Question about Maytag Refrigerators
Water will not fill up the ice dispencer. The lock is off. Does the changing of the water filter effect the ice making process?
  • Anonymous May 01, 2009
    changed filter and water dispenser or ice maker does not start working
I contacted the dealer and discussed the problem of no ice cbes being made, we were able to resolve why no ice cubes. I thank you for checking with me and I will keep in mind that FixYa is available.
Charles Roudebush...
Posted on Jun 29, 2008
I have a Maytag side by side w/ ice and water dispencer. Have been having intermittent problems with unit not dispencing water and not making ice(water not filling in to ice tray)unit is now making ice but...
YOU COULD HAVE A BAD WATER VALVE OR YOUR TANK IS CLOGGED UP AND STOPPING THE WATER FLOW THROUGH THE LINES. MOST MODELS HAVE A TANK IN THE BACK OF THE SHELVES ON THE REFRIGERATOR SIDE DOWN AT THE BOTTOM. IT WILL BE LOCATED BEHIND A PANEL YOU WOULD HAVE TO REMOVE SHELVES AND SCREWS TO GET TO IT BUT FIRST CHECK VALVE SOME SYSTEMS HAVE MULTI VALVES WHERE ON CONTROLS THE ICE MAKER AND THE OTHER ON THE DISPENSER.
Dec 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
GC3SHEx300 ice dispencer does not dispense cube or crush ice. Water comes out, lights work. it is not deactivated.
Sep 06, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
ED25DWXTN01 AFTER DISCONNECTING AND MOVING TO A NEW LOCATION I CANNOT GET WATER FROM DISPENSOR OR WATER UP TO THE ICE MAKER IS THERE A WAY TO BLEED THE SYSTEM?
In effect the only thing different is you moved the fridge and switched the water off. Make sure the water is getting to the fridge pipes connected to the fridge valves.(normally blue in colour.). If not rectify problem. If water is there, suggest you remove water filter in the fridge compartment and by pressing the water dispencer button see if water runs out at the filter adaptor. If not, there is an issue with the solonoid valve/s (very unlikely thougf) Could very possibly be the water is frozen and needs defrosting. Because there are variables that i havent been given, im surmising a lot. Normally when you depress any of the dispencing buttons,a clicking sound will be heard from the solonoids at the back. Simply the water should flow up the pipe to the filter then to the dispencer outlets. Most of the time, the water is either off or filter is blocked or limit switches at dispenser end is faulty. Very unlikely that both are defective at once so check the filter and water supply. If stuck, email me on terfou@imaginet.co.za
Sep 03, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water dribbling out of dispencer whirlpool american fridgefreezer
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
May 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker is not making ice no water is getting to it, but water is getting to the water dispencer
The problem could be in the dual valve , either it does not work or is leaking and the water freezes up inside the filling tube for the ice maker and when its needs water doesn't go through , in both cases the valve has to be changed.
Aug 11, 2009 | Refrigerators
No water supply to water dispencer
I had this problem with an old amana and my water filter neded replacing. Filter was enough for ice but not for water dispenser.
Mar 27, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
I lost power for several days during Hurricane Ike. When the power came back on, I cleaned out the ice maker bucket and let it make new ice. It makes ice and the light comes on when you press the...
when you repl the filter it has to be purged to bleed all the air out just keep askig for wtr until you purge all the ait out dispence at least 15 large glases of wtr
Oct 14, 2008 | Whirlpool Refrigerators
Icemaker and water dispenser not working GE GSS25JFPA stopped working and i thought it was water filters (have not changed in 4 years changed the internal filter and a aux one in basement in line no...
generic troubleshooting video: http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
as the video shows a kinked line may be the culprit. or
if your ice maker is making ice and it is your ice dispencer that is not working along with your water dispencer and when you press the dispencer button the light dims on the door. I would replace the main board. I experienced the same problem and the board fixed it This board is shared by many models and brands of fridges and the transformer goes bad from power surges this board powers the solenoid valves that open for your water
Apr 03, 2008 | Refrigerators
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Refrigerators Logo
24 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
