Question about Indesit W 123 Front Load Washer
Indesit WIDL 102
HELLLLLP! Part way through a wash programme our Indesit WIDL102 washer dryer stopped working and all lights went out. Thought a fuse had blown so replaced it but on reinstating the power lights 1 and 4 flashed and the power light (red LED) flashed. After a couple of minutes the lights changed to 3 &4 and the machine cycled water for about 3-4 mins (water coming into the machine and being pumped out).
I believe the error codes indicate
a) f09 lights 1&4 eprom/setup error
and
b) f03 lights 3&4 Ntc fault
But have no idea how to remedy these
Tried powering off for a few mins and then back on - same scenario as above repeated.
What's my next step (the tip?) - the machine is about 18 months old.
Cheers Martin
  • lazylad2001 Jan 31, 2009
    my washer drying seems to have the same sort of issue, it starts and then stops and just spins a few times very slowly but the cycle doesnt end. i have tryed it on a driffrent setting but it does the same. I can risne and then spin it on there own cycles but cant pu it on a cycle and say go out come back and expect it to be complete as it wont be!!!!! it it is the controller its about £100.00 and i dont think it is worth it get a new one.....
    Habit-Forming:
    New Friend:
  • 81 Answers
Try to find an answer in this manual Indesit WITP 1021
Posted on Jun 18, 2017
    President:
  • 1,462 Answers
Almost certainly a new module and eprom. these modules have given a lot of problems.
not really worth doing
Posted on Jun 25, 2008
Indesit widl 146
Firstly look to check nothing is stuck in the pipes as in coins or wire from bras etc..these will always cause problems for the machines... if this isnt the problem it may be a fuse. Or worst case senario one of the boards needs replacing.
Mar 17, 2014 | Washing Machines
Indesit Widl 102 Flashing lights, wont turn on
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and/or its panel that is going bad. To start with check the Thermal fuse which is mounted to the exhaust duct inside the back cover panel. Please do accept the solution if the issue is resolved or post a comment with a more detailed question including the manufacturers name and model no# for your dryer so that I can further assist you.
Thanks
Rylee
Jun 14, 2010 | Indesit Dryers
WIDL102 indesit washer dryer not working properly
check heater element/ should read about 32ohmns on multimeter if not reading replace,if ok replace stat
Apr 03, 2010 | Indesit W 123 Front Load Washer
HI WHEN I TURN ON MY MACHINE ALL THE LEDS KEEP FLASHING. IT IS A INDESIT WIDL 102 WASHER DRYER.
Hello, this usually is signaling that there is a problem in your machine. You will need to get a service technician in to diagnose the problem for you. I hope this is somewhat helpful.
Nov 04, 2009 | Indesit WA 115 Front Load Washer
Indesit widl102 washer dryer has 2 led lights flashin
unplug it for a few minutes and plug it back in again might be a pain but till you can get it serviced it should delete the fault code and run thru a full cycle. hope this helps a little.
Not a true fix just a work around.
best to you.
Nov 30, 2017 | Indesit W 123 Front Load Washer
Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
Dec 01, 2008 | Indesit W 123 Front Load Washer
Dryer geting to hot
When that happens it is usually because of a broken thermostat or a devective vent system, see : It overheats.
Nov 20, 2008 | Indesit W 123 Front Load Washer
My Indeset widl102 washer dryer
sounds like a faulty water valve if not pcb or pressure switch sorry cannot be more precise but thats indesit for you regards jason
Jun 12, 2008 | Indesit W 123 Front Load Washer
Indesit washer dryer stops halfway through a wash....
depends on what lights are flashing this is your fault code
Mar 28, 2008 | Indesit W 123 Front Load Washer
Indesit widl 102 extra rinse button always on!
Check that the button isn't stuck it if not remove top lid and check the PCB and see if the switch hasn't collapsed causing it to be on all the time. Also if you hold in the go button for about 5 seconds this resets the program try this.
Thanks J
Feb 07, 2008 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
997 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
