My cd player stops and then restarts where it stopped. It is oriignial equipment in a Chevy Silverado 2003. I have used a lens cleaner disc and cleaned the cds. It also does this with new discs.
  • 4,234 Answers
Generally speaking this occurs when the player loses track of where it is. If the lens has been cleaned and this still occurs, an alignment is needed at the least or the optics are starting to fail and will require replacement. The cleaners that are just discs with brushes are not eally effective. Try removing hte unit from the vehicle and opening up the top. Clean the lens using a cotton swab and alcohol. If that fails to resolve the problem, then the alignment route is the next step.
Dan
P.S.
A reset will not effect this behavior.
Posted on Jun 25, 2008
    Genius:
  • 1,142 Answers
Did you try doing a hard reset to the device
  • Maanita Chadha
    Maanita Chadha Jun 25, 2008
    What is the error messag you get ?
My CD player stopped working in my 2003 Cadillac Deville. Whenever I load a CD it just says error?
hi Walter.
this could be a couple o things wrong here.
might need just a clean up.
  1. Confirm there is no CD in the player. ...
  2. Blow away dust with a handheld air bulb. ...
  3. Remove the lens cover. ...
  4. Select a lint-free cleaner. ...
  5. Wipe a small amount of high-strength isopropyl alcohol onto the lens. ...
  6. Let dry before replacing the cover. ...
  7. Try a lens cleaner disc.
  8. Sometimes a CD player will display a "No Disc" error. What this means is that the CD player, for some reason, does not recognize the disc. There are various reasons for this error, from the CD lens eye being dirty to a CD format that is incompatible with theplayer. Troubleshoot through process of elimination.31 Mar 2015
    How to Fix a No-Disc Error on a CD Player ' Techwalla.com
    https://www.techwalla.com/articles/how-to-fix-a-no-disc-error-on-a-cd-player
    or try this link.
How to Fix No Disc Error on CD Player Techwalla com
i know yours is in a car but the principle is the same.or should be.
i would just buy a lens cleaning disc that way you dont have to open it up,and see if it does clean it for you.
Nov 30, 2017 | Cadillac Cars & Trucks
Stopped playing after I inserted damp CD in 200 disc loading mechanism
this can be due to some moisture in lens.
leave the unit to get dry for 2 days.
Jul 04, 2008 | Kenwood DV-5700 Multi-disc DVD Player
My dvd player has just stopped playing disc's? I insert a disc, it loads up as the little circle comes up, saying loading. Then it says bad disc.It stops. Does anyone know what could be wrong here?
Couple things could be. I've found : the disc can be dirty, wipe it off. Or if its damaged the lens won't read it.
What usually helps the most is to put a lens cleaner in the player. they sell them. I only have a CD cleaner ( prob called lens cleaner). It still fixes it for me.
Jul 20, 2015 | Televison & Video
WHY DOES THE DISC STOP FOR A MINUTE AND RESTART ON HI-FI HITACHI AX-M68
Try a Lens Cleaner CD.
Go to a store that sells electric goods. Ask for a CD Lens Cleaner disc.
Sep 13, 2014 | Audio Players & Recorders
The Disc begins to be "read" and then stops suddenly, and restarts "reading" the disc until an error sign occurs on the screen
how long have you been using the player. There is every tendency that the lens (laser) of your player is weak and that's why it cannot read or play discs.
The lens (laser) is what makes the player reads discs, and if the lens is weak/dirty, there is no way it can read or play disc.
Get a lens cleaner and use it to clean the lens, if that does not solve the problem, then its means, the lens needs to be changed completely.
Good luck.
Apr 17, 2010 | Cyberhome CH-LDV 700B Portable DVD Player
DVD Player stops reading disc Error message :
usually this happens when lens cannot read the the disc. Due to few reason 1 Your disk is scratched 2 Your DVD lens is covered with dust 3 You need to replace DVD lens
Try another few CD/DVD to rectify whether there is any problem with dvd you are trying to play
if this error occurs on all the dvd you played then the most likely proble is with your DVD lens either its coverd with dust use Disk cleaner if not you got to replace a new DVD lense as per model
Feb 18, 2010 | Samsung DVD-V9800 DVD Player/VCR
5 disc cd changer CC4000 will not read
All players need cleaned from time totime. Do NOT try to clean it with anything other than a CD / DVD lens cleaner. They are available almost everywhere that sellsBlank media. It will clean the lens without scratching or smearing it.
Dec 06, 2009 | Marantz CC-4000 5-Disc CD Changer
CD player stops working
Are you using burned discs. If so try burning them at the slowest speed available on your computer, usually about 8x. If your using standard store bought CD's then you might have a lens issue. Try purchasing one of those lense cleaner discs, they have a tiny brush on them that cleans the lens while it spins, they work pretty good.
Oct 13, 2009 | 2004 Toyota Corolla
Stopped reading cd's
its means that your CD player cannot read data. actually the problem is in your lens. try to clean frist by cd cleaner disc with liguid and try. same problem change CD OPTICAL LENS.
Jun 07, 2009 | Audio Players & Recorders
Kenwood cd stopped pla computer made cds after i dropped it now will play for about 1min then stops
hi 1paullawrenc, try get your lens cleaned by using a lens cleaner hope this solve your problem.
raj..
May 11, 2008 | Kenwood CD-203 5-Disc CD Changer
 Grubhead
Grubhead
