Question about HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 Paper Feed Problem
My HP PSC 1315 has functioned relatively well for a few years. Recently a paper feed problem arose. First the printer sucked in a lot of paper and then when I removed this paper it hasnt fed a piece of paper through since. The printer attempts to pull a piece of paper through but no movement occurs. What can I do to remedy this problem?
  • 2 more comments
  • Anonymous Jun 26, 2008
    I have the same problem, it worked for about a year,then when I moved and re-hooked up my printer it did not work right. It did the same thing with the Paper Feed Problem, and won't print anymore. Any suggestion?
  • Anonymous Jun 29, 2008
    Ditto.
  • Anonymous Dec 09, 2008
    so frustrating!
  • redsail Mar 07, 2009
    My HP PSC 1315 All-In-One InkJet Printer feeds paper at start up even though there is no job to print. First, it feeds one sheet all the way through and then feeds a second sheet 75% of the way through at which time an error appears on the printer. I have reinstalled printer software, unpluged printer power and USB but nothing seems to work. Any ideas on how to correct this?
    Thanks!!
Remove the back panel or the duplexer if you have one attached (no tools required). Then locate the pinch wheel which is on the left hand side, about 4-5 cm in and from the left (looking from the back). With a cotton bud reach in and wipe the roller. push your little finger in to gently rotate the roller bit by bit so that you clean the whole roller. Only touch the side of the roller with your finger, so that you don't leave residues.
HP recommends that you use a little distilled, sterile or bottled water on the bud, but not tap water. I found that just using a dry bud worked to remove the build up of dust from the roller.
This succesfully got my PSC 1317 picking up paper again. I think it will apply to other printers in the PSC 1300 series.
Posted on Jul 25, 2008
I had the same problem with my 1315. was going to replace the printer but tried your advice and it worked a treat. thanks you've saved me some money!
Posted on Apr 25, 2009
Will not feed paper.
Open the front door, take cover behind the printer a little can shake up to something it's a pen
Oct 20, 2014 | HP PSC 1315 All-In-One InkJet Printer
Paper will not feed
E-mail hp psc 1315 inkjet support. I have found their advice very useful.
Jan 18, 2011 | HP PSC 1315 All-In-One InkJet Printer
Printer will not grab the paper HP PSC 1315 All in one inkjet
Try using a cloth (not a paper towel) with some water on it and clean the feed rollers. Also no alcohol.
Jan 21, 2010 | HP PSC 1315 All-In-One InkJet Printer
Hp psc printer paper feed is jammed with an piece of paper.
The small gear located in the paper feed assambly is break or fail, need replacement parts to repair it.
May 22, 2009 | HP PSC 1315 All-In-One InkJet Printer
Hp 1350 all-in one psc
your paper feed problem may be due to the feed rollers or due to the fact the mecanism that raise the paper doesn't function properly. Normally if you clean the rollers that should work
Jan 25, 2009 | HP PSC 1350 All-In-One Thermal Printer
Will not feed the paper.
it probably needs a roller assembly replaced
Jan 16, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 Problem
Glad to know that your problem is solved.
Thank you for using fixya..
Jun 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
2,854 people viewed this question
Seeker5211
Seeker5211
