Phillips plasma 50pf7320
My phillips plasma has started losing the picture.the sound is there but the screen just goes blank , just dark with no signal coming through.there is a slight buzz then it will come back as though nothing has happened.there is no pattern to this on the time side other than the slight buzz.
cheers
steve
I have a 50 inch phillips plasma and the pixtals are taking over and color is dark the amblight is very dim,
Posted on May 16, 2009
TV loses picture
Sounds like your picture tube or bulb is going out. It depends on what kind of tv ( rp, lcd, plasma) it could also be a component issue.
Nov 22, 2013 | Televison & Video
Phillips 42PFP53320 42" Plasma TV. No picture,
Hello jporter...
welcome here in fixya..
That problem is one of the common problems of plasma TV (have sounds but no picture)..As a expert of flat panel for more than 5 years I already encounter that kind of problem many times..
Actually that problem is caused of either X,Y or Z sustain board or even both 3 boards are faulty..Because some models when the one of those boards have short circuit or bad there are possibility that other sustain board are affected..But most the problem like yours is "Y-SUSTAIN" board..
I can't find your model online please double check it it either Phillips 42PFP5332D/37 or 42PFP5532D/05
And for specific and easy way to find replacement please try to look at the part # of that board (it is usually printed on the sticker attach to the board itself..
Hope it helps and please don't forget to rate my answer..
Have a nice day!!!
regards,
Chester.
Feb 04, 2012 | Philips Televison & Video
My phillips tv 50 plasma hd can't show picture
Problem is in either power supply or - my bet - the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
hope that help out......
Jan 18, 2011 | Philips 50PF7320 50 in. HDTV-Ready Plasma...
I have a LG42PG20 plasma tv that the sound works, but the tv has no picture. The screen is blank, dark in color.
cleanning inside,,,,check the red wire that to the screen inside moved it around,,,,plug in,,,try on...works....or not.so on..broken....not around shocks
Aug 27, 2010 | LG 42PG20 42 in. Plasma HDTV
Screen lower half goes black/blank
The lower "Y Buffer" board is defective. Best repaired by a technician, or contact Phillips support for the part if you think you are able to replace a small circuit board on your own.
May 19, 2009 | Philips 42FD9954 42 in. Plasma HDTV
Plasma tv makes loud static noise screen goes blank and shuts off
Take the back off and try to isolate where the sound is coming from.
Nov 24, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
I have a Toshiba 42WLT66 LCD TV approx 18mths old that has suddenly started to lose its picture. Sometimes the screen will switch to coloured lines then fade to a blank sreen, other times it switches...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 01, 2017 | Toshiba Televison & Video
Nec plasma, PXT-42SV1 intermittant picture goes to blank screen.
blank screen do you mean a blue screen or does it go dark
Jun 11, 2008 | Televison & Video
Panasonic plasma goes dark
sounds faulty. contact your retailer.
Apr 11, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Televison & Video Logo
327 people viewed this question
Top Televison & Video Experts
Electro Med Services...
