Question about Garmin StreetPilot C330 GPS Receiver
Garmin c330 gps
While in use, my garmin c330 simply froze. Screen and all dials/on-off buttons are frozen. Can you assist?
  • victor watson Jun 30, 2008
    My unit freezes at different times. I have reseted and it will work for awhile then it will go back to locking up.
Reset button under thin band on face plate. mine did the same thing
Posted on Jun 27, 2008
Frozen Screen
I had this problem and the only way to solve a frozen screen is to let the unit run out of battery and bring it back to life. Battery will die out on you for 6~8 hours. Once battery is dead you must do the following.
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 28, 2009 | Garmin StreetPilot C330 GPS Receiver
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Frozen screen screen is frozen and wont power off
2 OPTIONS
Feb 28, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin c 340 froze- what do I do
This solution is for c330 but it should work the same...
It took a nap...
Jan 21, 2009 | Garmin StreetPilot C330 GPS Receiver
My Garmin streetpilot c330
peel off the plastic part that says Garmin that surrounds the screen.. there is a button there that says reset.. press it... though.. you may lose some data.. not sure.
Oct 22, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin C330
IS the battery charged fully? Try turning it on while its plugged in.
Oct 07, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c330
Look near the SN # and press the reset button.
Jun 19, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c330
You will need to reset the device.
1. On the silver faceplat, under the word "Garmin", there is a tab. Remove the silver-ish fram carefully by pulling on the tab with your nail then by the sides.
2. once removed, press the reset button.
3. Once reset, the unit should work properly.
May 16, 2008 | Garmin StreetPilot C330 GPS Receiver
Streetpilot c330 Frozen on.
take the face plate off of it, and to the right of the screen there is a reset button
May 04, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin C330
put your thumbnail under the silver faceplate above where it says garmin and on the right you will see a reset button. It will reset your garmin and you will not lose your information. Hope this helps.
Patti
Dec 12, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
78 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
