Question about AudioBahn AW1251 Car Subwoofer
Helpp quick! I have two 12" adiobahns with a 760W pioneer amp they have all been working great until the left one has gone rock solid the other one still works plz help sooon!
    Novelist:
  • 100 Answers
My bet on the rock solid sub is the voice coil melted and it is shot. You could just unhook the rock solid one and use the one that still works. Just make sure the impedances will match up. Also, turn the gains down on the amp the sub most likely fried from over driving or distorting for a while. Good luck man
-Andrew
Posted on Jun 25, 2008
Why does my spa 500 amp blow a fuse every time I hook up my 15" lanzar sub to it
Because it's drawing more power than the fuse can handle get a fuse with a higher rating. A 100 app fuse worked great for main power with my setup 760w amp a 15"sub 2 10"subs and a 12" sub. Also my amp had 2 30amp fuses on it one for each channel but I ran everything out of one channel.
Aug 02, 2016 | Lanzar Car Audio & Video
I have 2 pioneer 6x9 400w, pioneer GM 6500f 760w amp and a kenwood KFC W1012 sub, how d i get the best sound from these?
pioneer gm 6500 is a 4 ch amp rated at 60w-4 way to small of an amp to run your sub. UNDER-POWERING your sub is more likely to damage spkr than over-powering. my advice,get mono-block to run sub
Jan 04, 2013 | Pioneer 6X9 5WAY 400W SPKR Car Speaker
Wiring diagram for pioneer deh-p41
Yellow for memory.
Red for power acc.
Black for ground.
Blue for remote turn on(amps and accessories).
Gray pair is for right front speakers, solid for positive,striped for negative.
White pair for Left front, again solid is pos, striped is neg.
Violet or purple for right rear, same with solid or striped.
Green pair for left rear, same solid/stripe configuration.
Nov 17, 2009 | Pioneer DEH-P410
03 impala there is a factory installed amp all speakers. i am trying to find out if i can power another amp 760w pioneer form the amp that is already there? i have already put outputs for my RCA wires. can...
You might not want to do that. The 760W Pioneer amp might require larger wire due to the power consumption of the amp. Most amplifiers require a direct wire from the battery to the amp. The power wire for the factory amp might not require very large wire and if you tie into the power for that amp the fuse could blow and wiring in your car could melt or catch fire, The best installation is to run the recommended guage wire from the battery directly to the amp with a properly rated in-line fuse.
Nov 07, 2009 | 2003 Chevrolet Impala
No bass coming out
u probably have to replace the rca inputs on the amp or resolder the short on them if u can
Aug 31, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Amp messed up got 24 volts instead of 12 how to fix
Here is what I need you to do so that I can help you try to fix this. I need you to open up your amp take some pictures. I will need some of the overall view, then take two seperate picteures closer dividing the amp in half. They should look like one really big picture of the overall amp. Then finaly I need you to take some pictures of the problem. I am sure that witht the pop and smoke that you saw and heard you shold be able to find the problem really quick. With all of this and from the way is sounds this could be a really easy fix. onle last thing do you have a soldering iron, solder and a wet sponge.?
Apr 11, 2009 | Metrik Amplifiers MAX-1202 Car Audio...
Wiring
Usually an 800 watt peak sub would be a 400 watt rms. Hmmmm. Anyway, just bridge the amp (1x 380) nd keep the gain up enough to stay clean. Watch the sub and turn up gain until it starts to distort, then back it down a hair. Do this with the CD players volume up 2/3 to 3/4 volume with the BASS and treble at zero (bass better at minus 4 or so if you are a bass head! Hope thishelps.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 27, 2009 | Pioneer GM-5300T Car Audio Amplifier
Speaker type
I posted a comment on your other post not nodicing this one. But commenting on the choice of amps, It would all depend on what the model number is on the pioneer amp. Also it would depend on what kind of sound you want. Could you get me the model number of that and double check your model numbers for the kenwood sub and amp. The amp that I show when I googled it was rated at 250 watt at 2 ohms no where near 1000. so if I have the wrong amp let me know, I would like to help. Thanks
-Andrew Hawkins
Jun 01, 2008 | Car Audio & Video
Red light on my amp?
Does the amp power up normally if you disconnect the speaker wires from the speaker terminals of the amp?
It's never a good thing to blindly short across a power source.
May 22, 2008 | Pioneer GM-5200T Car Audio Amplifier
TI-85 Calculater
Press and release the orange 2nd key. Then press and hold the down arrow key until the screen is how you want it.
Jan 13, 2007 | Texas Instruments TI-85 Calculator
AudioBahn AW1251 Car Subwoofer Logo
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Jerry Naidoo
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
