Question about DeLonghi DEFSGG36-SS Gas Kitchen Range
Delonghi gas range fan on all th time, almost
Cooling fan comes on, even when the oven is off.. Fan will almost never shut off.
  •  Tony
    Tony Feb 19, 2013
    This ended up being the tangelfan - cooling fan - shot bearings
    Brigadier General:
  • 3,614 Answers
Behind the control panel, there you will see the thermal switch/thermal fuse, this part is the one holds and trigger the cooling fan.. once this part is broken it could result in system malfunction, like the one you gave encountered..
micro
Posted on Jun 25, 2008
  • micromaster
    micromaster Jun 25, 2008
    kindly accept my solution here and there, will yah...?
    thanks
After the oven has been on 1 hour, or so, it shuts down. Also the controls go blank. After the oven cools down, the controls return and cooking can continue.
I think you have a cooling fan issue with your unit, if the thermostats are sensing the unit is too warm it shuts down. So if the cooling fans is not coming on is will happen also. I hope this answers you question. Good Luck
Apr 14, 2016 | KitchenAid KGST307 Gas Kitchen Range
DELONGHI GAS RANGE DEGESC24SS COOLING FAN COMES ON NEVER SHUTS OFF
the switch to the fan could be not functioning as normal, or it was not totally functioning.. it it better to check it right away.
Jun 25, 2008 | DeLonghi DEFSGG36-SS Gas Kitchen Range
Cooling fan below range top goes on and stays on even when oven is off
That sure cools...
Jenn Air Oven SVD48600B continuous fan - ApplianceBlog
www.applianceblog.com/.../12231-Jenn-Air-Oven-SVD48600B-continu...
Dec 10, 2007 - 10 posts - ‎4 authors Turned the oven on to 250, and the cooling fan (not exhaust fan, not convection ...What part number would this be for our Jenn Air SVD48600B range? ... It may only be that the fan comes on and stays on when not needed. ... Caveat: the same thermometer says my Jenn-Air wall oven is also 50* below the ... Jenn-air JDS9860AAP Oven won't turn on - ApplianceBlog
Mar 24, 2013
Jenn-Air SVE47600 Downdraft Fan Not Working
Nov 30, 2010
Jenn Air Oven SVE47500B oven light and fan stay on ...
Nov 20, 2010
More results from www.applianceblog.com
Nov 21, 2015 | Jenn-Air Kitchen Ranges
Range modle is KGSS907SSS01.when i cooking or use the oven, some noice come out ,until over is off or the temperature is down.
is it possible the coolant fan is running and has started making some noise ...the fan will come on at temperature request it has a thermostat to bring it on when the oven gets hot enough and will cool down...sometimes the fan will run even when you turn the oven off if it is hot enough until the temperature gets down low enough to shut it off...maybe this is what is going on and the fan has started making noise now and will need to be replaced.... good luck to you
Jan 13, 2011 | KitchenAid KGSS907SSS Gas Kitchen Range
I HAVE A WALL MOUNT TRUE TEMP OVEN AND THE FAN COMES ON WHEN I BAKE AND WILL NOT SHUT OFF FOR A LONG TIME AFTER I SHUT OF THE OVEN.
some models have an internal fan that will run even when the oven is off to cool the electronic boards inside,,,, for ur perticular model look through your owners manual, or download a copy at geappliances.com ango to their section for manuals and literature
Feb 06, 2010 | GE Profile 30" Self-Cleaning Drop-In...
Delonghi ESM465ST Oven Noisy Fan
If it is a fan assisted oven, then you are likely to have 2 fans, an external cooling fan, and a fan inside the oven for ciculating the hot air.
So to answer your query, yes it is a noisy fan you are going to have to establish which fan.
It could be a worn bearing, or the fan blade has come loose.
If it is a worn bearing, thge only cure is a new fan.
Hope this helps with your problem.
Dec 02, 2009 | DeLonghi Ovens
Stoves 900DFa oven cuts out
Hi.
The most probable cause is failure in your panel cooling fan 9not the one inside your oven)
If the appliance switches on again after 15 - 20 minutes then the fault is most likely here.
Unfortunately as you have gas the you will need a Gas Safe Certified engineer to repair
Regards
aardvark repairs
Nov 18, 2009 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Cooker delonghi professional dfs903 6 ring hob has terible fan like noise whenever you turn the oven on which has now become unbearable and occurs whether using the grill, the oven on fan setting or not....
i had the same problem, the noise is coming from a circular fan located under the hob itself. not from the fan at the back of the oven.its a cooling fan.i bought a new one online around £70 and got a local gas fitter to install it. its a real big job and most if not all of the gas connections to the hob have to be disconnected its a big job.but worth it.
i have the same problem with the door,thats what im looking for.
if i find a solution ill let you know
Oct 05, 2009 | DeLonghi Kitchen Ranges
DeLonghi Debige 2440 Electric/Gas Double Oven Fan Failure Light
I had the very same problem. I slid the oven out of the wall about 6" or so, unplugged it, plugged it back in. It worked. I'm not sure if I jostled some connection, or if unplugging/repluging it in reset some sort of circuit fault.
Feb 02, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
Oven cuts out after about 15 minutes
most common fault is the cooling fan is failing to come on, whreas the fan will be okay ( check windings with ohmn meter ) it will normally have a ceramic 10k resitor in series with the live which goes open circiut
Sep 25, 2007 | Stoves 900DFa Dual Fuel (Electric and Gas)...
DeLonghi DEFSGG36-SS Gas Kitchen Range Logo
233 people viewed this question
Top DeLonghi Kitchen Ranges Experts
JP Services
JP Services
Vitaliy Gins
Vitaliy Gins
Paul Bade
Are you a DeLonghi Kitchen Range Expert? Answer questions, earn points and help others
