Question about E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop
Nitro model engines
Ihave an irvine 40 marine engine that wont run smoothly. I have dismantled and cleaned the carb since it was last run sixteen years ago. I do not have the instructions and do not know the settings for the carburetter etc.
Can you help?
    Guru:
  • 1,342 Answers
Why won't my mercury marine engine not restart after running for 30 or 40 min.
is it cooling ok ? run on hose and check engine block and exhaust plate cool ! water inlets clear and impellor good condition ? compressions all over 100psi ? carbs clean ?
Jul 23, 2014 | Clymer Mercury/Mariner 75-225 HP 4-Stroke...
Engine start to run rough and shot off after 3-4 minutes running
Possible solutions:
You could have water in your gas if so a $3 additive will unfreeze and eliminate this which will cause rough idling. If your carb is clean make sure to let the blower warm up for several minutes, take off the choke as it warms and it will run smoothly. Last if those dont work, adjust your carbs mixture setting screw (when the engine is warm). (and check your oil! Hope this helps.
Feb 04, 2014 | Mtd Snow Thrower 28" 357cc Ohv
Engine starts runs well but after 45 minutes or so will die . I can choke as it starts to die and engine will continue running.When it dies will restart easily.Ihave replaced gas filter ,cleaned tank,new...
Carb. needs to be rebuilt. If your choking the engine it to keep the alive and you've cleaned and replaced everything else, I would recommend carb. overhaul.
Sep 23, 2013 | Garden
TILLER LOPS. WONT RUM SMOOTH WHEN TILLING GARDEN ENGINE GOES UP & DOWN IN SPEED
For a quick and easy fix, try adding some Fuel Treatment to your fuel as it sounds like the carb is dirty. I recommend Berryman Chem Tool B-12. The dose is 1 ounce to a gallon of gas. Double that, or just add a little bit directly to the tiller fuel tank...if this is a 4 stroke engine. If this is a 2 stroke, don't do this as the oil in the mix will be too cut by the solvent in the B-12. Carburetor disassembly and cleaning will be required on a 2 stroke tiller engine. Clean that carb ONLY with WD 40. Don't use any strong solvents on the internal carb as it can swell and/or distort the sensitive check valves and mess up the carburetor permanently.
Jul 20, 2011 | Garden
Problems with RC engine not running right!
Theres a idle screw located on engine under airfilter, should be small flat head. Clockwise will stop the carb from closing thus not cutting engine of. Also make sure you run car slightly richer than leaner. Hope this helps.
Mar 31, 2010 | Exceed-RC 1/8TH .21 Tectonic Nitro...
4.5hp B&S engine on a bolens mower..won't idle steadily
This is called hunting, your fuel-air ratio is not right. Your carb. jets need cleaned
Sep 02, 2009 | Garden
Wont run smooth
have the govenor checked could be the spring is worn down
May 10, 2009 | Toro Lawn Mower With Toro Power Tools
Engine is surging.
hi,
sound through experience you have a air leak possible from a gasket or oring if so equipped. take some wd 40 and spray around the carb gaskets and seams. if this stabalises the surging or smooths it out it is definatley seeping air around it. in any case you will most likely need to take the carb back apart and repair or replace the gasket. hopes this helped. happy mowing!
Mar 29, 2009 | Craftsman Garden
E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
