Aiwa Stereo part.
Aiwa Stereo system NSX-V70 Where can I purchase a ribbon connector for the above system. It goes from the CD deck to the fascia board. The ribbon is 20cm long 7.5mm wide and has 5connectors. Part no AWM 2896 80C VW1
Ive tried everywhere to locate one. Can you help?
Kind regards
Ken
  • 4,234 Answers
The part can be purchased from tritronicsinc.com usnig the part number below.
Dan
Part # U0110289U Cost: $5.40
Posted on Jun 25, 2008
Aiwa nsx v200
I don't have a better solution, but you would help me if you could tell me the reference of the original remote controle for this Deck Aiwa NSX-v200. Juts in case... I am looking for this Original remote controle and for the Users manual (or a copy).
It seems sthta without these two items, it is impossible to program the deck...
Thank you for your kind attention.
Lou
Jun 24, 2012 | Audio Players & Recorders
Aiwa NSX-A-J800 Manual
Retrevo has the manual for the Aiwa NSX-AJ800 Stereo System here: http://www.retrevo.com/support/Aiwa-NSX-AJ800-manual/id/1076dj383/t/2/ . You will need to enter a code to download the pdf.
I hope this helps.
(note you will need Adobe Reader or a similar program to read the file)
Dec 23, 2011 | Aiwa NSX-DS55 CD Shelf System
I have a nsx-a508 unit,the 2nd tape deck got stuck i was able to open it but now neither deck plays and the cd player did work when this happened originally but does not work now ,the lights all come...
I think I can help you with the tape part, but as for the CD, that's a whole different story.
First, you should reset the unit by holding down the stop button (clear), and then pressing the power button. Everything stored in memory after purchase is cleared, including the radio stations, clock, etc.
Check if deck 1 is now playing.
I had a similar problem with my AIWA NSX-AJ310, and after some digging up, I realised that the belts were busted. They're not hard to replace though, unless you don't trust yourself to replace them. If you don't, let a qualified technician see about that for you.
The CD player in my system has retired also, so, we're in the same boat as with regard to that issue!!
Hope my solution was helpful!!
JaHa
Jun 21, 2011 | Aiwa NSX-A505 CD Shelf System
It is possible to connect a "AIWA NSX V70" as a
Use VIDEO/AUX instead. MIC is for the smaller input signal that a microphone would typically produce.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Aiwa-NSX-V70-manual/id/1076ci461/t/2/
Use your PC soundcard controls to adjust the output to something useable (max?).
Apr 30, 2011 | Aiwa NSX-AJ300 CD Shelf System
I have a NSX-V70 stereo. Tapes and CD do not work, FM/AM is fine
Your unit needs a little TLC. Let me address the likely problems/solutions:
1) Tape deck stuck - The most common problem here is that the belt has gotten slippery. This has prevented the mechanism from resetting to a known position and that is what prevents the door from opening. Hopefully when you pried it open, nothing bot broken.
2) Both tape drives run from the same motor and use different belts. The same applies to the second deck as the first. The belts are sliping and need to be replaced.
3) The CD lens is probably dirty and needs to be cleaned. The fact that the CD stops and an attempt is made to play it suggests that the optics are working enough to detect the disc. Clean the lens using a cotton swab and alcohol and that should resoplve the CD problem.
If you have not opened up these before, I would not suggest you start without someone around who has. There are 3 belts that need to be chagned for the cassette section to work. Plan on $15-$20 for the belts.
Dan
Feb 23, 2010 | Aiwa Audio Players & Recorders
Aiwa nsx v900
did you check on speaker wires? Red is +Positive, Black is -Negatives....
Jul 12, 2009 | Aiwa NSX-DS55 CD Shelf System
I NEED A MANUAL FOR AN AIWA STEREO BOOKSHELF SURROUND SOUND SYSTEM CX_NHMA86
Click Sony-Aiwa Support to download instruction manual of NSX-HMA86 (CX-NHMA86) stereo system.
Apr 28, 2009 | Audio Players & Recorders
Aiwa NSX-V70 will not recognize that a CD is present. 3 disk tray rotates, CD disk is "picked up" when selected, but the system does not read the CD.
Hi there. Found your post as I was looking for an answer to the same issue with my NSX v70 about an hour ago. I'm pleased to say that I found a solution on the web and mine is now working fine!
Try this address below and follow the instructions. The knob you need is black, with some white numbers on and can be seen from the back of the unit once you have removed the black casing and the silver back. Quite easy when you know how! Good luck.
http://www.kuro5hin.org/story/2004/3/24/45212/6874
Jul 12, 2008 | Aiwa Audio Players & Recorders
213 people viewed this question
 Grubhead
Grubhead
