Advise, c
1) Check to make sure THE receptacle in the surge protector that the computer is plugged into, is good.
I have had a few surge protectors where just THAT receptacle was bad.
("Hmmm, monitor, router, and printer has power from the surge protector." Checked the receptacle in the surge protector that the computer was plugged into, with a table lamp, found THAT receptacle was bad)
2) Receptacle in surge protector proves to be good?
Suggest performing the test to see if the problem is the Power On switch, or the Power Supply.
(The Power On switch is located inside the plastic Power On button)
The test involves bypassing the Power On switch, by using a jumper wire on the Soft Power On, in the ATX main power cable's connector.
Has nothing to physically do with the switch itself.
Using the jumper wire the computer (Power Supply) comes on?
Problem is the Power On switch.
[ Example of a generic ATX power on switch that I have found fits many computers,
http://www.directron.com/atxswitch.html ]
Using the jumper wire the computer (Power Supply actually), does Not come on?
The problem is the Power Supply.
Replace.
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20(Green wire {PS_ON} is the Soft Power On wire. It is jumped to ANY Ground {Black} wire)
Want to know how to Properly perform the above test? Please post back in a Comment.
Also post the computer manufacturer's name, and the Model Number.
(On the back of a desktop computer next to the Windows Product Key, or up on the side of the tower)
Regards,
joecoolvette.
