Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Hoover steam vac
The red ball in the dirty water basket keeps popping up even when there's no water in it. Why?
I had the same problem just before the impeller broke. Lower the handle and check the hose connection at the bottom is not broken. Turn the unit on with the handle down, then check the suction on the accessory hose, leae it disconnected. Take off the bottom container, and check the suction on the round intake tube (lower one towards the front), with the handle up and with the handle down. If the suction increases dramatically when the handle is lowered, the impeller is probably in it's self-destruct stage. (same as mine). Soon the impeller will break off, and BINGO no suction at all.
Posted on Jun 28, 2008
Why does red ball stop operation?
Hi there! The red float is there to let you know when your dirty water tank is full and needs to be emptied. If the float is popping up and the dirty water tank is empty or not full this is an indication that the dirty water tank filter is dirty and needs to be cleaned or replaced. Follow the link below to order a replacement filter for you vacuum.
Search Results
Hope this helps!
Jul 28, 2014 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
I have a Hoover Steam Vac. Even though I don't
There in the trigger assembly is a release button that might be broken.
Nov 28, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover Steam Vac
take off dirty water tank look for small screen usually at the top behind tank remove debris from screen!
Oct 19, 2008 | Hoover F7431-900 SteamVac Vacuum
Hoover steam vac not sucking water back up i have super wet floors and no water in recovery tank
I think it is the gasket on top and bottom of the plastic chanel that takes the water up to the dirty water holding tank , Part of the rubber gasket is missing on both the top and bottom. This will alow
air to come in and thus you loose the suction to empty the water into the dirty water bin. My unit is hoover steam vac model F60220-900. I need to know where to get the gaskets.
Aug 28, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
Hoover steam vac
in most cases you will need to replace the dirty water tank assy. this is usually around $40 to $50.
Aug 14, 2008 | Hoover F7431-900 SteamVac Vacuum
Problems with the Hoover Steam vac Heated carpet cleaner
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Nov 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
The automatic shut off
Check the filter on the inside of the lid for the dirty water tank. It needs to have a 1/4 in. gap from the top of the lid to the top of the filter.
Oct 13, 2007 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover F5906-900 Steam Vac
Make sure that that the lid for the dirty water tank is locked on to the bucket, the other is make sure that the filter on the inside of the lid is not all the way up, needs to be a gap 1/4 inch or so.
Aug 19, 2007 | Hoover F5906-900 Upright Steam Vacuum
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
215 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
