Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Frige has water dripping in from freezer
The freezer form ice under slide out tray and stops up drain. Water then drips into the refrigerator and stay wet. I have removed ice in freezer thawed out drain line and it starts again in 1-2 weeks
  • Brian Papineau
    Brian Papineau Dec 06, 2008
    I have the same problem with the exact same model...Ive checked the seal and it seems to be good on both the fridge and the freezer...any other ideas?
  • 63 Answers
Hi, Check the door seal.
Ice is often caused by warm, moist air getting into the freezer and condensating, then freezing.
Posted on Jun 25, 2008
Hi, I have a refurbished RFG297AARS from Samsung that we purcased as a refurb about 7 days ago. On day 1-3, a puddle of water formed under the back right underside of the fridge, without the water line...
Chances are its either the drip line or drip tray.. there is a drain to route the condensation pulled out of the fridge and freezer that leads to a drip pan underneat the unit.
Either the drip tray was not installed.. reinstalled incorrectly or the drain tube is leaking or no longer directed to it, or it's overflowing due to excess condensate.
Best of luck!
Apr 26, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
Our frige is only a ear old and our freezer is on the bottom. We I have ice forming from water leaking out of the vents in the freezer. This water is leaking from the left and the right side of the...
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Apr 21, 2011 | Refrigerators
My whirlpool refrigerator is 4 year old. the ice maker is not installed I am getting water in my refrigerator now for over 5 months. There is no sign of water dripping down from the freezer or the back...
Jan 21, 2011 | Refrigerators
Water is dripping from the top into the fridge in the back is frozen up and condensation is forming at the top of the fridge ceiling...dripping down.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer.
Aug 10, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
Ice forms under tray in freezer - then water drips into refrigerator - this has been going on for at least 3 years - and we are at wits end trying to keep the drain from freezing up - what to do - the...
Whirlpool has a kit to stop the drain from plugging up. You mount a metal tab on the heater and it is long enough to slip down into the drain. When the heater comes on some heat gets transferred into the drain hole and keeps it from ice blockage. fed15be.jpg
Apr 08, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water dripping into refrigerator from freezer
Drain in freezer is clogged usually with ice. Unplug frige and defrost 6 hours with doors open. Pull lower front grill and check drain pan for water. If no water remove rear panel inside freezer to clear drain hole, below coils in the middle...
Mar 29, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a ge tns22brcblbs and there is water leaking from the freezer into the frige. the frezzer and frige are working just fine im sure the water is coming from the defrost of the freezer but i need to...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer
Oct 30, 2009 | GE Profile Arctica Stainless Steel Top...
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
159 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
