Question about Lexmark Office Equipment & Supplies
NEW LAPTOP COMPUTER - PRINT NOT CONNECTION - Lexmark Office Equipment & Supplies
Need to install with the driver CD
Posted on Jun 25, 2008
Why can i print but not scan?
You probably need to re-install the print driver on the computer that is not scanning.
Apr 25, 2014 | Brother Office Equipment & Supplies
HP Photosmart C4780 and Acer Aspire fight over web-based printing!
Try hard-wiring your laptop to the router with an ethernet cable as a test and then try printing, if you do not loose connection to the internet then the problem is probably that the printing is hogging your wireless bandwidth.
If the same thing happens with loosing connection to the internet try connecting to the internet real quick through another computer that is hardwired, you want to find out if the problem is a wireless one or that affects wired computers also. You might need a driver upgrade, you also might need to upgrade the firmware of the router
Jan 22, 2013 | Cisco Photosmart C4780 Wireless AllInOne...
Troubleshoot scan for an x3650? I am using an ASUS laptop with windows 7. Desperately tying to scan and send payroll. It's worked previously, but not now.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
Sep 12, 2011 | Lexmark X2600 InkJet Printer
I got it hook up to my laptop and i wanted to print out 1 or 2 pictures. And it wont print.
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 19, 2011 | Lexmark X3550 All-In-One Printer
I just bought a linksys wrt120n wireless router. Is there a way to use the wireless router to print on my new laptop?
This model printer does not have a network connection therefore to print via wireless from the laptop, the printer needs to be connected to a computer and setup as a shared printer. This computer must be connected to the wireless router with a LAN cable.
Please click on this link and follow my instruction to configure a shared network printer :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 04, 2010 | Lexmark X7350 All-In-One Printer
Just got a HP laptop for work that's running windows 7. It won't find our HP 5610 printer at home even tho I've downloaded the right driver
Is the printer directly connected to the laptop by a USB cable? Try a new cable. Check that the USB ports work by plugging in a known working device.
If you are using a print server or USB hub, try a direct connection. (If networked, check that your firewall isn't blocking the access by disabling it. If the print server is another computer, make sure that computer's firewall isn't blocking the laptop (trust level between the two machines).
I hope this helps.
Jun 28, 2010 | HP Officejet 5610 All-In-One InkJet...
I cannot print over wireless connection. I am using the Linksys WRT54G. I am trying to print from my laptop to my HP LaserJet 1320 PCL 6 printer. I cannot see the printer from my laptop. I am using AVG...
Disable your firewall on that computer where you shared your printer.
After that check firewall settings to allow printing from the network.
Your router working ok.
Feb 28, 2010 | Linksys Wireless-G WRT54G Router
Dell-All-in-One printer. Won't communicate with my
go to Dell websitr and downlowd the updared programs and driver for the All In one printer, the problem might not be your laptop, but your printer and the software having a connection issue. check with Dell.
Jul 21, 2009 | Office Equipment & Supplies
Printer will not print from computer
not a solution as such, but if the desktop won't send to the printer, then the laptop isn't the problem. if the connection is ok and the printer driver loaded ok then it might be a problem with wp software.
Sep 01, 2008 | Canon PIXMA MP160 All-In-One InkJet...
How can I install a printer to my Compaq. There is no port !
Newer printers will have a usb connection so u will need to buy a usb cable to connet between your laptop and theb printer. Alternatively, if your printer is old and doesn't support usb then you will need to buy a parrallel port to usb adapter to allow you to print from your laptop. With printers so cheap these days its actually more economical for you to buy a new printer rather than the adapter.
the only other way to do it is to connect your printer to another computer and share that printer over the network and then you can install that printer on your laptop as a network printer and therefore print from your laptop.
good luck
smeags.
Feb 20, 2008 | Compaq Presario 700 470024-192 Notebook
18 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
