Question about Hitachi 50UX58B 50" Rear Projection Television
Hello I have un tv hitachi 50ux58b it no work is dead. What should make, where can is the problem. thanks JOSE
    Scholar:
  • 167 Answers
Hello. the first thing you want to do .!!! is unplug the set.!!! then take off the back of the set and look for a fuse.!!! it should be around where the power cord come's out of the set. and see if the fuse is good . let me know if it's good or bad .!!! ok . " hope this help's you. "GOOD LUCK"
Posted on Jul 16, 2008
My hitachi 50ux58b red light comes on but tv wont come on.
check diod d915
check d196
check for open fuse on the B+ side
replace c707 1000uf @ 2KV
replace IC 901 and H.O.T location Q777
hope this helps,
regards
daniel
Jan 12, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi tv model 50ux58b starts to come then goes off
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Nov 07, 2008 | Hitachi 50UX58B 50" Rear Projection...
Hitachi 50UX58B
hello . rember me .? I told you to replace the hole board.!!! and we will go from there.!!! WELL you did not get back to me.!!! and you rated me as just helpful. !!! well tell me did it not fix's your set .& make it work now. !!! Right.!!! so if you think about it . YOU DID RATE ME RIGHT.!!! YOU SHOULD OF RATED ME AS FIXYA. . BEOUSE IT DID FIX YOU AND YOUR SET WORK NOW.!!! AND IT DID NOT BEFORE. YOU NEED TO CHANGE MY RATING TO FIXED YA,. ANFD THEN WE WILL GO FROM THER AND WILL LET YOU KNOW HOW TO FIX YOUR OTHER PROBLEM'S YOU HAVE NOW. THANK YOU "GOOD LUCK"
Oct 01, 2008 | Hitachi 50UX58B 50" Rear Projection...
Hitachi 50ux58b 50"
hello. it sound like a power supply problem to me .!!! it could be a bad solder joint.!!! or a bad fly back transformer.? "good luck"
Jul 27, 2008 | Hitachi 50UX58B 50" Rear Projection...
Hitachi TV Model 50ux58b
hello tell me did you have it on a surgestrip.!!! it sound's like the fly back transformer went out. !!! and is the set hdtv.!!! if not you might want to get you a new set,!!! a hdtv .!!! well hope this help you"good luck"
Jul 17, 2008 | Hitachi 50UX58B 50" Rear Projection...
My TV 50ux58b hitachi is dead not Power
hello. sorry it took so long to get back to you. well. the first thing to do is to check the fuse. did you.?
Jul 03, 2008 | Hitachi 50UX58B 50" Rear Projection...
Hitachi 65xwx20b
hello. yes you might check the cord . ? or your outlet that your pluging in to,might not work.? check them. ok hope this help's you."GOOD LUCK"
May 03, 2008 | Hitachi 50UX58B 50" Rear Projection...
Hitachi ultravision tv
tv comes on ,i hear but can not see
Dec 27, 2007 | Hitachi 50UX58B 50" Rear Projection...
Tv went dead
This sounds like the small blue capacitor next to the horizontal output transistor shorted and cracked, which blew the B+ fuse. The B+ fuse is the solder-in type which looks like a small resistor and the value of the blue cap is usually 1000pF at 2KV.
May 08, 2007 | Hitachi 50UX58B 50" Rear Projection...
Hitachi 50UX58B won't turn on
try checking c707 you have to look close they go bad look around it i had the same problem a small pin hole burn in it
Sep 16, 2006 | Hitachi 50UX58B 50" Rear Projection...
Televison & Video Logo
42 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
