There is a break in the cable of my Sennheiser PXC250, it is right next to the male jack, is there any way i can fix this easily?
  • 682 Answers
Better to change it with same one from near radio shack near you
Posted on Jun 25, 2008
Need the cables for crate flex wave footswitch
They look to be 1/4" stereo male to male jacks (known also as TRS). I don't know where you are but they are easily available.
You need a pair of them at the length you need.
e.g. SHORT 1m 6 35mm Stereo TRS Jack Plug to Guitar 1 4 Jack Male Musical...
Jul 02, 2016 | Crate Music
Sennheiser 126 connect to tv
You should be able to hook the tv to the cable box the cable box should have your A/V jacks. If so unplug the PS3 plug in your receiver to the cable box and run the PS3 through the receiver. Also check the side of the tv for HDMI inputs if you have HMDI you can go to Radio Shack and get a converter to go from HDMI into A/V
Nov 07, 2013 | Sennheiser Audio Players & Recorders
We are trying to hook our TV up to our computer to use it as a monitor. What cords do we need to do this besides the normal monitor cord?
if you want audio as well, it will depend on what kind of audio connection your tv has next to the VGA (computer monitor) connection. If it looks like the normal RCA audio, (red and white plugs) you will need to get a male headphone jack (to plug into your computer headphone or speaker out jack) to stereo RCA cable so you would have a headphone jack on one side of the cable and a red and white plug on the other side. Now if your TV just has what look like a headphone jack next to the VGA (computer monitor plug) you will need to buy a male to male stereo headphone jack cable. for both of these, just make sure the cable you get it long enough, or buy an extension.
Mar 21, 2011 | Sansui HDLCD1908 19 in. LCD TV
Hello My name si Christopher and I have a Sennheiser E815S microphone and was wanting to know how can I get it to work on my PC?
Christopher, your microphone is a dynamic type with XLR connector. This means that you can connect this microphone at your pc (at the mic in connector, the red one) using a cable with XLR female connector at one end and 3.5mm jack male connector at the other end (like this). Keep in mind that the 3.5mm male connector has to be a mono type, a stereo one will not work. In case you have the connectors and a suitable cable you can connect as follows:
YOU MUST CONNECT BOTH 1 & 3 pins from XLR side at the ground point of the jack.
The whole setup won;t give the best sound quality, but it's the simplest and cheapest way to use your mic and the pc. In case you need better quality, clarify me what you are trying to do order to give you some suggestions.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Jan 31, 2011 | Sennheiser E815S Professional Microphone
My headphones don't work, but the wires are not broken. only one side works if you put pressure on the jack.
What you describe means that there is a connection problem at the jack end. e don't if it's at the male jack (the one at the cable) or at the female one (the jack on the device). Check your headphones at another device to clarify this. If the problem is active on the other device too, you have to fix the male jack. In order to do this, you can easily change this end with another jack (complete jack and part of the cable from another headphones) by connecting the cables. The best solution is to change the jack with another one and solder the cables but since these cables are very thin, it isn't so easy.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Oct 02, 2010 | Skull Candy SCSBP35 Consumer Headphones
I cannot connect the Ethernet male end into the female end
On the male end of the cable there should be a little plastic clip that sticks up, this is what holds the cable in and if you want to disconnect the cable you will have to push done on this clip to release it. These are prone to break off and if it does break off your best bet is to buy a new cable. These can be replaced but will cost about the same as new cable and are not as reliable.
moz-screenshot.pngRefer to this image to see the clip I am referring to: http://www.nuggetlab.com/comptia_files/equipment/net_CAT%205%20cable%20with%20RJ-45%20connector.jpg
Jan 13, 2010 | Dell Inspiron 5150 Notebook
Hi, could you please provides a circuitry diagram for PXC250.My headPhone was broken, i'm gonna to fix it.cheers!
Looking at them from the picture provided by FixYa, I rather think there's no circuitry involved! It looks like the wires go into two speakers. As you don't say what the fault is then I will guess a few things for you and some solutions.
1 One side dead - fault in plug or cable or speaker.
2 Cutting out - faulty cable or plug.
3 No sound - faulty cable or plug.
If you need to get to the speaker, remove the pad, remove foam (force it if it won't come off, glue on when finished). You should see screws then.
You should be able to get a new cable/plug from any good electrical parts shop such as Maplin or RadioShack. You will probably need to contact the maker for a new speaker.
Dec 16, 2009 | Sennheiser PXC 250 Consumer Headphones
Connection to tv from my pc to watch live action
Hi there.
The audio out or headphone jack is located at the front of the laptop and is coloured green.
Get a male to male mini stereo jack ( about 3 meters ) and you will be in business!!
Good luck and thanks for choosing FixYa!!
Jun 01, 2009 | Acer Aspire 3610 Notebook
Trying to sort aux-in
as you do not mention the model I have to guess that your player has a aux-in on phono (or RCA) jack. If you want to plug the iPod just buy a "Twin phono to 3.5mm stereo jack cable".
You can find in many superstores or Maplin.
Mar 30, 2008 | Audio Players & Recorders
Cahnging plug
The standard HD25SP cable's 1/4" jack screws over the mini-jack. There's no reason for you to do any soldering. If you have a few inches of cord left from where you cut the plug off you may want to re-splice the cable back together to their corresponding colours. Then unscrew the 1/4" ******** to reveal the mini-jack.
Oct 11, 2007 | Sennheiser HD 25 SP Consumer Headphones
 Grubhead
Grubhead
