Question about Cameras
Have a minolta x-7a that was in storage for a while - replaced the batteries - a little corrotion on the screw plate - installe new roll of will and can not get the shutter to activate so that the film will advance - took our and replaced several times - till will not advance - do not see the red mark on the top that shows film is load - help - want to start using again
  • 2 more comments
  • grayallenl Jun 25, 2008
    this is NOT a digital camera and I have cleaned the battery contacts and batteries
    does not make sence to hold the on button for 20 to 30 MINUTES - it is a slide switch - do you mean hot the shutter button instead?? and for that long??
    this does not make sence to hold a slide switch for 20 to 30 MINUTES - that isn't going to work!
    all contacts and batteries were cleaned with contact cleaner - this is not the answer
    Sergeant:
  • 260 Answers
  • straightforward repair is recommended. You may need to replace the aperature.
  • This is beyond batteries. This is going to require deep cleaning by taking it apart and putting it back together
  • Even if we get you to do something simple to get the film to advance again, it is very likely the pictures will not be the quality you expect.
  • If you feel comfortable doing this yourself then we can work on the solution with you. but his will take some time and when you are ready we will probably need to chat with you to complete this project.
Posted on Jun 25, 2008
  • Ken Jones
    Ken Jones Jun 25, 2008
    See if the winder connection (round chrome ring with spring-loaded slotted edge) at the base of the camera body can be gently 'flicked' with a coin or similar to release a mechanical catch of some kind.
  • Ken Jones
    If you need i can send you a link for a mail order repair shop that will not charge you unless the camera is fixed. They specialize in repairing cameras that do not have replacement parts anymore.
    Sergeant:
  • 275 Answers
I think you need to clean battery contact plate since it got corrosion. www.konicaminolta.com this is your company website. click to this link......
    Genius:
  • 2,028 Answers
Storage causes electrical products to gather dust and corrode, sounds like it's in fairly good condition, however I would take it in for a professional cleaning. This should work out the little bugs.
  • Ryan Rogers
    Ryan Rogers Jun 25, 2008
    When I said cleaning I was refering to an internal cleaning. With a professional (internal) cleaning, they will not only clean out any dust build up inside the camera, but will clean any corrosion on electrical contact points as well.
    Master:
  • 848 Answers
You are having sensor problem in your minolta x-7a ..........since you have not used for long time it will better to put the battery and press the on button for 20-30minutes .......the sensor will function again
Minolta X-7A SLR 35mm Camera Shutter is only half closing when taking pictures.
Issue with Shutler... Take Off Lens check for dust or banding plate inside...carefully try to open or close the shutler if not ...Refer to a professional Repair shop ...
Oct 01, 2010 | Minolta X-370S 35mm SLR Camera
Minolta x-7a
Follow the illustrated instructions in the manual you can download from http://butkus.org/chinon/minolta/minolta_x-7a/minolta_x-7a.htm
Jul 04, 2010 | Minolta X-370S 35mm SLR Camera
Help with minolta x-300s, i cant seem to move the film winder
Well, here's the most likely things going on:
1. dead battery. Your X-300 has an electronic shutter that needs battery power to work. Try fresh batteries and check the battery contact wires for corrosion.
2. End of roll. If you have film in it, try the silver button on the bottom. rewind film and try another roll of film. Before you put in the new film, try the advance, click, advance, click thing.
3. Not all rolls of film are perfect. Some are shorter than they should be, some hang up in the canister.
4. The Minolta X-series were well known to have a problem. Two cheap capacitors on the later models would die, locking up the camera. One is under the top plate and the other under the bottom plate. These caps need to be replaced. I suggest you send it to a repair shop for that. Check prices. Garry's camera repair in Niles, IL does a very economical repair on these. It runs about $50 and $8 for return ship. He will also Clean, Lubricate and adjust it.
You could also buy another 300/370 on Ebay, as they're inexpensive these days.
Best of luck. Hope its just the film or batteries. You might also consider joining the Yahoo Minolta groups.
Jan 19, 2010 | Minolta Photography
Maxxum 7000 My Program Back 70 has the display "flashing" like it needs a replacement battery. Any ideas on what is causing this. I looked and it does not seem to have anywhere to hold a lithium backup...
take off the battery holder and remove the screws on the metal plate. gently lift the plate and replace the battery. remember the different length of the screws.
camera may need a little time to for the circuit to energize.
Dec 30, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Loaded film camera will not work asks for program how do i do this How do I set the program on my Minolta Maxxum 7000
it might be the internal battery. remove the battery holder and remove the screws on the metal plate. gently lift the plate and replace the battery. remember the different length of the screws.
Oct 29, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Can you tell me where is the lithuim battery of minolta maxxum 7000? I want to replace it tnx in advance
remove the battery holder, then remove the screws on the metal plate, remember different length of screws. gently lift the plate and replace the battery. it may take a while for systems to turn on.
Oct 25, 2009 | Minolta Maxxum 7000 35mm SLR Camera
How do i replace clock battery
remove batt. holder, then remove screws on metal plate. carefully lift plate. replace batt. then plate. remember different length of screws. it may take a while for systems to power up.
Aug 25, 2009 | Minolta Maxxum 7000 35mm SLR Camera
My Minolta X-700 with new batteries is still dead
dcates
you will need a jewelers + type screwdriver. just turn screws to the left, remove the screws and bottom plate. push re-wind button in first. check the small white gear at the bottom of take up spool. if its broken it may be hard to replace as no new parts are available for this model.
Jan 01, 2009 | Minolta X-700 35mm SLR Camera
Minolta maxxum 7000 35 mm camera
I had the same problem. After I replaced the lithium backup battery, everything works perfectly. It is a CR2016 watch battery and it is located behind the silover plate inside the battery compartment. Remove the 6 screws and replace the battery. Note the polarity when you remove the plate because the camera will not operate if if it is put in backwards.
H
Nov 14, 2007 | Minolta Maxxum 7000 35mm SLR Camera
Cameras Logo
49 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
