Question about SanDisk Sansa e260 MP3 Player
I dont have sandisk driver for my sansa E260..i cant transfer songs..
    President:
  • SanDisk Expert
  • 652 Answers
Sansa Not Recognized: Try connecting it to the back of your computer or another computer the back straight to the motherboard this should be USB 2.0 and see if it will recognize it as sansa or Drive/removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansas firmware and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier. Make sure USB mode is MSC
Recovery Mode may also allow your computer to recognize the sansa
lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software when finished disconnect.... Sync to upload songs to the sansa......Hope this works
Posted on Dec 01, 2010
SOURCE:
How install a driver for Sansa e260
Download the software after you run the link below ....Put check next to converter/firmware update/Manual download...run the programs follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Feb 17, 2011 | SanDisk Sansa e260 MP3 Player
Sansa e260
You need to synch them to Rhapsody or whatever music service you pulled the songs from. also, make sure your music service subscription supports transfer to portable devices instead of simple transfer to a computer.
Jan 15, 2009 | SanDisk Sansa e260 MP3 Player
Driver required
please post me a sansa e260 driver and installion software
Oct 27, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260
Apparently there is a known problem with older firmware with some MP3 files having info in the ID part of the file that makes the player go crazy. So update your firmware or listen to different music :-)
"Bugs Fixed: Stability· Hanging at Refresh Database with certain ID3 tag genres."
This info from page below. Also shows you how to update to latest firmware which may fix your problem
http://forums.sandisk.com/sansa/board/message?board.id=e200&thread.id=10357
Sep 04, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260
The e260 works with microSD cards. Your 4GB card is actually a microSDHC card and won't work in the Sansa.
With a microSD card, simply put music tracks into a folder called "MUSIC". When the card is installed, the Sansa will see the additional tracks.
Jul 14, 2008 | SanDisk Sansa e260 MP3 Player
Mtp mode
uuh no it dosent...nice try tho
Jan 05, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e60
Try using WMP or explorer to transfer songs
Jan 05, 2008 | SanDisk Sansa e260 MP3 Player
Please help me!!! im desperate!!! sandisk sansa e260
if your sanas e260 does'n syncronize with your computer or say data base..., take the battery out and conect it with out the battery.
May 08, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
117 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
