Question about GE Profile JT912 Electric Single Oven
NEFF Oven Model B1430NOGB/02 Oven Temp not heating above @50 degrees
Hi, My Circotherm fan oven does not heat up above about 50 degrees. The fan runs O.K. and the thermostat light goes out once higher temperature setting is reached although the heat within the oven does not match the Temp setting. Can you help me decide if I should try changing the Element first OR would it be the Thermostat or Thermostat regulator that is at fault?
Hope you can help, Many thanks, Louisa
  • 3 more comments
  • Coastguard3 Jan 19, 2009
    Same problem. Did the suggested solution work?
  • Anonymous Mar 23, 2014
    the temp is off by 50 degrees
    thermostat fault
  • Anonymous Mar 31, 2014
    When I set the oven thermostat selector to 300 degrees the oven heats up to around 350 degrees or more. Everything else seems to work fine.
  • Anonymous Apr 01, 2014
    vedo273ss oven will not heat to 350 degrees or above. Where to purchase heating element and how to replace it.
    President:
  • 1,462 Answers
Probably the element. to save wasting money, check continuity with a multimeter
Posted on Jun 25, 2008
What is rhe best temperature for cooking bread in the Neff 1451 oven?
On circotherm at around 210 in a preheated oven for first ten minute, then drop to 190 until finished. For a 2-2.5lb loaf that would be 10mins followed by 20-30mins depending how dark you want it. On the neff ovens down the left side the shelfs are numbered 4 at the top down to 1 at the bottom... you should use the shelf set on 1 or 3 (**NEVER IN POSITION 2**). Good Luck. Hope this helps.ps you can prove the bread in the oven by setting the selector to 'fan' but with no temp, the heat from the lamp will create enough heat (obviously the bulb/lamp need to be working!!)
Sep 14, 2011 | Neff B1451 Single circotherm plus Electric...
Hi - have a Neff U1721 double oven, the element in main oven went bang cracked the element and blow a hole in fan cover. replaced the element but now temp light comes on but doesn't heat up, can you...
Test element check for continuity across the terminals and it is getting power when switch onon. If both ok, chances are the front selector switch has blown.
Feb 01, 2011 | Neff U1721 Double circotherm Electric Oven
Hi there, Neff B1432 was working perfectly this afternoon, but this evening when cooking 2 racks of lamb it wouldn't heat up higher than 50 degrees. Sounds like the thermostat...is this an easy job to...
Could be a faulty thermostat, but I would check that element is getting hot before commiting to replace the thermostat.
Run it for a few minutes and feel to see if you can feel hot air blowing from fan at rear of oven. If no heat present, thei it will be the elemnt that is faulty.
Jan 06, 2011 | Neff B1432 Single circotherm plus Electric...
Neff u1421 bottom oven: Either fan works but no
You need to replace the oven fan element, as there is probably a seperate element in use when used on convection heat.
Please rate my solution.
Thanks.
Oct 24, 2009 | Neff U1421 Double circotherm Electric Oven
Neff faulty Fan
Hi.
I would not think that both fan and element are faulty, although it is possible.
if it has a timer make sure that it is on manual and not on auto, as this would stop the oven working.
Other possible fault is faulty main oven selector switch.
Hope this helps. Please do not for get feedback .
Thanks.
Nov 23, 2008 | Neff U1661 Double circotherm super...
Neff single oven
fan heating heating element gone replace it ;Ire close bye
Sep 04, 2007 | Neff U1721 Double circotherm Electric Oven
GE Profile JT912 Electric Single Oven Logo
454 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
