Question about Hotpoint Washing Machines
Hotpoint WT741P is showing fault code F8. What does it mean?
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Hotpoint Aquarius WT740 Fault Code
Hi. F05 means pressure switch jammed on full.
Check pump for blockage and that it is working, if no joy you will have to call an engineer
Posted on Nov 20, 2008
barkencoa
  • 3463 Answers
SOURCE: Hotpoint WD860 - Fault Code F-07
F07 indicates heater relay stuck.
You need to check the heater to see if it is faulty, and fit new one if it is.
Please rate my solution.
Thanks.
Posted on Jul 10, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have an F8 fault on my hotpoint wf860p
f8 is shown when the heater circuit is on with no water in.. it doesnt do it when you unplug the pressure switch because your disabling the heat protect circuit
THE BOARD IS PROBABLY FAULTY
F08 indicates pressure switch stuck on full.
Unplug the appliance from the wall socket.
Take the top off the machine.
Locate the pressure switch, you can identify it by the thin tube attached to it.
Take the tube off, blow down this tube as hard as you can to shift any blockage or restriction in the pressure chamber. Give the pressure switch a couple of good taps with the screwdriver handle.
Refit the tube and try the machine again.
If still doing it, unplug again and follow the tube down.
This end will be attached to the pressure chamber.
Take this chamber off and thoroughly clean it out, clean out the port into the tub too.
Reassemble and try again.
If after this it's still faulty you'll need to start replacing parts.
I'd suggest trying a new pressure switch first.
Failing this, if all of the above fails to resolve the problem you're possibly looking at a faulty main control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 16, 2010
Tip
Common faults on a hotpoint tdc32
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning open circuit)
4 Modern tumble dryers also have sensors and pcb's (Printed circuitboards) these have programs that can fail and circuitry although most should produce an error code showing you were the fault is.
5 Faulty connections and burned wires may also bethe fault.
For Free Video help on yourHotpoint TDC32 Tumble Dryer USE THIS LINK
on Jan 17, 2010 | Hotpoint TDC32 Electric Dryer
Hotpoint Aquarius wf 325, why does the on/off switch flashes and programme cuts out
Does it show a fault code. You can look up what these mean on hotpoint/Indesit website. We had issues with our machine when water pressure was low but works fine when pressure ok ( showed code For that). When it had a motor not moving fault code we found it cheaper to use Indesit own repair as it gave a fix or replacement guarantee for 1 yaer The parts needed would have been over 200 pounds and wee now have 15ish per month repair contract and no other charge. (only lasts 1 yr). Our local repairer said circuit board and motor over200 + 100ish labour.
Jan 14, 2015 | Hotpoint Washing Machines
My washing machine shows F-05
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Hi, the above web page shows fault codes and what they mean for Hotpoint machines
Mar 02, 2011 | Hotpoint Washing Machines
Hotpoint ultima wt741p is showing F:01 on the display screen when the machine starts up -the machine starts but no water comes through and the drum stays idle - any advice please ????
F:01 is display say some error problem occur in your machine, maybe the motor that pump water to fill the machine has not working or its sensor that water is flowing is not working also.
Jan 29, 2011 | Hotpoint Washing Machines
Hotpoint wd860 fault code F8 what does this mean
Hello,F8 is simply a component failure and you need to replaced the electronic range control (ERC).
Thanks
May 23, 2010 | Washing Machines
Hotpoint ultima washing machine is showing a fault
F 05 normally means there is a blockage or a fault with the pressure sensor. The common place for blockage is in the black pipe from the drum to the pump as it has a filter in here and clogs up. remove the pipe and clean the filter out and remove gunk from the pressure sensor on the side of the pipe as well. If that does not fix things the pressure switch could be faulty itself
Sep 13, 2009 | Hotpoint Ultima WF860 Front Load Washer
Thanks.
Jul 10, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Thanks.
May 30, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
On a hotpoint aqualtis aqxx149pm i get error code f8 flashing
Hi.
F8 means that heater relay cannot be activated, you need to call an engineer.
Could be expensive, possibly a new control board needed
Nov 19, 2008 | Hotpoint WMA35 Front Load Washer
Washing Machines Logo
42 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
