Question about Toshiba Satellite A105 Notebook
Cursor lockup We have the laptop connected to a projector; powered up the projector first then the laptop and the cursor works momentarily and then freezes.
  • VickyN Jun 26, 2008
    We ended up fixing the problem by using the Fn key along with one of the others in the top row - can't remember which one worked because we tried them all and suddenly it was working. We're going to look into getting one of those wireless meeses too - thank you!
  • Anonymous Aug 14, 2008
    About every three days my cursor locks up for 10 seconds or so and then is fine for 15 to 30 seconds before it locks up again. During the lock up time the task graph shows a 99% use of my RAM (at 1.256 GB) and during the whole time, even when the cursor is working, my bottom CD drive (read only) will not open and the light will not even blink but the top one works fine. To fix it, I reboot and then the bottom CD driver will work. ( I have done all the de-frag and clean ups plus dumped a lot of unneeded programs.) Dell XP3 2.33 GB - 1.256 GB RAM Steve D.
  • 2,028 Answers
This is generally cuased by a software conflict. You can eliminate this by purchasing an external mouse. Walmart has a nice little wireless Microsoft mouse for about $20.
Posted on Jun 25, 2008
Why doesn't my My McBook now running operating system 10.7.5 no longer work with the WPS-Dongle 2 ?
Upgrade issue. Why did you upgrade? Was it absolutely necessary? Upgrading should only be done as last resort because often it results in peripherals that worked no longer working. And if manufacturer of peripheral does not provide a new driver or patch you are SOL.
Aug 24, 2017 | Optoma WPS-Dongle 2 - network adapter
How can i reset de lamp time
With the projector running hold the right cursor key, down cursor and the enter button down switch the mains power off.
Still holding these buttons down power the projector back on. it will take a few secounds for the lamp to light up.
When it does you should see lamp hours 0000
Hope this helps
Mar 23, 2011 | Sharp PG-A20X LCD Projector
I have a panasonic projector model no.PT-AX100E. It is currently turning it self off after about a minute when i turn it on. There are no flashing on the lamp or temperature leds. The lamp has about 1100...
Enter the service menu under self check and you will most probably see that the fault is cause by the iris (will be in red). The iris needs to be oiled so that it can open and close again properly (you can find a youtube video showing you how to do this).
Enter Service menu like this:
From the projector being on, press the power button to turn it off then press:
Cursor left
Cursor up
Cursor down
Cursor up
Cursor down
Sep 04, 2010 | Panasonic Office Equipment & Supplies
Acer computer won't work with LCD projector
Have you tried a lower resolution?Update the drivers for the video card.
Good Luck
Oct 17, 2009 | Acer Computers & Internet
Cursor stops moving and i have mess with battereis to get it going
1st check to be sure the batteries are BOTH good.
Power light on does not always mean there is enough to do the job.
2nd if the contacts are loose then slightly pry the contact out a little.
I do mean just a little! All your trying to do is make a better contact.
3rd make sure the batteries AND the contacts are clean!
Any corrosion or dirt/dust may momentarily cause the batteries to disconnect. Once this happens the cursor stops. No power, no cursor movement is possible.
Oct 03, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Mouse pad cursor doesn't work
try using the FN key with the monitor/VGA output selection changer(usually F5). You will see a little icon that looks like two monitors. Mouse control may have been changed to the external monitor connection. See if pressing FN(function) and holding that key and then pressing the monitor key will bring back your mouse indicator. You may need to do it with the projector connected and on.
Sep 12, 2009 | Toshiba Satellite A135-S4527 Notebook
Mouse doesn't alays work.
check the hard drive for any problems and re-install the drivers for the mouse
Nov 16, 2008 | HP Computers & Internet
Cursor lockup
This just because that there are too many services running in the background of the Operating system
All you need to do is to manually disable maximum of them and disable all the startup Items
Here is how you can do that the easy way
Manual steps to perform a clean boot in Windows XP
Step 1: Start the System Configuration Utility
Click Start, click Run, type msconfig, and then click OK.
The System Configuration Utility dialog box appears.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box.
5. Click the Services tab.
6. (VERY IMPORTANT DON'T MISS THIS) Click to select the Hide All Microsoft Services check box.
7. Click Disable All, then Click on the startup tab and click on Disable All Button and then click OK..
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. Log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK:
You have used the System Configuration Utility to make changes to the way Windows starts.
The System Configuration Utility is currently in Diagnostic or Selective Startup mode, causing this message to be displayed and the utility to run every time Windows starts.
Choose the Normal Startup mode on the General tab to start Windows normally and undo the changes you made using the System Configuration Utility.
Step 4: Optional step to disable features
This step temporarily disables Microsoft features such as Plug and Play, networking, event logging, and error reporting. Also, this step permanently removes the restore points from the computer. The System Restore feature uses restore points to restore your computer to an earlier state. If you remove the restore points, you can no longer restore Windows to an earlier state.
1. Click Start, click Run, type msconfig, and then click OK.
2. Click the General tab, click to clear the Load System Services check box, and then click OK.
3. When you are prompted, click Restart to restart the computer.
Steps to configure Windows to use a Normal startup state
2. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
Aug 14, 2008 | Microsoft Windows XP Home Edition
Reset lamp timer
you need to enter factory Menu.
You do so by doing the following:
1).Start the projector.
2).Press keypad <Source> and <Auto> keys simultaneously, enter " Lamp Hour info" layer
3). Press <Source> and <Auto> keys simultaneously again, then enter factor menu.
Do not change anything till you reach Lamp Layer where lamp hour and usage hour is given. If you reset, then all data revert to default - factory reset. you may chage here or under (2).
Let me know if this solves your problem.
Sep 03, 2007 | LG RD-JT30 Multimedia Projector
Toshiba Satellite A105 Notebook Logo
107 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
