Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
My red convergence is out, and it will not change
Ia have gone through the simple convergence through the menu, and red will only change at some places. i did the Mute 183 thing, and was able to get it onto red, and able to move some of the places to allign it with the green and blue, btu in other areas, it won't move at all. is there a simple fix? my TV is just 4 yrs old, and i would think it should last longer than that. we haven't used it excessively, probably only 5-10hrs/week. I have a similar problem. I guessed at the Mute 183 route, and got all the bars to line up. Now I need to know how to same the settings. Once I hit Exit, after aligning all the colors, it goes back to the way it was before.
  • 27 Answers
When thes tvs get around 4 to 5 years old the convergence go's out on them there are 2 stb's or someting like that it may be stc's i can't remember what they call them it's been so long sence mine did 1 has probbly went bad i chould control the red but not the blue and sometimes when this happens it will also blow green fuses as well in my books they should put cooling fans in these tvs to help cool them there is to much heat inside the tv thats why they only last a few years before having that problem i have 3 of them and all three of them did the same thing you can check the remote eye on the front of your tv sometimes when there is a problem the green remote eye will flash acode but you will have to have the service manual to find out what what the code means
Posted on Jul 01, 2008
Red tint around picture, images and such. seems like projector may be offset... with red... any ideas would be appreciative... Thanks.
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 09, 2011 | Samsung HCM553W 55" Rear Projection...
Unable to adjust red convergence much red shadowing
Not able to do auto or manual convergence adjustment.The tv convergence board is dead.The tv convergence board,must be replacing 2 STK convergence ICS and some or all of it resistors too.To fix the convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Mar 02, 2011 | Philips 60PP9202 60" Rear Projection...
RCA HD52W66 Television convergence is screwed up and gone from the set up menu
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 25, 2011 | RCA HD52W66 Projection Television
Convergence is gone from the menu
Please do us a favor and rate this solution after reading.
  • Screen looks 3D
69189a5.pngSOLUTION
Thee green on my Hitachi 43fdx20b has gone wacky, ive seen an answer to if the red and blue go wierd but not the green. What can I do to save my t.v.?
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 24, 2011 | Hitachi 43FDX20B 43" Rear Projection...
Experiencing convergance problems in upper left hand corner on Samsung PCL541R mostly red shifted to right and down Bottom right half of screen is clear Do I need to replacer convergance chips?
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 18, 2011 | Samsung PCL541R 54" Rear Projection...
Picture stays red with blue background and adjustments make no difference
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 17, 2011 | Philips Magnavox 9P6034C 60" Rear...
Picture is almost black and white but bleeds red
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 10, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Have red line running horiontally across screen..Magic focus is no help
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 09, 2011 | Hitachi 43FWX20B 43" Rear Projection...
Shadows of green and red in picture
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 08, 2011 | Zenith R50W46 50" Rear Projection...
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
121 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
