Question about Admiral Refrigerators
Ice is forming in the bottom of the freezer compartment, and water forms under the fridge freezer. Also the comperssor does not always respond to the freezer setting when the stat is turned up. Regards alan
  • 1,462 Answers
Compressor may not start for quite a time even if you change the stat setting. this is deliberate.
ice on floor of the freezer is caused by the drain being blocked - probably with ice. remove the back panel inside the freezer and melt the ice off with a hairdryer. you will have to clear the drain itself with hot water - needs a bit of patience.
this can just happen with time but you may have a fault on the defrost system which is causing it
Posted on Jun 25, 2008
Why is ice forming under the bottom drawer of my Samsung American fridge freezer Rsa1shpn and then water eventually leaking out the door? I have defrosted the fridge freezer but still have the problem
There is a drain tube located under the panel of most freezers. If that clogs up, the auto defrost can't work. The freezer defrosts by evaporating all the moisture out of the compartment. So, check that first. Secondly, a leaky door seal can also cause that problem. You can order door seals online or on Amazon.
Oct 17, 2014 | Samsung Freezers
Kfcs22evms ice under freezer door and water leaks out onto floor
Check for a clogged drain line at he bottom rear.
Oct 30, 2017 | Refrigerators
Ice forming under bottom freezing compartment drawer
is the ice in the fridge or freezer if its the freezer it might have a blocked drain is there water in the back try on the compressor if not check the drain failing that it will be a d frost issue get someone out to look at it
Feb 16, 2011 | LG Refrigerators
Pooling of water in fridge compartment of my Neff fridge/freezer
The defrost drain is clogged. Defrost drains usually get there clog right behind the back freezer panel. Remove this to get to the defrost drain and remove all built up ice and clear the drain and you should be fine. Hope this helps.
Feb 04, 2010 | Refrigerators
Formation of ice in freezer compartment
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
Sep 05, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Water in bottom of refrigerator coming from freezer (not really sure of the exact model as I'm not home to double check).
If water appears on the floor in front of the refrigerator once or twice a day, it could be due to a clog in the defrost drain tube. The usual evidence of a clogged drain in a side-by-side refrigerator is ice under the bottom basket in the freezer compartment, in addition to a puddle of water on the floor. Try watching the YouTube videos like this one:
Apr 01, 2017 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
Leaking frost-free Zanussi fridge-freezer
Has this thing a separate frezer and cooler compartment.
Have tried to completely defrost and clean that thing.
At times like in airco's the pinch valve for the cooling process to effect (expansion) is stuck frozen, or very seldom broke.
Apr 14, 2009 | Freezers
Ice repeatedly forms at the bottom of the freezer compartment. Eventually it reaches the door and water leaks out. Signature Series Frostfree Model HMG51108
Your defrost drain line is frozen up.
Turn off fridge, remove bottom freezer drawers.
Remove visible ice.
Take a hair dryer and melt ice at the back of the freezer at the drain pan.
Pour a water and bleach mixture through drain hole.
This procedure could take a hour or more.
Feb 21, 2009 | Admiral 26 cu. ft. Side-By-Side...
Ice forming on freezer
The drain is plugged. This fridge will defrost every 8 hrs or so. When it does , it will melt the frost that has built up on the evaporator. This melted frost will run down a drain under the evaporator to a drain in the bottom directly under the evaporator. When the drain gets plugged the water cannot drain out of the freezer compartment. After several defrost cycles the melted frost will overflow onto the freezer floor. When the fridge starts back up it will freez this water is the bottom of the fridge. sometimes this water that is now ice will melt on the next defrost cycle and actually run out into the floor. You will have to unplug the fridge or turn it off, then remove the cover to the evaporator. Get a hair dryer and melt the ice aruond the evaporator and drain. Once the ice is removed, check the drain and try to clear it. Once clear, replace everything but the shelves. Plug the fridge back in or turn it back on. Observe and listen for the evaporator fan. It should be running now. When working on the ice on the evaporator always be carefull. The defrost heater can be damaged if up push or pull on it too much.
Nov 15, 2008 | Samsung RF265AA Bottom Freezer French Door...
Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Apr 12, 2008 | Refrigerators
Refrigerators Logo
96 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
