Question about Bosch Dishwashers
Main Motor won't start-up in my dish-washer model SGS 5302 GB/07 - How would I know if the capacitor was faulty ? there is no smell or no visible damage - could this be tested with a multi-meter ?
    President:
  • 1,462 Answers
Not easy to test without special equipment. if capacitor is faulty, then motor will not move but will get quite hot as current is passing thro the run winding but motor not being cooled.
it is not an expensive part - about £8 in the uk. note the value of the capacitor and you should be able to source from a friendly electrical dealer. that will be a lot cheaper than buying it as a manufacturer's spare part
Posted on Jun 25, 2008
I smell my motor. Is it worth replacing, or buy new?
5 years seems short for a major appliance designed to give 10 years or more of service. I'd say it's worth repairing yourself.
Just make sure it is the motor, then dig a little deeper to find out why it failed. It can be from being bound up because of a jam in the pump, a leak causing the bearings to freeze, or in the case of inductive motors a failed starting/run capacitor.
I've seen failure of the waste water gate/valve solenoid due to a timer issue. You'll have to do your detective work and once you know exactly the part that is eminating the smell, you will have a path to backtrack from.
Remember, water and electricity don't mix and shut both off before working inside the dish washer!
Jan 30, 2016 | Kenmore Dishwashers
My wife put a load in last night and a couple of hours later the laundry room smelled like something was hot and the washer had stopped on the spin cylce. The control panel didn't feel hot but I unplugged...
Something caught in pump & belt burning. Motor start capacitor (If fitted) is US & needs replacing. Timer faulty, motor has burning smell, replace timer & or motor. Motor switchgear failed motor sitting there & humming, adjust switchgear or replace motor.
Dec 19, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool duet washer
2 possibilities ---1 is the capacitor that starts the motor and 2 is the agitator module that makes the motor keep changing direction. IF either is faulty the motor will not run
Jun 10, 2013 | Washing Machines
Won't start
sounds like you have a bad motor,when it heats up it stops running and when it cools down it will run again but one of these times it won't run anymore until you change out the motor.when the motor gets hot you might smell a shellac smell,this is the windings on the motor heating up.part number 8528157 and it's around 120 dollars on the sears site
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-Parts/Model-LSQ9549LW3/1198/0153200/W0312163/00005?blt=06&prst=&shdMod=watch this video to change motor
http://www.youtube.com/user/RepairClinic?v=Oeiyjt7807o&feature=pyv&ad=5457341981&kw=washing%20machine%20motor
May 07, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
When washer gets to spin cycle it will spin for 3 second then cut off, A few minutes later I hear a click inside the washing machine and it will try again
If there is smell that keeps on increasing then you must shut down the washer and remove power. Check on the motor , the capacitor to the motor and the main control panel. Since smell was noticed there can be ccomponents and so take care not to burn you fingers when you touch any part. Once this is identified you can remove and repace. if the heat was noticed on the motor,check for free movement of the spindle or it can be due to possible heavy load. Also check for inlet and drain valve pump to be faulty and have burning off the coils.
Nov 05, 2011 | Amana DLW330RA Top Load Washer
Washer won't wash or spin has a burning smell then shut off.
A burning smell confirms the fact that there is a serious fault . All what is required once the smell is detected is to remove the panel and check for the part that is heating up. You can first check the main motor, check for leaked capacitors, check if the smell comes from the control panel or the valves, pump.
since the smell is present the part will be heated up and so is hard to confirm.
Your observation to confirm is most important before we go to the next step as the damaged part thus detected must be replaced.
Oct 07, 2011 | Maytag PAV2300 Top Load Washer
Washer pumps but half the time it won't spin unless you give the basket a little push. I use a small magnet to keep the lid relay closed. Once I give the basket a little push, the washer starts to...
Quite likely the spin motor is a capacitor start type motor and has a capacitor to start it (by placing a winding slightly out of phase with the rest of the motor in turn encouraging the movement of the motor). When it reaches about 200 RPM the capacitor is disconnected and runs without it.
Maybe the start capacitor is faulty or the internal switch/electronic control is faulty?
Aug 30, 2011 | GE WPRB8050D Top Load Washer
The motor will not start. Its hums for a second, than stops.
Dear Sir,
I came across a lot like this problem as an expierienced technician on power washers.
Most probably there is a capacitor, which when faulty, it gives this condition.
If you know with all respect to remove the pump from the electric motor, try starting without load.
It is possible that the problem is in the pump. If the electric motor finds that it cannot turn because the pump or pump pistons are jammed...it will hum and stops. I hope you did not do this very often...because you may have damaged the electric motor for good. Also important never put on a power washer without water supply. To test you can feed water but remove the gun...so that there is no load. Hope it is the capacitor in your case. Now the capacitor gets faulty from another fault. One of them is that when you were using the machine and closed the gun, the power washer stayed getting on and off all the time. This will damage the capacitor for sure. If you make a new capacitor ad machine starts and stops when gun closed....there is problem with control valve (Spill Valve). Hopefully the valves are OK. The spill valve you will locate inside...generally always you see wires coming out of it. Spill Valves are rarely serviced...myself I change with a new one. This what I am explaining is for nearly all models.....but I do not know your type of model....so I appologize if I am not explaining for your model. Well if you know how to open the cover...you can pin point what I said. Many Karcher covers are opened with screw drivers Torx T15.
Apr 19, 2011 | Karcher Garden
Washer does not spin
The main reason for the washer not able to spin will be failure of supply voltage to the main motor. Now this is possible if the porgram controller unit is faulty, the motor is faulty or a the motor capacitor is faulty.
Check for free movement of the motor, check the supply , if there is no supply from the control panel, then the unit must be the suspect.
Please find help . Click on washing machines
Nov 19, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Dishwashers Logo
254 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
