Question about Canon imageRUNNER C3220 Color Copier
Quality My canon 3220 is not printing as crisp as it use to. Are then any adjustments I can make. Have had service techs. out a number of times. No one can seem to fix it. Thanks
  • deals Jun 25, 2008
    Thanks all of this has been done. As well as all new drums, new fuser, new toner all canon products. I am working from a mac computer to copier.
    Thanks for your help.
    Problem Solver:
  • 6 Answers
Make sure you are only use canon toner NO compatible toner. Same thing on the drum unit. Also make sure scan lense under glass is clean and fixing film unit is good shape,good luck.
Posted on Jun 25, 2008
How do I get my Canon Pixma ip7220 printer to stop printing blurred lines?
Hello, my name is Steve.
This is an early sign of print head failure.
Soon it will give you an error code on display or ill be observed on your computer. The print head nozzles are not firing correctly. The only way to remedy this is to:
1. Have the printer serviced and cleaned ( the cost of the new print head and a cleaning and servicing of the printer
2. Order the print head online and install it yourself. The wonders of the internet can find an give you a video of how to do this.
The part number is: Canon QY6-0082-000 Printhead (Canon QY60082000 Printhead) I hope this helps, Steve
Jul 29, 2015 | Canon PIXMA iP7220 Premium Wireless Inkjet...
Canon Pixma 210 series has an error code 6000, won't print or scan
Hope this helps
With thanks to a canon tech
Ok Well again I will repeat this answer with a titch more detail.
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
May 22, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Serving my Canon PC-6RE Copier.
there are some things better left for others to do. copiers is one of them. you cant explain in a paragraph what needs to be done and how to do it. there are alot of things that can be broken by people who dont know what they are doing. your machine is so old that you cant get parts for it anyway. you would be better off getting a new machine.
Mar 31, 2009 | Canon Office Equipment & Supplies
Canon iR 3220 PS driver printer problem with PowerPoint 07 files
Is it that two other pcs can print to that same printer?
If so are they using a different version of the driver, ttry reinstalling the driver on the non working pc making sure the port settings are correct.
Mar 23, 2009 | Canon Office Equipment & Supplies
Canon c3220 problem!
Normal 0 I have a fix you could try. I ran into this problem when I noticed that the black printouts looked fine, but anything in color was horribly blurry, and you could actually see that the CMYK colors were not aligned on the paper. The following worked for me after removing and cleaning the ITB and all the rollers, and after realigning the lasers after removing the drums, neither of which fixed the problem.
First enter Service Mode, by using the physical keys and pressing Additional Functions, then 2 and 8 on the numeric keypad simultaneously, then Additional Functions again. In the touch screen select "Copier", then "Function" at the top, then "Clear" in the middle, then "DC-CON" near the top of the list. Then hit the "OK" button on the bottom of the screen. Then, back to the physical keys, press Reset, and then Reset again, and you will be back to the main copier screen on the touch screen. Shut the entire machine off, and wait about 10 seconds, and then turn it back on again. Test it out.
For good measure, you should probably also do a Full Gradation Adjustment at this point, by pressing Additional Functions, then Adjustment/Cleaning, then Auto Gradation Adjustment, then Full Adjustment. It will print and you will have to scan it a few times before it is done.
Mar 21, 2009 | Canon imageRUNNER C3200 Copier
I have a canon 3220 N copy machine it copy in black an white very good but in color copying the colors and figures appears oblique! please what is the problem and how can we fix it?
Firstly, you will need to perform an auto gradation adjustment.although the chances of it curing this problem are slim. Enter the additional functions mode by pressing the head key, then select 'COMMON SETTINGS' then select 'ADJUSTMENTS/CLEANING' then select 'AUTO GRADATION CORRECTION' then select 'FULL ADJUST'. The machine will print out a chart and ask you to copy it from the glass, repeating this several times. Now, this is just a measure- your real problem is your ITB assembly (intermediate belt) - the belt can slip as the rollers are dirty when turning. Problem is, you can't do this yourself unless you really know what you're doing. This ITB assy may need servicing or replacing it entirely or in parts if it has done it's life.
Jan 27, 2009 | Canon imageRUNNER C3220 Color Copier
Printer issues
If you are using Glossy paper, when you go to print make sure to go into the printer Properties from the Print dialog box and select Glossy paper in the type. This will put the printer into it's highest print quality mode.
So from most windows applications, it would be :-
CTRL-P (to print with dialog box for changes)
Click on Properties
Select a Media type of glossy photo paper
Select standard or high print quality.
p.s. you may need to experiment which if the media types gives you best quality for the paper your using, unless it's Canon paper and then just match it up.
Oct 29, 2007 | Canon Pixma iP6600D InkJet Photo Printer
Canon imageRUNNER C3220 Color Copier Logo
107 people viewed this question
old marine
old marine
