Question about Philips Magnavox 27MS343S 27" TV
Cannot get 27" magnavox closed caption
We have a 27" magnavox 2005 - closed caption is locked on - no response from original remote control - no response with menu for color, brightness etc.
tried volume up - volume down reset but nothing - any tricks?
I called the Magnavox tech support - put the TV on channel 2,
hit the cc button repeatedly and problem solved.
thanks for contacting me.
Posted on Jun 26, 2008
How to turn off closed captioning without original remote
You must have its remote control to close the closed captioning function.
Dec 24, 2012 | Memorex MT2274 27" TV
Can't get closed captioning to go away,,, can't find it on the menue does anyone know how
Check whether there is a "CC" button on the remote control. If you are using a universal remote control, it might not have this button. As there is no selection for closed caption in the TV menu options, its original remote control will have this CC button. If you are the original remote, press this button once.
Jun 08, 2012 | Norcent Technologies2703 27" TV
How do i turn off the closed captioning setting on my 27
Hello
Without its orginal remote, you can't turn OFF its close caption window.
If you ahve its original remote control, inform me by Fixya comment. I'll assist you to turn off this option. Without orginal remote control, giving any advice to you to rectify this problem, will be waste of time.
Feb 18, 2012 | JVC AV-27D303 27" TV
I can not turn the captions off on my magnovox television
It sounds as if you have the closed caption option activated on your TV. The easiest way to disable this is to search your remote for the closed caption button. It is most likely the button marked CC or Closed Caption. Good Luck
Jan 11, 2011 | Philips Magnavox 27MS343S 27" TV
How do I turn off closed captioning
If you have the original remote control, there's normally a single button that controls captioning. You press it to cycle through the captioning choices until you reach "off". If you don't have the original control, you may have caption control available through the on-screen menus. Not all makes and models provide it, though.
If you're using this TV with a cable converter, satellite receiver or another set-top box, the captions you're seeing may be coming from that device and not from the TV's caption decoder. Make sure you check that captioning is shut off on those devices as well.
Oct 01, 2010 | Philips Magnavox 27MS343S 27" TV
I have problem with our Magnavox TR2510C101. My toddler press everything and now it turns out there is black screen (square) cover the image. Do you know how to fix it? thanks!
You have accidentally gotten the Closed Caption turned on....
Here is how to turn it off....
1) Press the MENU button either on the front of the TV or on the original TV remote.
2) Use the Volume + or Volume - to highlight "SET"
3) Use Channel - or Channel + to highlight "CLOSED CAPTION"
4) Press Volume + to access the CLOSED CAPTION menu.
5) Press Channel - or Channel + until OFF is highlighted.
6) Press Volume + or Volume - to confirm selection.
7) Press the TV/AV/EXIT button on the remote to exit or the MENU button on the front of the TV.
GOOD LUCK and please rate this solution...
Jan 14, 2010 | Philips Magnavox 27MS343S 27" TV
Turning off the closed captioning without the remote.
I had the same problem. I got a Philips Magnavox Universal Remote that has a closed captioning button [CC]. Here's a link to the same type:
http://www.amazon.com/Philips-Magnavox-PM435S-4-Device-Universal/dp/B00006686A/ref=pd_bbs_1?ie=UTF8&s=electronics&qid=1240350929&sr=8-1
Dec 10, 2008 | Philips 20PT6245 TV
Closed caption
The set is in demo mode press the volume upand the volume down button at the same time on the set.
Aug 11, 2008 | Philips Magnavox 27MS343S 27" TV
Big Black box covers screen
On the remote control is a button called closed caption or CC.. Someone turned on the closed caption. Simply turn off the closed caption. That black box is called the text box. Good Luck
Apr 12, 2008 | Philips Magnavox 27MS343S 27" TV
Close caption turns on and off by itself problem
Check the cable box to make sure the captions aren't truned on in the cable box.
If not -if it really is the Magnavox caption service- then -
This is assuming you have the original remote:
1 Press MENU to show the on-screen
menu.
2 Press VOL+ or VOL- until SET is highlighted.
3 Press CH+ or CH- repeatedly to
highlight CLOSED CAPTION.
4 Press VOL+ or VOL-
to display the
5 Press CH+ or CH- to select the
closed caption you want (OFF, CC-1,
CC-2, or CC-MUTE).
CC-MUTE sets
the TV to show closed captions when
you press MUTE. The TV volume will be
disabled until you press MUTE again to
restore the sound.
6 Press VOL+ or VOL-
to confirm your
selection.
7 Press TV/AV/EXIT to remove the
menu.
Feb 25, 2008 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 27MS343S 27" TV Logo
547 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
