but disconnect from power before attempting to remove door.
Aug 04, 2009 | Dishwashers
Soap dispenser cover won't close
It sounds like it may be stuck between cycle steps.(this sometimes happens if the washer is open during a cycle)Try and run it through one full wash cycle as it is.Then check to see if the soap door will close.If not,the lack may be broken
Jan 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Detergent dispenser spring door is either missing the spring or broken. In any case it opens but is no longer spring loaded. I can't figure a way to remove the assembly unless I have to take off the front...
Door just pulls off, you will require a new door, spring & possibly a catch. Spring fits onto pin on door and other end onto pin on holder, then fold spring on its-self and re-instate onto runners/slide. Paul Winn Appliance Services. (Cumbria)
Apr 25, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher detergent door spring
I ordered and received the new Bosch dishwasher detergent door, but do not know how to repalce it!
Jan 23, 2008 | Dishwashers
Detergent dispenser
The opening of this dispenser is controlled by a wax motor for release. If you are unable to keep the latch shut you are probably looking at the spring and latch assy. This is not a hard job, but you have to open the inner door to get at the latch. Part numbers for the spring disp. flap is 912547. The latch (inside door) is 99001291. If you take your time and observe carefully the job will be easy. Catriver, post back.
Aug 08, 2006 | Magic Chef CDB6100 Built-in Dishwasher
Bosch 23 in. SHU3307UC Built-in Dishwasher Logo
381 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
