Guitar amp output problem - Audio Players & Recorders
  • Graeme Ross
    Graeme Ross May 11, 2010
    Hi, can help you, but need a little more info. Make and model and the problem you have will help.
    regards
    robotek
  • 1,512 Answers
How you going with the amp problem mate?
Posted on Jun 29, 2008
How to connect my mixer to my guitar combo
You don't mention the make and models of the gear you're asking about, so we can't address your pacifist setup. However, most mixer outputs are going to be at line level, whereas a guitar amp inputs are instrument level. Line level is way hotter than a guitar amp can handle. You need to find a mixer that has a -10dB output to do what you're asking.
Jun 24, 2016 | Music
Not reconizing input of guitar
Read your manual good and check settings. Look for master volume and pan outputs. Make sure it is connected properly to you amp. You have a left and right output, also check the amp/line switch. You can find your manual here http://line6.com/support/manuals/
Mar 03, 2013 | Line 6 Floor POD Plus Guitar Multi Effects...
I just purchased the UCG102, and connected the output on it to my guitar amp. The result is an extremely loud buzz sound that doesn't allow me to hear anything else. I'm using a lapop, USB from the...
It is happening because you have a ground loop. You need to check the ground on your amp. If it is an old one that does NOT have a three wire cord, you need to have that changed. Failure to do so could also damage the interface. ALL your equipment, computer and guitar am should be powered from the same receptacle. If you have other devices connected to your laptip such as printer, they too MUST connect to the same receptacle or plug strip. Any phone lines should be disconnected from the laptop. Make sure everything has three wire cords. The interface probably sends out line level, so you should use a low gain input of the amp and use very little gain as the interface probably has 20 or more Db output than a guitar.
Mar 17, 2011 | Behringer Ucg102 Guitar To USB Interface
I want to connect a guitar and mini amp so i can use the multi-fx processor. can you help?
Connect the guitar out to the FX input and connect the output jack of the FX to the Amp input.You will need two guitar cables for that.bobhifi_8.jpg
Mar 11, 2011 | Audio Players & Recorders
I plugged my guitar into the amp one day only to get no sound from the guitar. The amp is working - I plugged a different guitar in and it worked - but the guitar seems unresponsive.
If the guitar is active and the battery is dead you will not get any sound. If the output jack or some of the controlls have been twisted and may have broken the connections on the inside.
Feb 11, 2011 | Washburn Electric Guitars Modelno X11B
My fender hot rod deluxe is distorting in clean channel when I push the volume past 2
Realize that the number on the volume control is only relative... it means nothing regarding what the amp can produce. With a high level output guitar you can easily drive the amp into distortion at very low volume control level settings... what counts is the actual output sound volume and specifically the voltage output going to the speaker. Once the amp reaches saturation, any further input just pushes it into distortion or "flat topping".
An oscilloscope on the output will quickly show when amp starts to flat top.
Jan 17, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Should I run my guitar through the High z aux. Or the low z balanced for best results ?
I assume you are wanting to connect the output of the receiver into the input of your guitar amp. Use the 1/4" output on the receiver to the 1/4" input on your guitar amp.
Dec 23, 2010 | Shure PGX14 Guitar Wireless System (UHF)...
Guitar Problem I Think.
First check your guitar to amp cord.
The pickup, audio jack, or pickup selection switch may be defective.
Nov 04, 2008 | Washburn Amplifiers: 25 WATT Guitar...
I've just got a tascam dp01cf recorder and i'm having trouble with it, its abit hard to understand what to plugs in were, i'm using a electric guitar,a yamaha magicstomp effect pedal and a amp. also i'm...
You have a couple of options with your guitar input. You can either plug your guitar directly into the right (Hi-Z) input and use the Tascam's onboard effects with it instead of your effect pedal.
You can put your pedal in the chain between your guitar and the (Hi-Z) input. So guitar into pedal is, pedal out into Tascam Hi-z in. (Still doesn't use the amp).
Or my preferred method for recording guitar would be to mic the amp. In that case you'd just input a microphone (placed about 8-12 inches from your amp) and record your guitar that way. The mic would be plugged into either one of the Tascams two mic inputs to record the amps speaker output while your guitar, pedal and amp would just be hooked up in the normal way.
Please note: Never plug the output from an amp into any of the Tascams inputs. Those inputs are line-level and the speaker output level which comes out of an amp out would damage your Tascam.
To get a backing song into a track in your Tascam, you'll have to first, using a PC, get the song into a 16 bit mono Wav file format. Then you'll have to use the USB import function to copy that wav file onto your Tascam onto the CF media cards fat partition. From the you'll be able to import it into the Tascam choosing which track it will import into.
Cheers,
BD
Apr 17, 2008 | Tascam 2488 Portastudio Multitrack...
26 people viewed this question
 Grubhead
Grubhead
