Paper jam on a HL-2140 and can not get the toner out
Thanks
Worked at it again this am and managed to remove the tray and toner .
This allowed removal of the jambed paper .
Fired it up and it now prints a ok .
Maybe it was just the way we were grabbing the tray and the toner
it appears like you have to release the tray and the toner and lift them both up slightly
prior to pulling them out .
I could not understand why we could not pull the paper out since about 1 inch was protruding but could not be budged.
It"s working fine now .
Regards Jack
Posted on Jun 26, 2008
After paper jam cleared HL-2140- printer continues to flash error error error------- What is solution
Be sure the front door is closed and that the fuser door is closed. Also be sure none of the sensor flags are stuck down. Also try pressing the Go button to see if the error clears.
Jul 07, 2011 | Brother HL 2140 Laser Printer
Brother HL - 2150N Paper is jammed inside printer; how do I remove it ? URGENT - business printer... thank you!!
Open the front cover, remove the toner/drum cartridge.
Open the rear cover, look for a jam lever you can press down then remove the paper from the back.
If you try to pull the paper out through the front you can damage the gear system.
Use both hands to try and limit the possibility of tearing the paper.
Jun 14, 2011 | Brother HL 2140 Laser Printer
HL 2140. How do you remove jammed paper from inside printer
You can remove the jammed paper by removing the drum and toner inside the printer.
First Open the front cover, just pull down the cover right above the brother logo. You will see the handle for the drum and toner. Hold the handle and pull it towards you, just use a little force on it. Then remove the jammed paper inside. Just to be sure you can remove the toner from the drum by holding down the green tab on the side of the drum unit. then pull the toner out. Check if there's a small piece of paper inside the drum unit. Put the toner back to the drum make sure it clicks into place. Reinstall the drum and toner back to the printer. It should also click into place. Then close the cover.
Hope this helps. Rate if it works. Thanks
May 05, 2011 | Brother HL 2140 Laser Printer
How could i fix paper jam on Brother HL-2140 Laser Printer?
One of the main causes for paper jams is the presence of dirt, dust, or debris in your toner cartridge. The paper coming into the cartridge would get stuck. So clean your printer regularly. Remove the dust from the printer. Also find out whether any jams occurred in the sensor hole in the upper part of the rotating drum. Do not touch the roller while cleaning. If the oil in your body gets into the roller, the printing media cannot roll over it properly and you can't get rid of the printer problem.
Jan 12, 2011 | Brother HL 2140 Laser Printer
I simply have the error light on my brother 2140 printer. I have pulled out the drum and toner. I have cleaned the corona wire. I don't have a paper jam.
  1. Open the front like you are going to pull out the toner.
  2. With the door open push and hold the button the on the left side that the blue button normally pushes when closed.
  3. Release after 30 seconds. this will reset the drum.
Hope this helps. Happy Printing :)
Dec 30, 2010 | Brother HL 2140 Laser Printer
Ihave a paper jam help
Pull the paper tray out and look in there. open front door and pull out the toner/drum unit and look in there. open the back door and look in there. and thats all I can say about that. Steven 818-888-0006
Mar 05, 2010 | Brother HL 2140 Laser Printer
Have a BROTHER HL2140. Paper jam: Can't remove drum unit & toner cartridge: Help
Solved by opening the front and removed paper: not required to remove cartridge. Info on Problems with Printers. Thank You
Nov 08, 2009 | Brother HL 2140 Laser Printer
49 people viewed this question
jasbo
jasbo
