Question about Motorola Mobility HS850 Consumer Headset
How do i connect motorola hs850 with lgcu720 (shine)
I have a n hs850 and I want to pair it with the LGCU720 (shine) but I do not have the manuel to the headset.
1. With the headset’s boom closed,press and hold the Multifunction
Button E until the headset indicator turns on (about 3 seconds).
2. Release the button, then open the headset boom.
3. The headset indicator remains on.
4. Perform a device discovery from the phone.
5. Select the Motorola HS850 from the discovered devices list and confirm following the on screen prompts.
6. When prompted by the phone, enter the passkey 0000 and confirm to pair the headset with the phone.
The device ID is now stored in the phone’s memory.
Pairing is successful when the headset indicator flashes 10 times
rapidly.
Hope this helps
- Ted G.
Posted on Jun 25, 2008
Hi there, pls i tried 2 unlock my lgcu720, but it says my phone is not personalise. Pls how du i personalise it? Tnx
This site is nearly perfect and they were recommended highly in the cell phone forums.
http://www.unlock-zone.com
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
Dec 07, 2010 | LG Shine CU720 Cellular Phone
LGCU720 shine phone. Bluetooth is not working
did you do it the correct way ,recheck your procedure and settings ,follow the instructions here http://www.wireless.att.com/support/deviceTutorials.do?universe=att&deviceId=10290&tutorialsCategory=Bluetooth+Set+Up&tutorialId=645050
if the problem still persisits then its a hard ware problem with the blue tooth device
Jan 04, 2010 | LG Shine CU720 Cellular Phone
Hello i have my imei for lgcu720 i need to find for free the code to unlock
Oct 14, 2009 | LG Shine CU720 Cellular Phone
Won't pair with Motorola HS850 headset
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Apr 20, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Make sure the book mike is closed, then press the button until the light changes color. Once it changes color, open the boom mike. Now the earpiece is in pairing mode.
Feb 08, 2009 | Motorola Mobility H700 Wireless Headset
I've lost my pairing code how can I get another on, or is there a
From the Motorola Website:
The default pin code or passkey for Motorola Bluetooth accessories products is 0000 and cannot be changed.
This should work for you, but if it doesn't you'll to contact Motorola
Dec 05, 2008 | Motorola Mobility HS850 Consumer Headset
Motorola HS850 Headset gone silent
I bought a new HS850 and guess what, I got this hearing problem on the very first day ...phew ! I did the pairing with my Motorola A1200 phone and it worked for once, even the sound was coming in the earpiece and then I put it to charge for the first time and once done, I again started it up and it got connected with the phone and after that there was no sound in the ear piece. I was going nuts....about what could be the problem.
So i decided to delete the earlier paired profile from my phone and do the pairing again and guess what...It Worked....:) So you can try that out too....
Dec 06, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility HS850 Consumer Headset Logo
63 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
