Question about Sony VAIO GRV680 Notebook
Dc jack how can i change my DC jack
  • 63 Answers
This is usually quite a tricky repair on laptops as you'll need to solder the new jack socket to the motherboard in the laptop.
If you cant get the original socket, you could get a chassis mounted socket, mount the socket onto the case where the old jack was and fix it in place with a nut. Then solder 2 pieces of wire from the socket to the motherboard.
Watch the polarity though, else you'll have a fried motherboard!!!
Posted on Jun 25, 2008
Compaq CQ1-1225 AIO Wont Start at all. Removed all components
Anti-Static wrist strap connected to ground source, and your wrist;
1) The jack your AC adapter plugs into on the motherboard, is the DC Power Jack.
Motherboard out of case, power to motherboard, take your multimeter and see if you are getting 19 VDC at the DC Power Jack's positive solder joint, on motherboard.
The center pin of the jack is Positive. (The inner cylindrical shell is Negative)
Follow the DC Power Jack's positive pin from the Center of the jack, to the motherboard.
You probably won't be able to touch your meter's Positive (Red) probe, to the DC Power Jack's positive pin under the jack; so touch it's solder joint on the opposite side of the motherboard.
(DC Power Jack should be soldered close to the motherboard, is why)
Of course also touch the Negative lead, (Black probe), of your meter, to the Negative, (Ground) solder joint for the DC Power Jack.
Getting 19 volts DC?
See if there is a cracked solder joint, for any of the DC Power Jack's pin connections to the motherboard.
ANY perceptible movement of the DC Power Jack on the motherboard, indicates a bad power jack, and may indicate a broken/cracked solder joint.
Center pin of DC Power Jack is loose? Bad DC Power Jack. Replace.
2) DC Power Jack is determined to be in good repair? No cracked/broken solder joints?
The next components in the power circuit on the motherboard, leading From the power jack, are P. MOSFET's.
Power MOSFET Wikipedia the free encyclopedia
More information using a prior solution,
Dv6000 power light does not come on any more
Check the links given.
3) The last thing that concerns me, although I probably should have listed it first; is the AC adapter you are using.
Concern is that it doesn't have the 'intelligent chipset' that matches the Compaq CQ1-1225 All-In-One desktop PC's circuitry.
AC Adapter For Compaq Presario All in One CQ1 1225 Desktop PC Charger...
Just my thoughts..........
Jan 15, 2015 | HP Computers & Internet
How to replace charging port
Gateway Nv57h73u notebook jack issue check:
1) more common issue is changer ( ac adapter) DC core broken inside, please change a adapter to fix. also you can repair adapter DC core wire. if still no charging that could be DC jack issue inside notebook.
2) disassembly keyboard and top cover of your laptop looking for a wire it connect to the DC jack, check is the wire broken close to the jack soldering pot. you can soldering it to fix, or other issue is jack damaged, you can order and change the DC jack with wire easily, the parts see picture
Oct 20, 2014 | Gateway Nv57h73u With Autodesk Maya...
My acer aspire 7720G shut down random
Wait a minute. What?
From what I read;
1) One wire of the AC adapter (Charger) is hot to the touch.
'.....when I touch the charge one part of the wire is very hot."
2) AC adapter checks out as far as voltage is concerned.
"I tested the charger voltage and everything is ok."
3) "Sometimes when I touch the charge appear the icon...Could it be the charger broken wire?"
Does this mean, "Sometimes when I touch the AC adapter (Charger), the battery icon appears."?
Battery is CHARGING icon?
Could it be a broken wire in the power cable TO charger?
Uh, yeah.
1) AC adapter NOT plugged into the DC Power Jack, plug the power cable of the AC adapter into power.
Multimeter set to DC Voltage, and proper scale, red Positive lead to harness wire that goes to DC Power Jack's center pin;
,black Negative lead of multimeter, to wire that goes to DC Power jack's inside cylindrical metal shell;
Now gently wiggle the cable from the AC adapter, TO the DC Power Jack of the laptop.
Do you get an intermittent reading?
2) Also, how did you replace the DC Power Jack? What steps did you take?
Did you reuse the wire harness, and solder it to the DC Power Jack?
Have a lot of experience in desoldering/soldering?
What tools did you use?
25 Watt soldering iron?
.025 or .030 rosin core solder?
Desoldering Tool, or Desoldering Braid? (Solder Wick)
Side Cutters instead, and slightly shortened the wires of the DC Power Jack's harness?
(Then tinned the wires, and soldered the wires of the DC Power Jack harness, to DC Power Jack?)
Damp sponge, and cleaned the well tinned No.2 chisel tip, of the soldering iron, frequently? Used rosin solder flux?
Center pin wire (Positive), of harness cable TO DC Power Jack, was soldered to the center pin of the DC Power Jack?
Negative wire of cable TO DC Power Jack, was soldered to the inside shell of the DC Power Jack?
(Cylindrical shell, inside the DC Power Jack, that surrounds the center pin of the jack)
Sure there are no cold solder joints?
Not trying to 'browbeat' you, just am curious.
1) IF you are SURE you have the polarity correct, of the wires in the harness cable, that goes to the DC Power Jack;
,and you are SURE there is no broken wire, in the cable from the AC adapter (Charger) TO the DC Power Jack;
,and you are sure you made good solder joints;
I suspect the power correcting chipset on the motherboard, to be bad, or perhaps a Diode.
One example of the chipset I am referring to. This one is used in a lot of laptops. May not be used in yours, but gives you something to refer to when looking for a bad chipset, in the power stage, on your motherboard,
Usually when bad the top of the chipset will be blackened, or bubbled.
A Diode is a one way valve for electricity. When they go bad it is visually obvious.
Post your findings in a Comment.
Jun 10, 2012 | Acer Aspire Computers & Internet
Hi when plug in my ac adapter into lenovo x61 the tablet will not turn on i try it on other computer and it will on what happen?
LOL, sounds like your tablet has seen it's better days. See why HP got out of the Tablet business? They are nothing but trouble.
Apr 08, 2012 | Lenovo Tablets & eReaders
My Q430's power connection is loose and not changing battery. Do I have to swap out motherboard?
The DC Power Jack is the jack you plug the AC adapter (Charger) into. (DC_IN)
The DC Power Jack for the Samsung Q430 series of Notebook PC's, consists of a;
1) DC Power Jack, which is connected to two wires.
2) The wires end in a small male plug connector.
It is now a DC Power Harness,
FOLLOWING Anti-Static Procedures, the laptop is disassembled far enough to unplug the DC Power Harness, and plug a new one in.
Sep 10, 2011 | Samsung Q430 Laptop
Hello sir, The problem with my laptop compaq presario v6500 is that it works on battery but it does not work on AC power while my charger is alright. neither its battery is getting charged. i took to a...
hi karun, i think your hardware eng may lie to you,its not necessary to change hole motherboard for this problem , if you have problem in your motherboard mean you cannot ON your laptop itself , just try to take your laptop to some-other hardware expert to do this process, or may be he didn't get spare of DC jack for your laptop.
But i am sure if you change your DC jack is more enauf for this problem, i have search how to do DC jack process in online, i got one site too. just check it and try to show it to your Hardware eng.If possible ask about you can able to get DC jack spare in your area , some hardware eng can help you by putting DC jack of old laptop of same model. Just don't change your motherboard until you have try all this process.
just copy and paste the link in your browser :
Good luck ! if you think your problem solved don't forget to rate
Jan 01, 2011 | Compaq 449901-001 - HP Presario V6500...
Hello my laptop t41 power is not even flash but the adapter is working,am technician and i have troubleshoot allot.
I concur with what Diegotech stated.
To iterate further;
1) The DC Power Jack (DC IN), may have cracked solder joint/s on the motherboard connector, (Female), where the DC Power Jack plugs in.
2) The DC Power Jack may be broken.
Center Pin mount, and/or body of DC Power Jack, and/or Outer Shell mount.
Replace DC Power Jack.
3) Wires from the DC Power jack plug to the female connector on the motherboard, may be bad.
Two examples, of a place to buy an IBM ThinkPad T41 DC Power Jack,
Past this point it's a bad DC sensor on the motherboard.
Replace motherboard.
IBM ThinkPad T41 Service Manual, (Free),
On this page go down to the 8th line.
The one that starts with > ThinkPad T20.
Go across, and click on > T41
Takes approximately 2 seconds to see the first page, and additional time to fully download.
Page 142 for 14.1 inch LCD screen
Page 151 for 15 inch LCD screen
(PDF file page number box at top)
Dec 01, 2010 | IBM ThinkPad T41 Notebook
Where i can buy, power socket for my amilo pro v2010?
Just one example,
The power socket in the laptop that the AC adapter (Charger) plugs into is a DC Power Jack.
Type Amilio Pro V2010 DC Power Jack in your browser search bar, press the Enter key.
To add:
Nov 07, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Dell inspiron 9300 doesn't charges i doubt its dc jack is broken , wanna fix it
If it works from DC jack try to change the battery first, for example to the same battery from another comp. If DC jack is broken and laptop don't works from wall outlet better change the jack in service center. Disassembling Dell is hard work... Cheers.
Sep 20, 2009 | Dell Inspiron 9300 Notebook
Intermittent dc jack connection for Gateway mx3215
Here is how to disassemble Gateway laptop,
Here is replacement DC socket (needs soldering),
Here is DC board (no need soldering, but expensive).
Hope this helps.
Mar 17, 2009 | Gateway MX3215 Notebook
Sony VAIO GRV680 Notebook Logo
90 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
