Press F2
del
F10
Depend in *********** company
just go optimse default
pr if you want to go to by manually follow the steep from picture
http://labtestproject.com/hardware_setting/configure_computer_bios_setup_change_computer_boot_sequence_boot_cd_rom_drive
http://support.gateway.com/s/tutorials/Tu_949687.shtml
for lenevo
http://www-307.ibm.com/pc/support/site.wss/MIGR-41472.html
the main part is to go boot squence 1st boot CD/DVD
2nd boot HDD(seagate/w d/maxtor)
F10 >yes
Hope it will help you.
Please don't forget to vote me.SHIBUDA
Good day,
To enter the bios while booting press the delete button repeatedly to enter the bios.
If this does not work you can also try pressing F2. It depends on the motherboard.
Please note that you must press the key just after the post beep. If you miss it restart the machine again and try again.
Hope this helps!
Regards
HI,
tap this over and over, : f1 or F2 or f10, or f9 or delete key
ALR PC non / PCI = CTRL+ALT+ESC
AMD advanced micro devices=BIOS = DEL
Award BIOS = DEL
Dtk Datatech Enterprises Co. BIOS = ESC
Phoenix BIOS = CTRL+ALT+S
Phoenix BIOS = CTRL+ALT+INS
Restart your computer
during the boot process you will see on the screen to press a certain key usually Delete or F2 to enter setup
this will differ depending on which bios you have
Press and hold that key during the boot up process to enter BIOS
if you have changed any of the BIOS settings by mistake
you can load failsafe or optimised defaults using the arrow keys you can after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
CMOS is an on-board semiconductor chip powered by a CMOS battery inside computers that stores information such as the system time and date and the system hardware settings for your computer..
If your computer won't boot without a password or you need a password to enter the computer set-up or change the settings, then you have a BIOS password set. BIOS is an acronym for basic input/output system.
The BIOS is the basic instruction set that teaches the computer how to access disk drives, keyboard, display etc. The BIOS is typically placed on a ROM chip in the computer hence the term ROM BIOS.
The ROM BIOS allows the computer to boot itself. The BIOS is required to boot the computer. Thus, if the BIOS is password protected, the computer will not boot (or you will not be able to enter or change the BIOS settings.)
using the arrows keys scroll to Advanced Bios Features change the first boot device to cd rom press escape the F10 save to cmos to restart
BIOS is a software program that controls basic functions in your computer, such as boot order, keyboard control and how your processor interacts with memory cards
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys scroll down to advanced bios features press enter to change boot devices
press f10 to save to cmos escape then restart your computer
if you need to change any of the settings using the arrow keys if you have made any changes that has compromised your computer
you can go back and load failsafe or optimised defaults
hope this helps you
When you boot up to the log in
screen type in administrator as user if you cant log in
During the boot up process you
will see on the screen for a short amount of time a certain key to enter set up
press and hold that key to enter set up BIOS scroll to set user password or
supervisor password you can change or remove the password from there if you are
still unable to change your password you might download
http://download.cnet.com/%7Bvalue=http://www.download.com/ubcd4win/3000-2086_4-10550208.html
UBCD4Win is a bootable
"live" CD which contains software that allows you to change
paswords repair/restore/diagnostic
almost any computer problem also has a
bios reset tool which remove your password and BIOS password although you will
have to use a computer with an internet connection you will have to burn it to
a disk as an iso then change your firtst boot device to cd During the boot process you will see
on the screen to press a certain key to enter setup Press and hold that key
during the boot up process to enter BIOS the scroll down to advanced bios
features press enter change your first boot device to cd press escape then
press f10 to save to cmos to restart (note after you have removed the password
you must go back and change the first boot device to your hard drive)
Hope this helps
IF YOU HAVE NOT PUT A BIOS PASSWORD
Hope this helps
you can change a few settings in BIOS but as long as you can remember what changes you have made so if anything goes wrong you can restore bios to original settings
enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
hope this helps
