Question about Epson Stylus RX650 All-In-One Printer
Scanner error Hi guys  I have a RX650 I power up and get a "scanner error has occured"   How do I go about trying to see what the problem is and fixing it? thanks Shaz
    Novelist:
  • 110 Answers
Please follow the steps below to resolve your issue.
1) Turn off the printer.
2) Lift the scanner cover.
3) Toggle the transportation lock five times, ensuring that it is in the unlocked position, towards the front of the scanner.
4) Turn on the printer, and the error should be cleared.
Posted on Aug 22, 2008
My fi-5220C says No paper on ADF paper chute or Hopper. (Code: Ds32003)
"No papers on the Chute unit" error occurs when the Hopper empty sensor detects no paper loaded on the Chute unit at the receipt of a Feed command.To recover this, Load documents on the Chute unit.
1. Does the same symptom occur after turning OFF and ON the scanner? Press power button of the scanner for more than 2 seconds to turn it OFF, and after more than 2 seconds elapse, press the power button to turn the scanner ON.
2. Is there a slip of paper left near Hopper empty sensor? Open the ADF and check inside visually.
3. Check the performance of Hopper empty sensor. Conduct Maintenance mode to see if the sensor works properly.
If the error still occurs, confirm that the cable is correctly connected then replace the sensor EM.
Thanks & regards,
ScanCare
Oct 02, 2013 | Fujitsu Office Equipment & Supplies
Error code "L"
Is the code display L-6? This error code describes US Sensor Alarm.
You may perform the following steps or may ask your local Fujitsu scanner expert for the disgnosys and replacement of faulty part.
1. Does the same symptom occur after turning OFF and ON the scanner? To check, press power button of the scanner for more than 2 seconds to turn it OFF, and after more than 2 seconds elapse, press the power button to turn the scanner ON.
2. Check the US Sensor operation by conducting Maintenance mode to see if the US sensor works properly. If the error still occurs, confirm that the sensor cable is correctly connected. And then replace the US Sensor FX and US Sensor RV.
Thanks & regards,
ScanCare
Aug 05, 2013 | Fujitsu fi-6130 Flatbed Scanner
I have fujitsu 4120c and it doesnot work,it have error 8.can anybody help me
Error code 8 means the SCSI fuse is blown off. This alarm is detected during initial processing immediately after power-on.
Probable causes:
- Defective SCSI cable
- Other SCSI device malfunction
Check if the SCSI cable or other SCSI devices connected to the scanner cause this error.The scanner can work even after this error occurs.
If the issue persists, you may have to contact Authorised Fujitsu Engineer to rectify the error.
Hope the above information is helpful.
Thank you for contacting Fixya.
Regards,
TechSatya
tech.satya@gmail.com
Nov 13, 2010 | Fujitsu fi-4120C Path-Through Scanner
My Epson RX650 scan software will not start up. The printer works and the copy feature works. When I double click on the Epson Scan icon on my desktop it appears that it wants to start up but then...
Install another scanning software, if you have photoshop or any imaging software, you can use the scanner by going to the menu, then choose File, Import, TWAIN, Acquire and the scanner control will appear.
Or just go to My Computer and double click the scanner icon (in XP) to start the scanning assistant.
Nov 09, 2010 | Epson Stylus RX650 All-In-One Printer
Canon MP480- 5011 - Printer Error Has Occurred After Scan/Prt
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints.
Jul 16, 2009 | Canon Pixma MP480 All-In-One InkJet...
Ive turned on my Epson rx650 and it says there is a scanner error, and told me to refer to my manual. how can I fix this? I dont know where the manual is!!
You can find most of the manuals through www.epson.com.
I only found the user's guide by googling and that led me to theAustralian Epson site. The direct link to the user's guidehttp://tech.epson.com.au/downloads/RedirectLink.asp?ProductID=stylusphotorx650&Email=&DownloadID=5011
A Basic Operation Guide is at http://tech.epson.com.au/downloads/RedirectLink.asp?ProductID=stylusphotorx650&Email=&DownloadID=5012
The Basic Guide indicates that the solution is to turn off theall-in-one again and turn it back on. Make sure the transportation lockhas been released. If the error repeats contact dealer (Epson)
Jul 08, 2009 | Epson Stylus RX650 All-In-One Printer
Lide 50 Canon scanner - error code 2,7,0
same problem with me i got Lide 20 Canon scanner - error code 2,7,0
any buddy know solution must let me know..
ashrafrathod@gmail.com
Mar 20, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
RX650 screen display "printer error occurred Please see your Manual"
You can get the solution by me if you wish to go for a session email me at techin.scott at the rate of gmail dot com, I will pick you there.
Otherwise just go through this link, it will help out regarding : Drivers Installation for Printers
Oct 22, 2008 | Epson Stylus RX650 All-In-One Printer
Epson Stylus RX650 All-In-One Printer Logo
480 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
