Question about Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark X1185 when printer goes to print the paper feeder keeps loading the paper crooked . i've looked to see if anything was in printer and theres nothing
  • Anonymous Mar 27, 2014
    Printer shows message paper out when there are paper in the feeder.
  • 39 Answers
It does not take much to dirty up a printer even a little dust, try blowing a can of air, if that doesnt work the printer perferences might have changed either you have to thick of paper or not thick enoughtacording to your printing preferences or the page set up next time you go to print check the page setup
Posted on Jun 29, 2008
Why does paper go in crooked and then jams
Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Mar 09, 2012 | Lexmark X2500 All-In-One Printer
How do i fix my LEXMARK X3430?
If that doesn't help, try to re-seat the cartridges by removing and re-inserting them into the printer. Make sure they are properly seated and secured.
I hope this helps.
Feb 17, 2012 | Lexmark X Office Equipment & Supplies
Lexmark x6650 won't take paper correctly
Leading cause of paper jams or misfeeds is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
Jan 23, 2012 | Lexmark X6650 4-In-One Wireless InkJet...
Hello. I have a Lexmark x4650 printer/scanner/copier and the paper starts to feed thru and then pulls to one side. I am then unable to print my document. Why does this keep happening and how can i solve...
Try to remove the sheets of paper from the feeder. Grab a flashlight and look into the feeder for any foreign objects that might have accidentally fell into it. If feeder is clear, open the printer cover and remove the cartridges. While the printer cover is open, check inside for any obstructions in the paper path. If none, then close the printer cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reinsert the cartridges. Close the cover. Load some paper (avoid overloading). Try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Jun 21, 2011 | Lexmark X4650 InkJet Printer
I don't see a paper jam, but that is the error i keep getting. it will let me print or copy anything. the printer i have is a lexmark x5470
Leading cause of paper jams is debris/foreign objects that have accidentally fallen into the paper feed area.
2. Grab a flashlight and look inside for any debris.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
6. If cartridge area is clear, close the cover.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
Apr 26, 2011 | Lexmark X5470 All-In-One InkJet Printer
I have an lexmark 630 and keep getting the error "load MP feeder plain paper" thanks for the help chip loye chapelthrill@gmail.com charlesloye@gmail.com
Please follow my tips ,When you print your computer before you go to print properties.Setting paper layout choice paper source and enable MP tray then print ok.
keep your mind before print you must be insert paper in MP tray.
Sep 28, 2009 | Lexmark T630 Laser Printer
Not printing
It insists there is a Cartridge problem on the Printer............  In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... Blinking Stopped...........Issue Resolved....... Still Blinking: Remove both the Cartridges take a Paper Towel turn the catridges direction so that u can see a Copper plate with small boxes on it....... Just wipe it twice or thrice with the Paper Towel.......... Now insert it and Power on the Printer and see whether the Lights are still blinking if it is still blinking...... Contact Lexmark at 1-800-LEXMARK Good Luck.........
Feb 01, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Print wont print
You have the paper inserted wrong in the printer. The paper should be inserted behind the feeder wheel that is on the right side of the feeder shoot
May 13, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark X1185 printer will not print color......everything else works fine
the ink is clogged not the cartridge but were the ink feeds into the printer. there should be a cleaner tab in the printer preference tab if available
Jan 08, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark x1180
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Nov 13, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark JetPrinter X1185 All-In-One InkJet Logo
53 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
