Question about RCA Universal Remote Control
LOST REMOTE CODES AND INSTRUCTIONS.
I HAVE A RCA UNIVERSAL REMOTE THE MY KID TOOK THE BATTERIES OUR AND I DNT KNOW HOW LONG ITS BEEN SO THE CODE GOT LOST. I JUST NEED THE CODES AND THE INSTRUCTIONS CAN ANYONE HELP ME?
  • 1 more comment
  • marcoagu42 Jun 26, 2008
  • I don't have the manual but here is how to reprogram the remote without the codes.
  • RCA Universal Remote Control Step1Turn on the component you want to program. Step2Press and release the component button on your remote that corresponds to the component you want the remote to operate (TV, VCR, etc.). The illuminated ON-OFF button will turn on and remain on. Step3Press both the component and the ON-OFF buttons. The illuminated ON-OFF button will turn off, and then will come back on. Step4Release both buttons after the ON-OFF button turns back on. The button should remain illuminated. Step5Press and release the PLAY button. If the component does not respond after five seconds, continue to press the PLAY button every five seconds until the component turns off. Step6Press and release the REVERSE button when the component turns off, then wait to see if the component turns on again. Step7Press and release the STOP button to save the new code.
  • ok i got to step 6 and the TV never turned on. Any other suggestings?
  • biggansj Jul 20, 2008
    im just looking for the codes to a sanyo tv , i have a rca universal remote
  • rdsoccer Nov 11, 2008
    RCA 5-DEVICE Remote Control by RCA Tried code search no luck what are the punch in codes for a 27 inch philips tv?
      Sergeant:
    • 260 Answers
  • Step1Turn on the component you want to program. Step2Press and release the component button on your remote that corresponds to the component you want the remote to operate (TV, VCR, etc.). The illuminated ON-OFF button will turn on and remain on. Step3Press both the component and the ON-OFF buttons. The illuminated ON-OFF button will turn off, and then will come back on. Step4Release both buttons after the ON-OFF button turns back on. The button should remain illuminated. Step5Press and release the PLAY button. If the component does not respond after five seconds, continue to press the PLAY button every five seconds until the component turns off. Step6Press and release the REVERSE button when the component turns off, then wait to see if the component turns on again. Step7Press and release the STOP button to save the new code.
    Posted on Jun 25, 2008
    • Ken Jones
      Ken Jones Jun 25, 2008
      here are the codes
      Programming Your RCA Universal Remote.
      The RCA universal remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: TV-000, VCR-000, Cable Box-000, and AUX is programmed with VCR code 037. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
      Programming a Device using Code Search: 1- Manually turn ON your device (TV, VCR, Cable Box) 2- Press and "HOLD" CODE SEARCH 3- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once. 4- Release CODE SEARCH. 5- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second). 6- Once the device turns off, press and release ENTER. 7- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
      Programming a device using the Code Lists: 1- Find codes for each device and brand below. 2- Press and "HOLD" CODE SEARCH. 3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step. 4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH. 6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists. TV Codes Admiral 005 MTC 011,019,027 Amtron 064 Multivision 081 Akai 002 NAD 018,023 Anam National 038 NEC 011,014,019,027,038 AOC 011,019,027,088 MTC 0017,0023 Bell & Howell 005 NEC 0017,0023 Candle 011,027,033 Panasonic 012,013,038,086 Citizen 011,027,033,064 Penny 000,008,011,019,027,068,086 Colortyme 011,027,084 Philco 006,007,010,011,013,016,019,027 Concerto 011,027 033,035,037,038,043,087,089 Contec/Cony 036,037,040,042,064 Philips 006,007,010,011,013,016,033,035 Craig 064 037,038,043,066,073 Curtis Mathes 000,011,015,027 Pioneer 011,027,045,062,093 CXC 064 Portland 011,019,027 Daewoo 011,019,027 ProScan 000 Daytron 011,027 Proton 011,027,037,072 Dimensia 000 Quasar 012,038,092 Electrohome 006,011,014,027,038 Radio Shack 000,021,025,036,037,059,064 061,068 RCA 000,006,011,019,027,034,038,044 Emerson 011,026,027,028,029,030 046,088 031,032,037,042,053,064 Realistic 021 065,067,075,076,079 Sampo 011,027 Envision 011,027 Samsung 006,011,014,015,019,027,036,037 Fisher 017,021,039,041 077 Funai 064 Sanyo 017,021,039,056,057,058 GE 000,008,009,011,012,027 Scott 028,037,064 038,068,086,089,091 Sears 000,006,011,014,017,018,021,023 Goldstar 003,004,006,011,019 027,039,040,041,051,071,083 027,037,050 Sharp 011,020,025,027,037,052,053,059 Hallmark 011,027 060 Hitachi 009,011,027,036,037 Signature 005,094 040,047,048,063,080 Sony 002 Infinity 013 Soundesign 011,027,033 JBL 013 Sylvania 006,007,010,011,013,016,027,033 Jensen 011,027 035,043,049,066,087,089 JVC 012,024,036,037,040,048,051,074 Symphonic 064,076 Kawasho 002,011,027 Tatung 038 Kenwood 006,011,014,027 Technics 012 Kloss Novabeam 035,043 Techwood 011,027 KTV 078 Teknika 011,019,027,033,037,040,066 Loewe 013 Telecaption 090 Luxman 011,027 TMK 011,027 LXI 000,013,018,021,023,054 Toshiba 018,021,023,071,085,090 Magnavox 006,007,010,011,013,016 Universal 008,009 027,033,035,043,066,087,089 Victor 051 Marants 013 Vidtech 019,027 Marantz 011,013,027,069 Wards 000,005,006,007,008,009,010,011 Memorex 005 013,019,025,027,028,035,043,059 MGA 006,011,014,019,022 066,076,082,089 027,041,056,061,068 Yamaha 006,014,019,027 Mitsubishi 006,011,014,019,022,027,041,055 Zenith 001 056,061,068
    I NEED THE CODES NUMBERS TO PROGRAM THIS TV WITH UNIVERSAL CONTROL
    GE Universal Remote Codes ' Jasco
    https://jascoproducts.com/support/ge-universal-remote-codes
    Make a note of which version you have and replace the batteries and cover. A version 2 through version 4 remote will have a "V2" to "V4" after the model number. ... Programyour GE Universal Remote using the correct code list and instructions. ... Sometimes a code will allow limited function control (e.g. volume and channel ...
    Universal Remote Control Codes
    www.remotecodelist.com/
    Codes and links for a number of universal remote controls, including Sony, RCA, ... If you have a remote for which you know the codes (or a web page that lists them) head to ... How to Program a GE Universal Remote Control .... look for your model of TV or VCR and find the online instructions that include the remote codes.
    RCA Universal Remote Control- Target Programming ...
    Jan 05, 2016 | Coby TF-TV3217 32 in. LCD TV
    Code for Toshiba TV on rca universal remote
    there are many different codes, here is a link to a site with some of them, scroll down to your brand of TV, there will be a list or # codes. In the past when I programed my remotes to my TV's, sometimes there were no matches for my TV on the list. if non of them work, in the instructions for your remote there is a procedure that you go through to program a unit if you don't know the code. http://www.eliztech.com/remotes/rca-codes-4digit.php
    if you lost your instructions for your rca universal remote go here to watch short instruction video http://www.rcaaudiovideo.com/remote-videos/
    Aug 18, 2014 | Televison & Video
    WHATS THE CODE FOR RCA TV ..I HAVE A ONE FOR ALL UNIVERSAL REMOTE NEED THE CODES TO PROGRAM MY RCA TV
    You received a list of ALL Codes with your universal.
    I got this off the internet. But I do not know what type of universal you bought. You didn't mention it.
    Good Luck.
    Here is the link if you need it. :0)
    http://www.google.com/search?q=universal+code+for+rca+tv&rls=com.microsoft:en-us:IE-SearchBox&ie=UTF-8&oe=UTF-8&sourceid=ie7&rlz=1I7GGLL_en
    rca
    Nov 07, 2009 | Universal Remote Control P000203220-1...
    I lost my instruction manual and the code can you help me program
    Sorry it took so long to respond to your request for assistance. You can find the instructions and codes you need to program your television at the RCA customer support website [http://www.rcaaccessories.com/rcaaccessories/ ] Copy this web address and paste it into the address bar of your web browser. This will take you to the RCA main customer support page. Just go to the universal remote control section and find your model remote control. Use the model number to find the technical support information page. On this page will be a copy of the owners manual and the remote control codes to use with your products. I hope this information helps you with your problem of needing instructions and codes to use your remote with your products. Thank you for using FixYa and have a nice day!
    Jan 04, 2009 | RCA 3-Device Universal Remote with...
    Remote control codes and directions
    http://www.oneforall-int.com/?pag=54 this will take you to the one for all website with the codes you need for your model
    Oct 28, 2008 | RCA Universal Remote Control
    Lost manual to rca universal remote, lost programing to operate remote
    RCA Universal remote codes for the Mitsubishi TVs are...006,011,014,019,022,027,041,056,061,068.
    First, turn on TV
    Press and hold code search button on remote
    Press and release the TV button
    Enter the three digit code you want
    Release code search
    Push channel up, if device responds, that code worked.. If not, repeat steps 1-5 with each code until you find the one that works. This information can be downloaded from http://www.thompsontv.com/rcarc.html
    If you want a hard copy with codes for all TVs.
    Aug 29, 2008 | RCA Universal Remote Control
    Televison & Video Logo
    597 people viewed this question
    Top RCA Televison & Video Experts
    matt martin
    matt martin
    Computer Repairing
    Computer Repairing
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
